查看: 2150|回复: 5
[编程技巧] 如何用改进欧拉方法求解
发表于 2007-6-30 17:04 | 显示全部楼层 |阅读模式
求解:
dy/dx=y+2*x/y^2  y(0)=1 x∈[0,2]
怎么用改进欧拉的方法编写程序啊???步长要求等于0。1
还要能画出图。。
哪位高手能帮帮忙啊,我要做报告。。
发表于 2007-6-30 17:07 | 显示全部楼层
建议看看数值分析的书, 这是很基础的作业.
你也可以搜索一下论坛.
 楼主| 发表于 2007-6-30 17:12 | 显示全部楼层
就是找不到。。。
发表于 2007-7-2 15:12 | 显示全部楼层
  1. function w = ieulerf(f,t,u,h)
  2. %
  3. %  v = ieulerf(f,t,u,h)
  4. %
  5. %  Computes one step of Improved Euler method for solving a first order ODE
  6. %
  7. % Input arguments:
  8. %
  9. %   f  - string name of function on right hand side of ODE: u' = f(t,u)
  10. %   t  - current time
  11. %   u  - current value of solution
  12. %   h  - step size
  13. %
  14. % Output:
  15. %
  16. %   v  - updated value of solution
  17. %
  18. % See also NUMODE, NEULER, MIDP, IEULER, RK4, NEULERF, MIDPF, RK4F
  19. %
  20. g = feval(f,t,u);
  21. v = u + h*g;
  22. w = u + h*(g + feval(f,t+h,v))/2;
发表于 2007-7-2 15:13 | 显示全部楼层
  1. function [tz,uz] = ieuler(f,t0,u0,tf,h,c)
  2. %
  3. %  [tz,uz] = ieuler(f,t0,u0,tf,h,c)
  4. %
  5. %  Uses Improved Euler method to solve a first order ODE
  6. %    Plots components of solution in Figure #1
  7. %    In 2-D case, also plots phase plane trajectory in Figure #2
  8. %
  9. % Input arguments:
  10. %
  11. %   f  - string name of function on right hand side of ODE: u' = f(t,u)
  12. %            note: f must return a column vector
  13. %   t0 - initial time
  14. %   u0 - initial data u(t0) --- column vector
  15. %   tf - final time or, if vector, list of times to evaluate solution.
  16. %   h  - step size
  17. %
  18. % Optional arguments:
  19. %
  20. %   c  - color for plot
  21. %
  22. % Output:
  23. %
  24. %   tz - times for evaluation of function as specified by tf, or,
  25. %        if tf is a scalar, all mesh points
  26. %   uz - value of solution at times tz.
  27. %
  28. % See also NUMODE, NEULER, MIDP, RK4, NEULERF, IEULERF, MIDPF, RK4F
  29. %
  30. [tz,uz] = numode('ieulerf',f,t0,u0,tf,h,c);
 楼主| 发表于 2007-7-2 15:38 | 显示全部楼层
xnp=0:.1:2;
y21=1;
ynp=[];
for i=1:length(xnp)-1
    y04=y21+diff(xnp([1:2]))*(y21-2*xnp(i)/y21^2);
    ynp=[ynp;y21+.5*diff(xnp([1:2]))*(y21-2*xnp(i)/y21^2+y04-2*xnp(i+1)/y04^2)];
    y21=ynp(end);
ynp
我自己写好了。。但是问题是怎么把图象显示出来?谁会啊???我输入一直显示
指数超过矩阵尺寸.
GMT+8, 2024-10-3 02:15 , Processed in 0.065920 second(s), 18 queries , Gzip On.
