查看: 1442|回复: 0
[前后处理] 24种材料属性实例
发表于 2007-6-29 02:27 | 显示全部楼层 |阅读模式
Isotropic Elastic: High Carbon Steel
MPMOD,1,1
MP,ex,1,210e9  ! Pa
MP,nuxy,1,.29  ! No units
MP,dens,1,7850  ! kg/m3
Orthotropic Elastic: Al203
MPMOD,1,2
MP,ex,1,307e9  ! Pa
MP,ey,1,358.1e9  ! Pa
MP,ez,1,358.1e9  ! Pa
MP,gxy,126.9e9  ! Pa
MP,gxz,126.9e9  ! Pa
MP,gyz,126.9e9  ! Pa
MP,nuxy,1,.20  ! No units
MP,nuxz,1,.20  ! No units
MP,nuyz,1,.20  ! No units
MP,dens,1,3750  ! kg/m3
Anisotropic Elastic: Cadmium
MPMOD,1,3
MP,dens,3400  ! kg/m3
TB,ANEL,1
TBDATA,1,121.0e9  ! C11 (Pa)
TBDATA,2,48.1e9  ! C12 (Pa)
TBDATA,3,121.0e9  ! C22 (Pa)
TBDATA,4,44.2e9  ! C13 (Pa)
TBDATA,5,44.2e9  ! C23 (Pa)
TBDATA,6,51.3e9  ! C33 (Pa)
TBDATA,10,18.5  ! C44 (Pa)
TBDATA,15,18.5  ! C55 (Pa)
TBDATA,21,24.2  ! C66 (Pa)
Blatz-Ko: Rubber
MPMOD,1,5
MP,gxy,1,104e7  ! Pa
Mooney-Rivlin: Rubber
MPMOD,1,8
MP,dens,1,.0018  ! lb/in3
MP,nuxy,1,.499  ! No units
TB,MOONEY,1
TBDATA,1,80  ! C10 (psi)
TBDATA,2,20  ! C01 (psi)
Viscoelastic: G-11 Glass
MPMOD,1,18
MP,dens,1,2390  ! kg/m3
TB,EVISC,1
TBDATA,46,27.4e9  ! Go (Pa)
TBDATA,47,0.0  ! (Pa)
TBDATA,48,60.5e9  ! Bulk modulus (Pa)
TBDATA,61,.53  ! 1/
Bilinear Isotropic Plasticity: Nickel Alloy
MPMOD,1,6
MP,ex,1,180e9  ! Pa
MP,nuxy,1,.31  ! No units
MP,dens,1,8490  ! kg/m3
TB,BISO,1
TBDATA,1,900e6  ! Yield stress (Pa)
TBDATA,2,445e6  ! Tangent modulus (Pa)
Transversely Anisotropic Elastic Plastic: 1010 Steel
MPMOD,1,10
MP,ex,1,207e9  ! Pa
MP,dens,1,7845  ! kg/m3
TB,PLAW,,,,7
TBDATA,1,128.5e6  ! Yield stress (Pa)
TBDATA,2,202e5  ! Initial strain at failure
TBDATA,3,1.41  ! r-value
TBDATA,4,1  ! Yield stress vs. plastic strain curve (see EDCURVE below)
Strain(1) = 0,.05,.1,.15,.2
YldStres(1)=207e6,210e6,214e6,218e6,220e6 ! yield stress
EDCURVE,ADD,1,Strain (1),YldStres(1)
Rate Sensitive Powerlaw Plasticity: A356 Aluminum
MPMOD,1,17
MP,ex,1,75e9  ! Pa
MP,nuxy,1,.33  ! No units
MP,dens,1,2750  ! kg/m3
TB,PLAW,,,,4
TBDATA,1,1.002  ! k (MPa)
TBDATA,2,.7  ! m
TBDATA,3,.32  ! n
TBDATA,4,5.0  ! Initial strain rate (s-1)
Plastic Kinematic: 1018 Steel
MPMOD,1,19
MP,ex,1,200e9  ! Pa
MP,nuxy,1,.27  ! No units
MP,dens,1,7865  ! kg/m3
TB,PLAW,,,,1
