个人文集
(huang1998)The empirical mode decomposition and the Hilbert spectrum for nonlinear and non-stationary time series analysis
(huang1999)A new view of nonlinear waterwaves: The Hilbert Spectrum
(huang2003)A confidence limit for the empirical mode decomposition and Hilbert spectral analysis
(huang2003)A study of the characteristics of white noise using the empirical mode decomposition method
(huang2004)INTRODUCTION TO THE HILBERT HUANG TRANSFORM
(huang2005)An Adaptive Data Analysis Method for nonlinear and Nonstationary Time Series - The Empirical Mode Decomposition and Hilbert Spectral Analysis
(huang2005)Computing Instantaneous Frequency by Normalizing Hilbert Transform
(huang2005)On certain theoretical developments underlying the Hilbert-Huang transform
(huang2005)THE HILBERT-HUANG TRANSFORM AND ITS APPLICATIONS (BOOK)
(G.Rilling2003)On empirical mode decomposition and its algorithms
(G.Rilling2004)Empirical mode decomposition as a filter bank
(G.Rilling2005)Empirical mode decomposition, fractional Gaussian noise and Hurst exponent estimation
(G.Rilling2006)on the Influence of Sampling on the Empirical Mode Decomposition
(G.Rilling2007)Bivariate Empirical Mode Decomposition
(G.Rilling2008)One or Two Frequencies The Empirical Mode Decomposition Answers
(Kopsinis2007)Enhanced Empirical Mode Decomposition using a Novel Sifting-Based Interpolation Points Detection
(Kopsinis2007)Investigation of the Empirical Mode Decomposition Based on Genetic Algorithm Optimization Schemes
(Kopsinis2008)Investigation and Performance Enhancement of the Empirical Mode Decomposition Method Based on a Heuristic Search Optimization Approach
(Bouzid2004)Empirical mode decomposition of voiced speech signal
(Bouzid2007)Maximum Error in Discrete EMD Decomposition of Periodic Signals
重要期刊
(SPL2005)A fast algorithm for bidimensional EMD
(SPL2005)Empirical mode decomposition - an analytical approach for sifting process
(SPL2007)Complex Empirical Mode Decomposition
(SPL2007)Intrinsic Mode Entropy for Nonlinear Discriminant Analysis
(SPT2007)Extraction of Dynamic Patterns From Wide-Area Measurements Using Empirical Orthogonal Functions
(EL2007)Similarity searching based boundary effect processing method for empirical mode decomposition
重要会议
(ICASSP2005)The use of a masking signal to improve empirical mode decomposition
(ICASSP2006)Localization Based Separation of Mixed Audio Signals with Binary Masking of Hilbert Spectrum
(ICASSP2007)Optimal and Bidirectional optimal Empirical Mode Decomposition
(ICASSP2007)Rotation Invariant Complex Empirical Mode Decomposition
非常感谢楼主提供的文献目录!略有修正,不知是否合适?
1.(huang2004)INTRODUCTION TO THE HILBERT HUANG TRANSFORM 应该是(huang2005)THE HILBERT-HUANG TRANSFORM AND ITS APPLICATIONS (BOOK)中的第一章。
2.另有一本书:(huang2005)Hilbert-Huang Transform in Engineering
