查看: 1142|回复: 0
[材料与接触] Fatal error:Problem too large?
发表于 2007-10-27 09:41 | 显示全部楼层 |阅读模式
*** WARNING ***                         CP =      11.875   TIME= 09:21:19
Meshes made up of 10 percent or more of SOLID185 tetrahedra are not
recommended.
*** WARNING ***                         CP =      25.297   TIME= 09:21:41
ANSYS could not find attached solid element for contact element 26055.
Check the element connectivity data.
*** FATAL ***                           CP =     114.609   TIME= 09:26:12
Problem too large.  Matrix wavefront of 107115 rows exceeds allowed
46340.
The above error is non-recoverable by ANSYS
ANSYS run terminated by the indicated error
Current data base saved if possible.
导致失败的主要原因是什么? 模型太大?
GMT+8, 2024-10-2 20:26 , Processed in 0.051296 second(s), 17 queries , Gzip On.
