查看: 2799|回复: 4
[综合讨论] 使用fsolve后出现的Optimization terminated问题
发表于 2007-8-29 15:35 | 显示全部楼层 |阅读模式
使用fsolve,出现如下提示:Optimization terminated: directional derivative along search direction less than TolFun and infinity-norm of gradient less than 10*(TolFun+TolX).
虽然exitflag = 1,但计算结果显然不对,应该是和上面的提示有关,我试着将TolFun和Tolx减小,但是不行。请问该问题怎么解决呢?先谢谢了
发表于 2007-8-29 16:16 | 显示全部楼层
将问题及你的代码贴出来看看.
 楼主| 发表于 2007-8-30 09:29 | 显示全部楼层
代码和问题
代码如下:
clear
clc
format long
%标定时参数c=[L1 L2 qc xp0 yp0 m n dm dn q1z q2z]
c=[270 250 0 280 -140 8 5 40 40 2 2];
L1=c(1);L2=c(2);qc=c(3);xp0=c(4);yp0=c(5);m=c(6);n=c(7);dm=c(8);dn=c(9);q1z=c(10);q2z=c(11);
%待标定参数q1z,q2z,qc,xp0,yp0,
%载入测量点的关节角度
encoder=load('ctest2');
[rencoder,lencoder]=size(encoder);
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%计算
for i=0:(rencoder-1)
    qas(i+1,1)=encoder(i+1,1)+sym('x(1)')/360*pi;
    qas(i+1,2)=encoder(i+1,2)+sym('x(2)')/360*pi;
    p(i+1,1)=L1*cos(qas(i+1,1))+L2*cos(qas(i+1,1)+qas(i+1,2))-rem(i,n)*dn*cos(sym('x(3)'))+fix(i/n)*dm*sin(sym('x(3)'))-sym('x(4)');
    p(i+1,2)=L1*sin(qas(i+1,1))+L2*sin(qas(i+1,1)+qas(i+1,2))-rem(i,n)*dn*sin(sym('x(3)'))-fix(i/n)*dm*cos(sym('x(3)'))-sym('x(5)');
fun=inline(p);
%设定迭代初值,请注意调整迭代初值
x0=[0 0 0 275 -145];
%进行迭代计算标定。
disp(('>>标定运算中................'))
myoptions=optimset('LevenbergMarquardt','on','NonlEqnAlgorithm','lm','MaxIter',10000,'TolFun',1e-6,'Tolx',1e-6,'MaxFunEvals',10000);
[x,Fval,exitflag,output]=fsolve(fun,x0,myoptions);
%[x,exitflag,output,resnorm,residual]=fsolve(fun,x0,myoptions);
%myoptions.TolFun;myoptions.TolX
%plot(residual(:,1))
%查看标定结果。
程序执行结果如下:
x =
  1.0e+002 *
  -0.00157063263327   0.01999999639038  -0.00018823937648   2.77315197169297  -1.45245585453119
Fval =
  1.0e-004 *
  -0.01594640878011  -0.12048655690933
   0.03428882394019  -0.03766079572642
   0.03962466678331  -0.16617129830365
   0.02481593242010   0.03753617619395
   0.01692886144156   0.00008686754427
  -0.05308237234658  -0.06403248079323
  -0.02576540737209   0.11849102776296
   0.02211054209056  -0.01946831304167
  -0.00197759675302   0.04430346109530
   0.02211379012351  -0.00505518414684
   0.03217430844416   0.08018792101439
  -0.07483193201097  -0.00094193410405
  -0.05233907188540   0.09332183253719
   0.00274875787909   0.01332473601678
   0.06932629389667  -0.10225775412209
  -0.01252338961422  -0.02912995171300
  -0.06191226759711   0.06072040690697
   0.03385061916106   0.00057519628172
   0.06426964205275  -0.05061323122391
   0.03675691573335  -0.04299255465412
  -0.01354735786663  -0.00303138165236
  -0.07229292123156   0.05114632756431
   0.03069964805036   0.00130948251353
   0.06652136391949  -0.05083241575221
   0.03795018130859  -0.03537865978842
   0.00070312523803   0.00564309232232
  -0.09476660068231   0.06300757689814
  -0.09079808933166   0.08536141251625
  -0.01131872863880   0.02868075029028
   0.08621919846519  -0.07459986676395
  -0.05258040744138   0.01491118354124
  -0.09602083650861   0.05066673139709
   0.01701882069938  -0.01661088418814
  -0.03767661894472   0.04545984353399
   0.01345104294614  -0.01193452618509
   0.02590453675566  -0.01323077214010
   0.02501625829154   0.00573993276021
   0.09590536592441  -0.02829373215718
  -0.02042577989414   0.03779048796559
  -0.01059285523297   0.03445793964829
exitflag =
output =
       iterations: 4
        funcCount: 34
         stepsize: 1
     cgiterations: []
    firstorderopt: []
        algorithm: 'medium-scale: Levenberg-Marquardt, line-search'
          message: [1x147 char]
理想值应该是0 0 0 280 -140;运算出来的结果和理想值偏差太多,虽然Fval很小,且exitflag = 1,是不是和提示有关:Optimization terminated: directional derivative along
什么原因导致优化停止。是程序中的rem(i,n)*dn*cos(sym('x(3)'))+fix(i/n)*dm*sin(sym('x(3)'))造成的么?
我将程序中sin(sym('x(3)'))用零代替(因为理论值就是零),只保留cos(sym('x(3)'))这一部分,结果就对了。对于这样待标定值既有正弦又有余弦运算的,怎么才能计算出可用结果。
因为x(3)在零附近,我将sin(sym('x(3)'))用sym('x(3)')代替;cos(sym('x(3)'))用1-(sym('x(3)'))^2/2代替,仍旧不行。难道只能保留正弦或余弦,另外一个用1或0代替。那如果'x(3)'的真实值比方
说pi/8,那就不好办了。
发表于 2007-8-30 10:05 | 显示全部楼层
1. 请将附件上传一下,以便于他人调试;
2. 函数可能写为function更合适一些;
3. 估计你还需要调节自定参数,或者先用默认值试试.
4. 你后面的猜测有拼凑的嫌疑。
当然,关键是要将原问题讲一下,以及附件上传一下,别人才能给出好的建议。
 楼主| 发表于 2007-9-3 12:00 | 显示全部楼层
怎么设置optimset中的参数能保证收敛
发现了问题,原来是弧度和角度换算弄错了。另外一个问题,考虑测量时的随机误差后,导致的solve算法不收敛的问题,一般怎么解决?假设随机误差为0.2,怎么设置Tolx,TolFun才能保证收敛呢?optimset里面的其它参数对此是不是也有影响
GMT+8, 2024-10-2 22:30 , Processed in 0.053125 second(s), 17 queries , Gzip On.
