查看: 2063|回复: 5
[HHT] rilling的EMD.m中的疑问
发表于 2007-11-1 21:00 | 显示全部楼层 |阅读模式
rilling的emd.m中的[indmin,indmax,indzer] = extr(m)应该是求极值的,其中的判断条件MODE_COMPLEX是什么意思?望高手指点!
发表于 2007-11-1 21:14 | 显示全部楼层
回复 #1 nacred 的帖子
把那段程序贴出来好吗?:@)
发表于 2007-11-1 21:16 | 显示全部楼层
回复 #1 nacred 的帖子
好像是复合模态!
 楼主| 发表于 2007-11-1 21:18 | 显示全部楼层
% computes the mean of the envelopes and the mode amplitude estimate
function [envmoy,nem,nzm,amp] = mean_and_amplitude(m,t,INTERP,MODE_COMPLEX,ndirs)
NBSYM = 2;
if MODE_COMPLEX
  switch MODE_COMPLEX
    case 1
      for k = 1:ndirs
        phi = (k-1)*pi/ndirs;
        y = real(exp(-i*phi)*m);
        [indmin,indmax,indzer] = extr(y);
        nem(k) = length(indmin)+length(indmax);
        nzm(k) = length(indzer);
        [tmin,tmax,zmin,zmax] = boundary_conditions(indmin,indmax,t,y,m,NBSYM);
        envmin(k,:) = interp1(tmin,zmin,t,INTERP);
        envmax(k,:) = interp1(tmax,zmax,t,INTERP);
      envmoy = mean((envmin+envmax)/2,1);
      if nargout > 3
        amp = mean(abs(envmax-envmin),1)/2;
    case 2
      for k = 1:ndirs
        [tmin,tmax,zmin,zmax] = boundary_conditions(indmin,indmax,t,y,y,NBSYM);
        envmin(k,:) = exp(i*phi)*interp1(tmin,zmin,t,INTERP);
        envmax(k,:) = exp(i*phi)*interp1(tmax,zmax,t,INTERP);
      envmoy = mean((envmin+envmax),1);
      if nargout > 3
else
  nem = length(indmin)+length(indmax);
  nzm = length(indzer);
  [tmin,tmax,mmin,mmax] = boundary_conditions(indmin,indmax,t,m,m,NBSYM);
  envmin = interp1(tmin,mmin,t,INTERP);
  envmax = interp1(tmax,mmax,t,INTERP);
  envmoy = (envmin+envmax)/2;
  if nargout > 3
发表于 2007-11-1 22:30 | 显示全部楼层
原帖由 nacred 于 2007-11-1 21:18 发表
NBSYM = 2;
if MODE_COMPLEX
  switch MODE ...
请看flandrin的最新文章,相信文章标题会在 emd.m 的帮助信息中有说明
 楼主| 发表于 2007-11-2 18:24 | 显示全部楼层
谢谢!:@)
GMT+8, 2024-10-1 15:31 , Processed in 0.064291 second(s), 19 queries , Gzip On.
