查看: 868|回复: 1
[综合讨论] 关于三角滤波器程序的问题求助
发表于 2007-11-19 20:33 | 显示全部楼层 |阅读模式
我是matlab新手,对三角滤波器melbankm.m程序,看不太明白。
想请教这个三角滤波器组里的每个滤波器的覆盖范围是一定的吗?
是不是可调节的,哪里调节,怎么调节?
function [x,mn,mx]=melbankm(p,n,fs,fl,fh,w)
if nargin < 6
  w='tz';
  if nargin < 5
    fh=0.5;
    if nargin < 4
      fl=0;
f0=700/fs;
fn2=floor(n/2);
lr=log((f0+fh)/(f0+fl))/(p+1);
% convert to fft bin numbers with 0 for DC term
bl=n*((f0+fl)*exp([0 1 p p+1]*lr)-f0);
b2=ceil(bl(2));
b3=floor(bl(3));
if any(w=='y')
  pf=log((f0+(b2:b3)/n)/(f0+fl))/lr;
  fp=floor(pf);
  r=[ones(1,b2) fp fp+1 p*ones(1,fn2-b3)];
  c=[1:b3+1 b2+1:fn2+1];
  v=2*[0.5 ones(1,b2-1) 1-pf+fp pf-fp ones(1,fn2-b3-1) 0.5];
  mn=1;
  mx=fn2+1;
else
  b1=floor(bl(1))+1;
  b4=min(fn2,ceil(bl(4)))-1;
  pf=log((f0+(b1:b4)/n)/(f0+fl))/lr;
  fp=floor(pf);
  pm=pf-fp;
  k2=b2-b1+1;
  k3=b3-b1+1;
  k4=b4-b1+1;
  r=[fp(k2:k4) 1+fp(1:k3)];
  c=[k2:k4 1:k3];
  v=2*[1-pm(k2:k4) pm(1:k3)];
  mn=b1+1;
  mx=b4+1;
if any(w=='n')
  v=1-cos(v*pi/2);
elseif any(w=='m')
  v=1-0.92/1.08*cos(v*pi/2);
if nargout > 1
  x=sparse(r,c,v);
else
  x=sparse(r,c+mn-1,v,p,1+fn2);
[ 本帖最后由 eight 于 2007-11-19 20:49 编辑 ]
 楼主| 发表于 2007-11-19 20:34 | 显示全部楼层
补充
%MELBANKM determine matrix for a mel-spaced filterbank [X,MN,MX]=(P,N,FS,FL,FH,W)
% Inputs: p   number of filters in filterbank
%  n   length of fft
%  fs  sample rate in Hz
%  fl  low end of the lowest filter as a fraction of fs (default = 0)
%  fh  high end of highest filter as a fraction of fs (default = 0.5)
%  w   any sensible combination of the following:
%        't'  triangular shaped filters in mel domain (default)
%        'n'  hanning shaped filters in mel domain
%        'm'  hamming shaped filters in mel domain
%        'z'  highest and lowest filters taper down to zero (default)
%        'y'  lowest filter remains at 1 down to 0 frequency and
%      highest filter remains at 1 up to nyquist freqency
%         If 'ty' or 'ny' is specified, the total power in the fft is preserved.
% Outputs: x     a sparse matrix containing the filterbank amplitudes
%        If x is the only output argument then size(x)=[p,1+floor(n/2)]
%        otherwise size(x)=[p,mx-mn+1]
%  mn   the lowest fft bin with a non-zero coefficient
%  mx   the highest fft bin with a non-zero coefficient
% Usage: f=fft(s);   f=fft(s);
%  x=melbankm(p,n,fs);  [x,na,nb]=melbankm(p,n,fs);
%  n2=1+floor(n/2);  z=log(x*(f(na:nb)).*conj(f(na:nb)));
%  z=log(x*abs(f(1:n2)).^2);
%  c=dct(z); c(1)=[];
% To plot filterbanks e.g. plot(melbankm(20,256,8000)')
melbankm.m
3.46 KB, 下载次数: 4
GMT+8, 2024-10-2 18:29 , Processed in 0.086450 second(s), 22 queries , Gzip On.
