查看: 1543|回复: 1
[CFD及热分析] 求助!顺序耦合法中的物理环境法的疑问
发表于 2007-8-29 16:27 | 显示全部楼层 |阅读模式
在建好模型划分网格之后,创建流体物理环境时是否先要用asel命令选中流体区,然后设置流体边界条件?流体固体的材料属性都是在创建物理环境时才设置吗?对帮助文件中的橡胶垫的例子有点疑问。
!!!!!  Create element plot and write to the file gasket.grph
asel,s,,,1,3
esla,s
/Title, Initial mesh for gasket and neighborhood  此处定义分析标题干什么
eplot
/ZOOM,1,RECT,0.3,-0.6,0.4,-0.5
alls
!!!!!  2. Create Physics Environment for the Fluid   创建流体物理环境前不需要先选择流体区域吗?
et,1,141
et,2,0        ! Gasket becomes the Null Element
vin=3.5e-1    ! Inlet water velocity (meters/second)
!!           CFD Solution Control
flda,solu,flow,1
flda,solu,turb,1
flda,iter,exec,400
flda,outp,sumf,10
!!           CFD Property Information
flda,prot,dens,constant
flda,prot,visc,constant
flda,nomi,dens,1000.   ! 1000 kg/m3 for density - water
flda,nomi,visc,4.6E-4  ! 4.6E-4 kg-s/m (viscosity of water)
flda,conv,pres,1.E-8   ! Tighten pressure equation convergence
!!    CFD Boundary Conditions (Applied to Solid Model)
lsel,s,,,8,17,9
lsel,a,,,20
dl,all,,vx,0.,1      ! Centerline symmetry
lsel,s,,,9
dl,all,,vx,0.,1
dl,all,,vy,vin,1     ! Inlet Condition
lsel,s,,,2
lsel,a,,,18,19
lsel,a,,,21,22
dl,all,,vx,0.,1      ! Outer Wall
dl,all,,vy,0.,1
lsel,s,,,1,3,2
lsel,a,,,6
dl,all,,vx,0.,1      ! Gasket
dl,all,,vy,0.,1
lsel,s,,,15
dl,15,,pres,0.,1     ! Outlet pressure condition
!!! create named component of nodes at the bottom of gasket
lsel,s,,,1
nsll,,1
cm,gasket,node
nlist ! List initial nodal positions of the bottom of the gasket
/com, +++++++++ STARTING gasket coordinates --------
alls
/title,Fluid Analysis 此处为什么又要定义分析标题?
physics,write,fluid,fluid
!!!!!  3.  Create Physics Environment for the Structure
physics,clear
et,1,0      ! The Null element for the fluid region
et,2,56     ! Gasket element - material 2
mp,ex,2,2.82E+6    ! Young's modulus for rubber
mp,nuxy,2,0.49967  ! Poisson's ratio for the rubber  在此处定义材料属性?
tb,mooney,2
tbdata,1,0.293E+6  !  Mooney-Rivlin Constants
tbdata,2,0.177E+6  !    "     "        "
发表于 2007-12-14 11:50 | 显示全部楼层
我也在做这方面的问题
我也在做这方面的问题,有空可以一起讨论讨论吗?
GMT+8, 2025-1-13 22:35 , Processed in 0.063632 second(s), 17 queries , Gzip On.
