查看: 1263|回复: 3
[综合讨论] DESIZE, 10, , 20
发表于 2007-8-26 21:31 | 显示全部楼层 |阅读模式
DESIZE, 10, , 20
这个命令10,20分别是什么意思?
发表于 2007-8-27 07:44 | 显示全部楼层
DESIZE, MINL, MINH, MXEL, ANGL, ANGH, EDGMN, EDGMX, ADJF, ADJM
MINL
Minimum number of elements that will be attached to a line when using lower-order elements (defaults to 3 elements per line). If MINL = DEFA, all arguments will be set back to default values. If MINL = STAT, list status of command (Including on/off status). If MINL = OFF, deactivate default element sizing. If MINL = ON, reactivate default element sizing.
MINH
Minimum number of elements that will be attached to a line when using higher-order elements. Defaults to 2 elements per line.
MXEL
Maximum number of elements that will be attached to a single line (lower or higher-order elements). Defaults to 15 elements per line for h-elements and 6 divisions per line for p-elements. To deactivate this limit, specify a large number (such as 9999).
ANGL
Maximum spanned angle per lower-order element for curved lines. Defaults to 15 degrees per element.
ANGH
Maximum spanned angle per higher-order element for curved lines. Defaults to 28 degrees per element.
EDGMN
Minimum element edge length. Defaults to no minimum edge length. The MINL or MINH argument can override this value.
EDGMX
Maximum element edge length. Defaults to no maximum edge length. The MXEL argument can override this value.
ADJF
Target aspect ratio for adjacent line. Used only when free meshing. Defaults to 1.0, which attempts to create equal sided h-elements; defaults to 4 for p-elements.
ADJM
Target aspect ratio for adjacent line. Used only when map meshing. Defaults to 4.0, which attempts to create rectangular h-elements; defaults to 6 for p-elements.
 楼主| 发表于 2007-8-27 09:51 | 显示全部楼层
这个是HELP里内容,怎么不用中文说一下
发表于 2007-8-27 14:37 | 显示全部楼层
学着自己搞定吧,翻译这东东,很难符合大家的胃口
所以学习ANSYS 一定要养成看帮助的习惯,慢慢来吧,不要急
不行找个字典,呵呵
[ 本帖最后由 venture 于 2007-8-28 08:26 编辑 ]
GMT+8, 2025-1-28 09:00 , Processed in 0.082194 second(s), 17 queries , Gzip On.
