查看: 1503|回复: 3
[综合讨论] 菜鸟请教各位高手!
发表于 2007-10-27 17:00 | 显示全部楼层 |阅读模式
我在运行ANSYS/LS-DYNA求解时,在message信息中出现如下提示:
Input file: work.k
The native file format       : 32-bit small endian
Memory size from command line:     8600000
expanding   memory to     8600000
********  notice  ********  notice  ********  notice  ********
* This is the LS-DYNA Explicit Finite Element code.          *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results    *
* obtained from this system. The user must verify his own    *
* results.                                                   *
* LSTC endeavors to make the LS-DYNA code as complete,       *
* accurate and easy to use as possible.                      *
* Suggestions and comments are welcomed.  Please report any  *
* errors encountered in either the documentation or results  *
* immediately to LSTC through your site focus.               *
* Copyright (C) 1990-2005                                    *
* by Livermore Software Technology Corp. (LSTC)              *
* All rights reserved                                        *
contracting memory to     2463096
expanding   memory to     4906192
expanding   memory to     5592136
expanding   memory to    16613068
*** Error Memory is set            8013068 words short
           increase the memory size.
           Current memory size      8600000
T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Initialization ....... 0.0000E+00    0.00     4.5300E-01  100.00
  Element processing ... 0.0000E+00    0.00     0.0000E+00    0.00
  Binary databases ..... 0.0000E+00    0.00     0.0000E+00    0.00
  ASCII database ....... 0.0000E+00    0.00     0.0000E+00    0.00
  Contact algorithm .... 0.0000E+00    0.00     0.0000E+00    0.00
  Contact entities ..... 0.0000E+00    0.00     0.0000E+00    0.00
  Rigid bodies ......... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Nonlinear ... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Lin. Alg. ... 0.0000E+00    0.00     0.0000E+00    0.00
  T o t a l s            0.0000E+00    0.00     4.5300E-01  100.00
Problem time       =    0.0000E+00
Problem cycle      =         0
Total CPU time     =         0 seconds (   0 hours  0 minutes  0 seconds)
CPU time per zone cycle  =         0 nanoseconds
Clock time per zone cycle=         0 nanoseconds
Number of CPU's     0
NLQ used/max       96/    96
Start time   10/27/2007 16:33:48
End time     10/27/2007 16:34:03
Elapsed time       15 seconds (   0 hours  0 minutes 15 seconds)
E r r o r   t e r m i n a t i o n
      程序运行终止,请问各位:我该怎么处理以让计算继续进行下去,请斑竹和各位高手指点!
发表于 2007-10-27 20:12 | 显示全部楼层
怎么感觉好象计算不收敛计算机做不下去了
发表于 2007-10-27 22:03 | 显示全部楼层
运行内存是不是设置的小了点啊?
 楼主| 发表于 2007-10-30 13:56 | 显示全部楼层
回复 #3 octopussheng 的帖子
多谢指点,正是这个原因.问题已经解决了.
GMT+8, 2025-7-12 23:27 , Processed in 0.080990 second(s), 17 queries , Gzip On.
