楼主: 猴王
[小波] 请各位对照我师兄的论文看看我的程序
 楼主| 发表于 2007-7-10 11:16 | 显示全部楼层
回复 #46 zhlong 的帖子
是采样频率的问题,我的0.005,你的0.001,我做出来了,但现在的问题还是,为什么在5秒出的损伤却出现在5秒之前的那个位置呢?
[ 本帖最后由 zhlong 于 2007-7-10 13:35 编辑 ]
发表于 2007-7-10 11:23 | 显示全部楼层
回复 #47 猴王 的帖子
换别的小波试试看
发表于 2007-7-10 14:20 | 显示全部楼层
现在这个答案应该比较完整了,不用ode45,改用定步长的4阶龙格库塔法积分,即下面贴的ode4。
function Y = ode4(odefun,tspan,y0,varargin)
%ODE4 Solve differential equations with a non-adaptive method of order 4.
% Y = ODE4(ODEFUN,TSPAN,Y0) with TSPAN = [T1, T2, T3, ... TN] integrates
% the system of differential equations y' = f(t,y) by stepping from T0 to
% T1 to TN. Function ODEFUN(T,Y) must return f(t,y) in a column vector.
% The vector Y0 is the initial conditions at T0. Each row in the solution
% array Y corresponds to a time specified in TSPAN.
% Y = ODE4(ODEFUN,TSPAN,Y0,P1,P2...) passes the additional parameters
% P1,P2... to the derivative function as ODEFUN(T,Y,P1,P2...).
% This is a non-adaptive solver. The step sequence is determined by TSPAN
% but the derivative function ODEFUN is evaluated multiple times per step.
% The solver implements the classical Runge-Kutta method of order 4.
% Example
% tspan = 0:0.1:20;
% y = ode4(@vdp1,tspan,[2 0]);
% plot(tspan,y(:,1));
% solves the system y' = vdp1(t,y) with a constant step size of 0.1,
% and plots the first component of the solution.
if ~isnumeric(tspan)
error('TSPAN should be a vector of integration steps.');
if ~isnumeric(y0)
error('Y0 should be a vector of initial conditions.');
h = diff(tspan);
if any(sign(h(1))*h <= 0)
error('Entries of TSPAN are not in order.')
try
f0 = feval(odefun,tspan(1),y0,varargin{:});
catch
msg = ['Unable to evaluate the ODEFUN at t0,y0. ',lasterr];
error(msg);
y0 = y0(:); % Make a column vector.
if ~isequal(size(y0),size(f0))
error('Inconsistent sizes of Y0 and f(t0,y0).');
neq = length(y0);
N = length(tspan);
Y = zeros(neq,N);
F = zeros(neq,4);
Y(:,1) = y0;
for i = 2:N
ti = tspan(i-1);
hi = h(i-1);
yi = Y(:,i-1);
F(:,1) = feval(odefun,ti,yi,varargin{:});
F(:,2) = feval(odefun,ti+0.5*hi,yi+0.5*hi*F(:,1),varargin{:});
F(:,3) = feval(odefun,ti+0.5*hi,yi+0.5*hi*F(:,2),varargin{:});
F(:,4) = feval(odefun,tspan(i),yi+hi*F(:,3),varargin{:});
Y(:,i) = yi + (hi/6)*(F(:,1) + 2*F(:,2) + 2*F(:,3) + F(:,4));
Y = Y.';
结构的动力学方程函数
  function xdot=danziyoudukuangjia(t,x)
  M=31.2;
  if(t<5)
     K=67.51*10^5;
