查看: 1114|回复: 0
[结构分析] 在结构中求热应力
发表于 2007-10-5 19:48 | 显示全部楼层 |阅读模式
我在这个长方体上(0.004*0.004*0.05m)EX7.2e10,,PRXY0.3,APLX2.4e-5。全是国际单位
施加了20摄氏度的参考温度以及520度的温度载荷,然后我限制了长方体Z轴方向两个面位移为0,限制了X轴方向两个面位移为1e-6,限制了Y轴方向两个面位移为1e-6!而实际上,长方体自由膨胀的话,Z轴方向会有6e-4的位移,在截面方向也会有4.8e-5的位移!所以我想这样的话长方体应该由于膨胀受阻会有很大的应力产生,但是模拟结果却只有0.277e8,这个值比我只限制Z轴方向算得的结果0.864e9还小很多!真是不知道错哪了,大家帮忙看看吧,谢谢了!
图片在附件里
第一张是加载完后的图
第二张是等效应力图,位移有些夸张,没用真实的比例!
第三张是位移图
/FILNAME,stress test,0
/TITLE,test
/PREP7
ET,1,SOLID45
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,7.2e10
MPDATA,PRXY,1,,0.3
MPTEMP,,,,,,,,
MPTEMP,1,0
UIMP,1,REFT,,,20
MPDATA,ALPX,1,,2.4e-5
FINISH
/SOL
FINISH
/PREP7
BLOCK,,0.004,,0.004,,0.05,
/USER,  1
/VIEW,  1,  0.562065102477    , -0.101562903645E-01,  0.827030634465
/ANG,   1, -0.146174033205
/REPLO
/AUTO,1
/REP,FAST
CM,_Y,VOLU
VSEL, , , ,       1
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT,       1, ,   1,       0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
ESIZE,0.001,0,
MSHAPE,0,3D
MSHKEY,1
CM,_Y,VOLU
VSEL, , , ,       1
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FINISH
/SOL
TUNIF,520,
TREF,20,
SAVE
FLST,2,2,5,ORDE,2
FITEM,2,1
FITEM,2,-2
/GO
DA,P51X,UZ,
APLOT
/PNUM,KP,0
/PNUM,LINE,0
/PNUM,AREA,1
/PNUM,VOLU,0
/PNUM,NODE,0
/PNUM,TABN,0
/PNUM,SVAL,0
/NUMBER,0
/PNUM,ELEM,0
/REPLOT
/USER,  1
/VIEW,  1,  0.955138723028    , -0.259023894253E-01, -0.295023873602
/ANG,   1,  -4.72666555355
/REPLO
/VIEW,  1, -0.809364904384    ,  0.630827492704E-01, -0.583908398891
/ANG,   1,  -3.84128444134
/REPLO
/VIEW,  1, -0.668360624291    , -0.663734407485E-01, -0.740870192585
/ANG,   1,  -3.49732276154
/REPLO
/VIEW,  1, -0.772552880947    ,  0.256674967239    , -0.580758131525
/ANG,   1,  -2.66902155023
/REPLO
/VIEW,  1, -0.707759526500    ,  0.229998736482    , -0.667964844783
/ANG,   1,  -4.18490168691
/REPLO
FLST,2,1,5,ORDE,1
FITEM,2,3
/GO
DA,P51X,UY,1e-6
FLST,2,1,5,ORDE,1
FITEM,2,4
/GO
DA,P51X,UY,1e-006
FLST,2,1,5,ORDE,1
FITEM,2,4
FLST,2,1,5,ORDE,1
FITEM,2,3
DADELE,P51X,UY
FLST,2,1,5,ORDE,1
FITEM,2,3
/GO
DA,P51X,UY,-1e-006
FLST,2,1,5,ORDE,1
FITEM,2,5
/GO
DA,P51X,UX,-1e-006
FLST,2,1,5,ORDE,1
FITEM,2,6
/GO
DA,P51X,UX,1e-006
ALLSEL,ALL
/SHOW,JPEG,,0
JPEG,QUAL,75,
JPEG,ORIENT,HORIZ
JPEG,COLOR,2
JPEG,TMOD,1
/GFILE,800,
/CMAP,_TEMPCMAP_,CMP,,SAVE
/RGB,INDEX,100,100,100,0
/RGB,INDEX,0,0,0,15
/REPLOT
/DELETE,_TEMPCMAP_,CMP
/SHOW,CLOSE
/DEVICE,VECTOR,0
ALLSEL,ALL
solve
FINISH
/POST1
/EFACET,1
PLNSOL, S,EQV, 2,1.0
/DIST,1,1.08222638492,1
/REP,FAST
/REP,FAST
/REP,FAST
/DSCALE,ALL,1.0
/EFACET,1
/DSCALE,ALL,AUTO
/EFACET,1
/SHOW,JPEG,,0
JPEG,QUAL,75,
JPEG,ORIENT,HORIZ
JPEG,COLOR,2
JPEG,TMOD,1
/GFILE,800,
/RGB,INDEX,0,0,0,15
/REPLOT
/SHOW,CLOSE
/DEVICE,VECTOR,0
/EFACET,1
PLNSOL, U,SUM, 2,1.0
/SHOW,JPEG,,0
JPEG,QUAL,75,
JPEG,ORIENT,HORIZ
JPEG,COLOR,2
JPEG,TMOD,1
/GFILE,800,
/RGB,INDEX,0,0,0,15
/REPLOT
/SHOW,CLOSE
/DEVICE,VECTOR,0
FINISH
/PREP7
/REPLOT,RESIZE
FINISH
! /EXIT,MODEL
这个我还用梁单元beam189算过,位移约束越多,应力却变小了!真是搞不懂!
加载后的图
加载后的图
等效应力图
等效应力图
位移图
位移图
GMT+8, 2025-1-14 04:23 , Processed in 0.092552 second(s), 22 queries , Gzip On.
