查看: 1401|回复: 4
[编程技巧] 看不懂有关 nargin 的程序代码
发表于 2007-8-28 12:01 | 显示全部楼层 |阅读模式
John H. Mathews著的数值方法(matlab版)中第308页有个求极小值的单纯形法程序,
一开始的 if nargin==5
                 show=0;
    %show==1displays iterations(P and Q)
没弄明白,这是用来做什么呀?
各位大侠,能否教我一下?谢谢!
[ 本帖最后由 eight 于 2007-8-28 18:56 编辑 ]
发表于 2007-8-28 14:00 | 显示全部楼层
nargin, nargout
Purpose
Number of function arguments.
Synopsis
n = nargin
n = nargout
Description
In the body of a function M-file, nargin and nargout indicate how many input or output arguments, respectively, a user has supplied.
nargin returns the number of input arguments specified for a function.
nargout returns the number of output arguments specified for a function.
Examples
This example shows portions of the code for the function fplot, which has an optional number of input and output arguments:
function [x0,y0] = fplot(fname,lims,npts,angl,subdiv)
%FPLOT Plot a function.
% FPLOT(fname,lims,npts,angl,subdiv)
% The first two input arguments are
% required; the other three have default values.
% [x,y] = fplot(...) returns x and y instead
% of plotting them.
if nargin < 5, subdiv = 20; end
if nargin < 4, angl = 10; end
if nargin < 3, npts = 25; end
if nargout == 0
plot(x,y)
else
x0 = x;
y0 = y;
发表于 2007-8-28 14:03 | 显示全部楼层
nargin用法示例。
    函数文件examp.m:
function fout=charray(a,b,c)
if nargin==1
   fout=a;
elseif nargin==2
   fout=a+b;
elseif nargin==3
   fout=(a*b*c)/2;
    命令文件mydemo.m:
x=[1:3];
y=[1;2;3];
examp(x)
examp(x,y')
examp(x,y,3)
 楼主| 发表于 2007-8-28 17:59 | 显示全部楼层
好厉害,谢谢!:@D
发表于 2007-8-29 16:22 | 显示全部楼层
简单讲,就是判断输入变量个数.------help nargin 即知.
GMT+8, 2024-10-2 22:23 , Processed in 0.067751 second(s), 18 queries , Gzip On.
