查看: 6378|回复: 12
[ADAMS专区] [推荐]超强的ADAMS官方资料下载推荐
发表于 2005-6-24 08:15 | 显示全部楼层 |阅读模式
http://www.mscsoftware.com/suppo ... s/training_main.cfm
adams官方网站提供的,内容是关于仿真方面的,资料多而齐全,快快下载阿!!!!
具体内容如下:
Training Materials
MSC.Software Corporation utilizes professional instructional materials for its commercial training courses. These are also available to faculty registered with our website, and can be re-used in part or in whole for teaching yourself or your students familiarity with MSC.ADAMS.
The pdf documents can be saved to your local computer by clicking on the "save" icon once the file has loaded in to the Acrobat Reader. Get Acrobat Reader.
Basic MSC.ADAMS Full Simulation
About the course
Instructor Guide - v12, Instructor Guide - v11 or Instructor Guide - v10.1 (3 Mb to 6Mb pdf document)
Student Guide - v12, Student Guide - v11 or Student Guide - v10.1 (3 Mb to 6Mb pdf document)
Exercise files for Basic MSC.ADAMS Full Simulation course v12, v11 or v10.1 (660 kb to 2Mb zip archive)
Basic MSC.ADAMS Solver
About the course
Instructor Guide (3 Mb pdf document)
Student Guide (3 Mb pdf document)
Exercise files for Basic MSC.ADAMS Full Simulation course (610 kb zip archive)
MSC.ADAMS/Flex
About the course
Instructor Guide (6.5 Mb pdf document)
Student Guide (3.6 Mb pdf document)
Exercise files for Basic MSC.ADAMS Full Simulation course (12 Mb zip archive)
MSC.ADAMS/Car
About the course
Instructor Guide (2.4 Mb pdf document)
Student Guide (2.4 Mb pdf document)
Exercise files for Basic MSC.ADAMS Full Simulation course (60 kb zip archive)
MSC.ADAMS/Controls
About the course
Student Guide (844 kb pdf document)
Exercise files for Basic MSC.ADAMS/Controls course (6 Mb zip archive)
MSC.ADAMS/Vibrations
About the course
Instructor Guide (3.7 Mb pdf document)
Exercise files for Basic MSC.ADAMS/Vibrations course (1 Mb zip archive)
MSC.ADAMS Theory Primer
This is a heavyweight overview of the theory behind MSC.ADAMS simulations. This is not a self-contained course, but rather an overview of the equation formulation techniques and numerical integration used within MSC.ADAMS. This is intended for a sophisticated audience in advanced dynamics or computational dynamics. View the primer (511 kb pdf document)
Getting Started Guides
Others around the world have also developed training materials which are available free for your use.
Carnegie Mellon Getting Started Guide - developed by Carnegie Mellon University
French-language Introduction to MSC.ADAMS - developed by Universite Laval
 楼主| 发表于 2005-6-24 08:16 | 显示全部楼层
Basic MSC.ADAMS Full Simulation Package Course
If you're new to mechanical system simulation, this course will give you the foundation of skills you'll need to begin using ADAMS' powerful virtual prototyping, testing, and visualization capabilities.
Who Should Attend:
New MSC.ADAMS users who wish to learn about mechanical system simulation (MSS) and how MSC.ADAMS can be used to perform MSS
Designers
Engineering Analysts
Test Engineers
University professors and students
Course Format:
5 days
40% lecture - 60% workshop
Course Content:
Create parts and organize them into mechanical systems
Connect parts with ideal constraints, such as:
standard joints (hinges, sliders, etc.)
joint primitives
complex (couplers, screw, etc.)
curve (cam-follower, pin-in-slot)
Actuate a system with:
ideal and complex part motion
applied forces
gravity
Connect parts with more realistic forces:
simple (springs, dampers, etc.)
complex based on system states (displacements, velocities, etc.)
complex based on test data
contacts and collisions
Measure quantities of interest (displacements, velocities, accelerations, applied loads, forces)
Perform static, transient, and linear simulations
Precisely control and manage your simulations
Investigate test results via animations and plots
Manage files generated and used by ADAMS/View and ADAMS/Solver
"Putting it all together" to complete a comprehensive workshop that tests comprehension of modeling elements and techniques discussed in class
Additional topics discussed are:
importing CAD-based geometry
performing cam synthesis
applying joint friction
performing design studies
applying sensors to your system
Prerequisites: none
发表于 2006-7-28 12:15 | 显示全部楼层
逆水行舟,有恶意灌水,回复的内容空洞~~
发表于 2006-8-14 22:00 | 显示全部楼层
都是英文的?
明明上面是MSC的英文网站,你反问是英文的,难道不是明知故问啊??
[ 本帖最后由 雅马哈 于 2006-8-15 08:18 编辑 ]
发表于 2006-8-19 16:20 | 显示全部楼层
好像现在的链接不对啊,是不是官方已经更换网址了,还是删除了?
发表于 2006-8-25 10:05 | 显示全部楼层
怎么打开不对啊,显示错误?
发表于 2006-8-31 00:47 | 显示全部楼层
就是啊,打不开
发表于 2006-8-31 01:35 | 显示全部楼层
看了这个帖子,本来是yejet兄给大家一个很好的连接资源,所以请回帖的兄弟注意,不要恶意灌水。
发表于 2006-10-28 20:57 | 显示全部楼层
是啊在给一个连接吧
发表于 2006-10-30 11:32 | 显示全部楼层
上面的连接不上可以试试这个连接http://www.mscsoftware.com/suppo ... book_references.cfm
发表于 2006-11-23 10:47 | 显示全部楼层
可以了,但都是英文,累啊!
发表于 2006-12-5 11:33 | 显示全部楼层
谢谢楼主,资料很全
发表于 2007-6-5 18:01 | 显示全部楼层
多多学习
GMT+8, 2024-11-17 18:36 , Processed in 0.078193 second(s), 23 queries , Gzip On.