TBDATA,1,310e6  ! Yield stress (Pa)
TBDATA,2,763e6  ! Tangent modulus (Pa)
TBDATA,4,40.0  ! C (s-1)
TBDATA,5,5.0  ! P
TBDATA,6,.75  ! Failure strain
Bilinear Kinematic Plasticity: Titanium Alloy
MPMOD,1,33
MP,ex,1,100e9  ! Pa
MP,nuxy,1,.36  ! No units
MP,dens,1,4650  ! kg/m3
TB,BKIN,1
TBDATA,1,70e6  ! Yield stress (Pa)
TBDATA,2,112e6  ! Tangent modulus (Pa)
Powerlaw Plasticity: Aluminum 1100
MPMOD,1,21
MP,ex,1,69e9  ! Pa
MP,dens,1,2710  ! kg/m3
TB,PLAW,,,,2
TBDATA,1,0.598  ! k
TBDATA,2,0.216  ! n
TBDATA,3,6500.0  ! C (s-1)
TBDATA,4,4.0  ! P
3 Parameter Barlat Plasticity: Aluminum 5182
MPMOD,1,22
MP,ex,1,76e9  ! Pa
MP,nuxy,1,.34  ! No units
MP,dens,1,2720  ! kg/m3
TB,PLAW,,,,3
TBDATA,1,1  ! Hardening rule of 1 (yield stress)
TBDATA,2,25e6  ! Tangent modulus (Pa)
TBDATA,3,145e6  ! Yield stress (Pa)
TBDATA,4,0.170  ! Barlat exponent, m
TBDATA,5, .73  ! R00
TBDATA,6,.68  ! R45
TBDATA,7,.65  ! R90
TBDATA,8,0  ! CSID
Barlat Anisotropic Plasticity: 2008-T4 Aluminum
MPMOD,1,23
MP,ex,1,76e9  ! Pa
TB,PLAW,,,,6
TBDATA,1,1.04  ! k (MPa)
TBDATA,2,.65  ! Initial strain at failure
TBDATA,3,.254  ! n
TBDATA,4,11  ! Barlat exponent, m
TBDATA,5, 1.017  ! a
TBDATA,6,1.023  ! b
TBDATA,7,.9761  ! c
TBDATA,8,.9861  ! f
TBDATA,9,.9861  ! g
TBDATA,9,.8875  ! h
Strain Rate Dependent Plasticity: 4140 Steel
MPMOD,1,24
MP,ex,1,209e9  ! Pa
TB,PLAW,,,,5
TBDATA,1,1  ! LCID yield stress vs. strain rate (see first EDCURVE command below)
TBDATA,2,22e5  ! Tangent modulus (Pa)
TBDATA,3,2  ! LCID Elastic modulus vs. strain rate (see second EDCURVE command below)
StrnRate(1) = 0,.08,.16,.4,1.0
YldStres(1) = 207e6,250e6,275e6,290e6,300e6
ElasMod(1) = 209e9,211e9,212e9,215e9,218e9
EDCURVE,ADD,1,StrnRate(1),YldStres(1)
EDCURVE,ADD,2,StrnRate(1),ElasMod(1)
Piecewise Linear Plasticity: High Carbon Steel
MPMOD,1,28
MP,ex,1,207e9  ! Pa
MP,nuxy,1,.30  ! No units
MP,dens,1,7830  ! kg/m3
TB,PLAW,,,,8
TBDATA,1,207e6  ! Yield stress (Pa)
TBDATA,3,.75  ! Failure strain
TBDATA,4,40.0  ! C (strain rate parameter)
TBDATA,5,5.0  ! P (strain rate parameter)
TBDATA,6,1  ! LCID for true stress vs. true strain (see EDCURVE below)
TruStran(1)=0,.08,.16,.4,.75
TruStres(1)=207e6,250e6,275e6,290e6,3000e6
