查看: 7154|回复: 12
[小波] [转帖]小波去噪matlab程序
发表于 2005-12-6 09:40 | 显示全部楼层 |阅读模式
  clear
  clc
  %在噪声环境下语音信号的增强
  %语音信号为读入的声音文件
  %噪声为正态随机噪声
  sound=wavread('c12345.wav');
  count1=length(sound);
  noise=0.05*randn(1,count1);
  for i=1:count1
  signal(i)=sound(i);
  for i=1:count1
  y(i)=signal(i)+noise(i);
  %在小波基'db3'下进行一维离散小波变换
  [coefs1,coefs2]=dwt(y,'db3'); %[低频 高频]
  count2=length(coefs1);
  count3=length(coefs2);
  energy1=sum((abs(coefs1)).^2);
  energy2=sum((abs(coefs2)).^2);
  energy3=energy1+energy2;
  for i=1:count2
  recoefs1(i)=coefs1(i)/energy3;
  for i=1:count3
  recoefs2(i)=coefs2(i)/energy3;
  %低频系数进行语音信号清浊音的判别
  zhen=160;
  count4=fix(count2/zhen);
  for i=1:count4
  n=160*(i-1)+1:160+160*(i-1);
  s=sound(n);
  w=hamming(160);
  sw=s.*w;
  a=aryule(sw,10);
  sw=filter(a,1,sw);
  sw=sw/sum(sw);
  r=xcorr(sw,'biased');
  corr=max(r);
  %为清音(unvoice)时,输出为1;为浊音(voice)时,输出为0
  if corr>=0.8
  output1(i)=0;
  elseif corr<=0.1
  output1(i)=1;
  for i=1:count4
  if output1(i)==1
  switch abs(recoefs1(i))
  case abs(recoefs1(i))<=0.002
  recoefs1(i)=0;
  case abs(recoefs1(i))>0.002 & abs(recoefs1(i))<=0.003
  recoefs1(i)=sgn(recoefs1(i))*(0.003*abs(recoefs1(i))-0.000003)/0.002;
  otherwise recoefs1(i)=recoefs1(i);
  elseif output1(i)==0
  %对高频系数进行语音信号清浊音的判别
  count5=fix(count3/zhen);
  for i=1:count5
  s=sound(n);
  w=hamming(160);
  sw=s.*w;
  a=aryule(sw,10);
  sw=filter(a,1,sw);
  sw=sw/sum(sw);
  corr=max(r);
  if corr>=0.8
  output2(i)=0;
  elseif corr<=0.1
  output2(i)=1;
  for i=1:count5
  if output2(i)==1
  switch abs(recoefs2(i))
  case abs(recoefs2(i))<=0.002
  recoefs2(i)=0;
  case abs(recoefs2(i))>0.002 & abs(recoefs2(i))<=0.003
  recoefs2(i)=sgn(recoefs2(i))*(0.003*abs(recoefs2(i))-0.000003)/0.002;
  otherwise recoefs2(i)=recoefs2(i);
  elseif output2(i)==0
  %在小波基'db3'下进行一维离散小波反变换
  output3=idwt(recoefs1, recoefs2,'db3');
  %对输出信号抽样点值进行归一化处理
  maxdata=max(output3);
  output4=output3/maxdata;
  %读出带噪语音信号,存为'101.wav'
  wavwrite(y,5500,16,'c101');
  %读出处理后语音信号,存为'102.wav'
  wavwrite(output4,5500,16,'c102');
发表于 2006-4-11 10:58 | 显示全部楼层
能不能把信号给传一下,谢谢!
发表于 2006-5-27 19:57 | 显示全部楼层
  好贴顶起来,感谢楼主分享!!
发表于 2006-6-10 18:01 | 显示全部楼层
  楼主,语音信号用wavwrite函数写文件,听不到声音呀。求助
发表于 2007-3-8 20:59 | 显示全部楼层
回复 #12 zhao197642 的帖子
可以听到声音啊,估计是你的音量开得不够大~:@)
发表于 2008-4-7 16:51 | 显示全部楼层
如果是图像,二维的呢?
发表于 2008-4-14 10:55 | 显示全部楼层
好东西当然要支持一下
发表于 2008-4-14 17:33 | 显示全部楼层
hao dong xi
zhi chi yi xia
发表于 2008-4-18 16:17 | 显示全部楼层
谢谢楼主,可以参考下:@) :@)
发表于 2010-9-1 16:12 | 显示全部楼层
这个对我横有帮助  谢谢!
发表于 2010-9-2 15:11 | 显示全部楼层
小波去噪是不是也得分几种方法。
头像被屏蔽
发表于 2014-7-28 17:44 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2024-9-29 23:34 , Processed in 0.067722 second(s), 21 queries , Gzip On.