  else
     K=67.51*10^5*0.95;
C=1.4*10^3;
xdot=[x(2);(1/M)*(F-C*x(2)-K*x(1))];
信噪比计算
  ss=sum(y1.^2);
nn=sum((y2).^2);
snr=10*log10((ss/nn))
主程序
t0=0.001;
te=10;
dt=0.001;%采样间隔
t=[t0:dt:te]';
x0=[0,0];
[x]=ode4('danziyoudukuangjia',t,x0);
d=x(:,1);
v=x(:,2);
s1=(diff(v(1:end-1))+diff(v(2:end)))/2;  %中心差分法
s1=[diff(v(1:2));s1;diff(v(end-1:end))]; %少的两个点用前向和后向差分法补齐
s1=s1/dt; %近似为导数
figure;set(gcf,'Color','W')
subplot(311);plot(t,d); title('位移')
subplot(312);plot(t,v); title('速度')
subplot(313);plot(t,s1); title('加速度')
y1=s1(150:end);%去掉信号前面一部分的瞬态成份
y2=0.005*randn(size(y1));%添加噪声
s=y1+y2;
%下面进行离散的单尺度小波变换并生成,各尺度上的信号
[c,l]=wavedec(s,5,'bior6.8');%对第一信号进行3尺度一维离散小波分解,采用墨西哥小帽函数
%提取结构的低频和高频信号
ca3=appcoef(c,l,'bior6.8',5);%提取第三尺度系数的低频
[cd1,cd2,cd3,cd4,cd5]=detcoef(c,l,[1,2,3,4,5]);%提取第一、二、三尺度系数的高频
%重构信号的低频和高频部分
a3=wrcoef('a',c,l,'bior6.8',3);
d1=wrcoef('d',c,l,'bior6.8',1);
d2=wrcoef('d',c,l,'bior6.8',2);
d3=wrcoef('d',c,l,'bior6.8',3);
d4=wrcoef('d',c,l,'bior6.8',4);
d5=wrcoef('d',c,l,'bior6.8',5);
%显示多尺度一维信号的分解结果
subplot(611);plot(t(150:end),a3);title('信号的低频细节部分');%AXIS([0 60 -5 5]);
subplot(612);plot(t(150:end),d1);title('Detailsd1');%AXIS([0 60 -5 5]);
subplot(613);plot(t(150:end),d2);title('Detailsd2');%AXIS([0 60 -5 5]);
subplot(614);plot(t(150:end),d3);title('Detailsd3');%AXIS([0 60 -5 5]);
subplot(615);plot(t(150:end),d4);title('Detailsd4');%AXIS([0 60 -5 5]);
subplot(616);plot(t(150:end),d5);title('Detailsd5');%AXIS([0 60 -5 5]);
这是得到的位移、速度、加速度:
这是噪声为0.005*randn(size(y1)),信噪比约13db时的小波分解图和EMD分解结果:
这是完全无噪声的分解情况:
[ 本帖最后由 zhlong 于 2007-7-10 14:57 编辑 ]
发表于 2007-7-10 16:03 | 显示全部楼层
回复 #50 猴王 的帖子
小波函数没改,只是将变步长积分改为了定步长积分。
不用客气,欢迎常来论坛。
[ 本帖最后由 zhlong 于 2007-7-10 16:12 编辑 ]
发表于 2007-7-10 16:37 | 显示全部楼层
这个积分程序不错,收藏了。
 楼主| 发表于 2007-7-12 20:21 | 显示全部楼层
回复 #51 zhlong 的帖子
请问,为什么我把损伤时刻改到30s的时候,损伤就是别出不来了呢,我只是把损伤的时刻,和采样频率改变了,损伤就看不出来了,而且还出现在5s时刻,这是不是也是因为m,k,c这几个系数阿
  F=20*sin(25*t+14);
  M=31.2;
  if(t<30)
     K=67.51*10^5;
  else
     K=67.51*10^5*0.95;
C=1.4*10^3;
close all;
t0=0.001;
te=60;
dt=0.005;%采样间隔
t=[t0:dt:te]';
x0=[0,0];
d=x(:,1);
v=x(:,2);
s1=s1/dt; %近似为导数
s=y1+y2;
ss=sum(y1.^2);
nn=sum((y2).^2);
%提取结构的低频和高频信号
%重构信号的低频和高频部分
%显示多尺度一维信号的分解结果
 楼主| 发表于 2007-7-12 20:34 | 显示全部楼层
损伤时刻改为30秒,出现问题!!!
发表于 2015-12-9 16:38 | 显示全部楼层
学习一下
GMT+8, 2025-7-28 14:06 , Processed in 0.067037 second(s), 19 queries , Gzip On.
