查看: 1357|回复: 3
[结构分析] 帮看看我的命令流有何错误?
发表于 2007-8-23 15:03 | 显示全部楼层 |阅读模式
我用三维实体模型分析一个转子-轴承系统的模态,转子是中空的,内径一致,带一个盘,总算不对,请问我的命令流中哪里错了?谢谢各位
/PREP7
ET,1,MESH200
ET,2,SOLID45
ET,3,COMBIN14
ET,4,COMBIN14
KEYOPT,1,1,6
KEYOPT,1,2,0
KEYOPT,3,1,0
KEYOPT,3,2,2
KEYOPT,3,3,0
KEYOPT,4,1,0
KEYOPT,4,2,3
KEYOPT,4,3,0
R,1,10000000, , ,           !弹簧系数
*DIM,SPIN,,4                                                    ! SPIN VELOCITY (RPM)
SPIN(1) = 0.
SPIN(2) = 20000.
SPIN(3) = 50000.
SPIN(4) = 90000.
SPIN(5) = 70000.
SPIN(6) = 90000.
SPIN(7) = 110000.
SPIN(8) = 130000.
MP,EX,1,2.06e11           !弹模
MP,DENS,1,7900        !密度
mp,prxy,1,0.275          !泊松比
K,1,0,0.006,,
K,2,0,0.0175,,
K,3,0.0555,0.0175,,
K,4,0.0555,0.0198,,
K,5,0.1557,0.0198,,
K,6,0.1557,0.0509,,
K,7,0.1657,0.0509,,
K,8,0.1657,0.025,,
K,9,0.1989,0.025,,
K,10,0.1989,0.033,,
K,11,0.5039,0.033,,
K,12,0.5039,0.0198,,
K,13,0.5969,0.0198,,
K,14,0.5969,0.0175,,
K,15,0.6369,0.0175,,
K,16,0.6369,0.006,,
K,17,0.0555,0.006,,
K,18,0.1557,0.006,,
K,19,0.1657,0.006,,
K,20,0.1989,0.006,,
K,21,0.5039,0.006,,
K,22,0.5969,0.006,,
LSTR,1,2
LSTR,2,3
LSTR,3,4
LSTR,4,5
LSTR,5,6
LSTR,6,7
LSTR,7,8
LSTR,8,9
LSTR,9,10
LSTR,10,11
LSTR,11,12
LSTR,12,13
LSTR,13,14
LSTR,14,15
LSTR,15,16
LSTR,16,1
AL,ALL         !创建面
LSTR,3,17
LSTR,5,18
LSTR,8,19
LSTR,9,20
LSTR,12,21
LSTR,14,22
FLST,3,6,4,ORDE,2
FITEM,3,17
FITEM,3,-22
ASBL,1,P51X            !用线分割面
ESIZE,0.006,0,
LCCAT,3,17
LCCAT,5,18
LCCAT,7,19
LCCAT,9,20
LCCAT,11,21
LCCAT,13,22
TYPE,1
MSHAPE,0,2D
MSHKEY,1
AMESH,ALL
LSEL,S,LCCA     !选择连接生成的线
LDELE,ALL       !删除连接线
ALLSEL,ALL      !选择所有图元
K,40,,,,
K,41,100,,,
TYPE,2
VROTAT,ALL, , , , , ,40, 41,360, ,
VGLUE,ALL
VSWEEP,ALL
N,40001,0.090865, -0.0198, 0
N,40002,0.56202, -0.0198, 0
N,40003,0.090865, 0, 0.0198
N,40004,0.56202, 0, 0.0198
TYPE,3              !创建轴承单元
REAL,1
E,3262,40001
E,3442,40002
TYPE,4
REAL,1
E,2002,40003
E,2182,40004
FINI
/SOLU
D,ALL,UX                                                  ! NO TRACTION & NO TORSION
D,40001,ALL
D,40002,ALL
D,40003,ALL
D,40004,ALL
RATIO = 4*ATAN(1)/30
ANTYPE,MODAL
CORIOLIS,ON,,,ON                                         ! CORIOLIS ON IN A STATIONARY REFERENCE FRAME
NBF = 10
MODOPT,QRDAMP,NBF,,,ON
/OUT,SCRATCH.txt
*DO,I,1,8
   OMEGA,SPIN(I)*RATIO
   MXPAND,NBF
   SOLVE
*ENDDO
FINI
/POST1
PRCAMP,,1.,RPM                                          ! PRINT CAMPBELL VALUES FOR SLOPE=1, UNIT= RPM
PLCAMP,,1.,RPM
 楼主| 发表于 2007-8-23 15:52 | 显示全部楼层
*DIM,SPIN,,4 中应该定义为8,我发错了
 楼主| 发表于 2007-8-25 10:23 | 显示全部楼层
没人能帮帮小弟吗?
发表于 2007-8-26 10:44 | 显示全部楼层
不是没人帮,最好是将问题描述清楚,算不对,是怎么样的算不对?结果不可信?还是其它的?
或者你认为真实的结果与算出来的结果差别在哪?
像这样,没说清楚,就放上一堆命令流,说让人看看哪里有问题,这是很让人反感的,至少我会这么觉得。
让人有针对性去帮你解决问题,也可以节省不少时间啊,如果还是没人回答,那就是都不太懂这方面的,或者懂这方面的都没上线。
GMT+8, 2025-1-30 01:23 , Processed in 0.075128 second(s), 17 queries , Gzip On.
