查看: 2119|回复: 3
[综合讨论] 计算出错了
发表于 2007-7-20 14:45 | 显示全部楼层 |阅读模式
计算出错了,但是不知道什么意思,英文水平太差了。
请高手指点一下。
*** ERROR ***                           CP=     81.328   TIME= 14:42:57
Large negative pivot value ( -447.763646 ) in Eqn.system.  May be
because of a bad temperature-dependent material property used in the
model.
 楼主| 发表于 2007-7-20 14:45 | 显示全部楼层
*** WARNING ***                         CP=     81.406   TIME= 14:43:02
Small equation solver pivot term= 9.063207875E-07 encountered at UZ DOF
of node 5316.  Check for an insufficiently constrained model.
*** ERROR ***                           CP=     81.562   TIME= 14:43:03
LSSOLVE looping is stopped because of a solution error.
 楼主| 发表于 2007-7-20 14:48 | 显示全部楼层
*** WARNING ***   SUPPRESSED MESSAGE    CP=     59.484   TIME= 14:41:04
Surface loads on unselected area 92 are not transferred to elements.
*** WARNING ***                         CP=     64.328   TIME= 14:42:38
SOLID185 wedges are recommended only in regions of relatively low
stress gradients.
发表于 2007-7-24 16:40 | 显示全部楼层
约束不够,出现大位移了。检查约束,重新施加
GMT+8, 2024-10-2 22:16 , Processed in 0.064408 second(s), 17 queries , Gzip On.
