查看: 1170|回复: 2
[其他相关] 卡内基梅隆大学ansys模拟训练资料
发表于 2007-10-30 15:09 | 显示全部楼层 |阅读模式
刚刚发现的ansys资料,特与大家一起分享!
网址: http://www.andrew.cmu.edu/course/24-ansys/
内容有:1.Fluid #1 Flow Around An Airfoil USING FLOTRAN
                2.Fluid #1 Velocity analysis in fluid flow in a channel using HEAT ANALOGY
               3.Fluid #2 Flow Around An Airfoil USING HEAT ANALOGY
               4.Fluid #2 Velocity analysis of fluid flow in a channel USING FLOTRAN
               5.Fluid #3 Analyzing Flow in a System of Pipes USING FLOTRAN
               6.Fluid #4 3D Flow Over a Car USING FLOTRAN
               7.Fluid #5 Predicting the Weather Using 3D Flow
               8.Fluid #6 3D Exhaust Flow Through A Muffler
              9. Structural #1 Analysis of a power transmission tower
              10.Structural #2 Analysis 2-D Beam structure
              11 Structural #3 Analysis of a Steel Bracket
              12 Structural #4 Analysis of a 3-D truss structure
              13 Structural #5 Analysis of a 3-D Beam structure
              14 Structural #6 Analysis of a 3D solid object
              15 Thermal 5 3D Heat Conduction within a Solid
               16 Thermal #1 Temperature distribution in a fin cooled electronic component
             17 Thermal #2 Heat flux analysis of a composite modular wall
              18 Thermal #3 Transient heat transfer analysis of a rectangular slab
              19 Thermal #4 Temperature distribution in a 3D fin cooled electronic component
               20Thermal #4 Temperature distribution in a 3D fin cooled electronic component
              21 Vibration #1 Modal Analysis of a Turbine
              22Vibration #3 Vibration in an Airplane Wing
[ 本帖最后由 bluehy 于 2007-10-30 15:22 编辑 ]
发表于 2007-10-30 21:18 | 显示全部楼层
楼主真是善于发现好东西啊。:handshake
发表于 2007-11-10 14:11 | 显示全部楼层
不錯的資料啊:victory:
GMT+8, 2025-1-13 19:44 , Processed in 0.062938 second(s), 18 queries , Gzip On.