EDCURVE,ADD,1,TruStran (1),TruStres(1)
Johnson-Cook Linear Polynomial EOS: 1006 Steel
MPMOD,1,30
MP,ex,1,207e9  ! Pa
TB,EOS,1,,,1,1
TBDATA,1,350.25e6  ! A (Pa)
TBDATA,2,275e6  ! B (Pa)
TBDATA,3,.36  ! n
TBDATA,4,.022  ! c
TBDATA,5,1.0  ! m
TBDATA,6,1400  ! Melt temperature (oC)
TBDATA,7,30  ! Room temperature (oC)
TBDATA,8,10  ! Initial strain rate
TBDATA,9,4500  ! Specific heat
TBDATA,10,240e6  ! Failure stress
TBDATA,11,-.8  ! Failure value D1
TBDATA,12,2.1  ! Failure value D2
TBDATA,13,-.5  ! Failure value D3
TBDATA,14,.0002  ! Failure value D4
TBDATA,15,.61  ! Failure value D5
TBDATA,17,20e5  ! EOS linear polynomial term
Johnson-Cook Gruneisen EOS: OFHC Copper
MPMOD,1,31
MP,ex,1,138e9  ! Pa
MP,nuxy,1,.35  ! No units
MP,dens,1,8330  ! kg/m3
TB,EOS,1,,,1,2
TBDATA,1,89.63e6  ! A (Pa)
TBDATA,2,291.64e6  ! B (Pa)
TBDATA,3,.31  ! n
TBDATA,4,.025  ! c
TBDATA,5,1.09  ! m
TBDATA,6,1200  ! Melt temperature (oC)
TBDATA,9,4400  ! Specific heat
TBDATA,11,-.54  ! Failure value D1
TBDATA,12,4.89  ! Failure value D2
TBDATA,13,-3.03  ! Failure value D3
TBDATA,14,.014  ! Failure value D4
TBDATA,15,1.12  ! Failure value D5
TBDATA,16,.394  ! C
TBDATA,17,1.489  ! S1
TBDATA,18,0.0  ! S2
TBDATA,19,0.0  ! S3
TBDATA,20,2.02  ! 0
TBDATA,21,.47  ! A
Null Material Linear Polynomial EOS: Brass
MPMOD,1,32
MP,ex,1,200e9  ! Pa
MP,nuxy,1,.3  ! No units
MP,dens,1,7500  ! kg/m3
TB,EOS,1,,,2,1
TBDATA,1,0.0  ! Pressure cut-off
TBDATA,3,1.5  ! Relative volume in tension
TBDATA,4,.7  ! Relative volume in compression
TBDATA,17,16e5  ! EOS linear polynomial
Null Material Gruneisen EOS: Aluminum
MPMOD,1,29
MP,ex,1,100e9  ! Pa
MP,dens,1,2500  ! kg/m3
TB,EOS,1,,,2,2
TBDATA,1,-10000  ! Pressure cut-off (Pa)
TBDATA,3,2.0  ! Relative volume in tension
TBDATA,4,.5  ! Relative volume in compression
TBDATA,16,.5386  ! C
TBDATA,17,1.339  ! S1
TBDATA,18,0.0  ! S2
TBDATA,19,0.0  ! S3
TBDATA,20,1.97  ! 0
TBDATA,21,.48  ! A
Rigid Material: Steel
MPMOD,1,7
MP,ex,1,207e9  ! Pa
MP,dens,1,7580  ! kg/m3
EDMP,rigid,1,7,7
Cable Material: Steel
MPMOD,1,27
MP,ex,1,207e9  ! Pa
EDMP,cable,1,1  ! See EDCURVE below
EngStran(1) = .02,.04,.06,.08
EngStres(1) = 207e6,210e6,215e6,220e6
EDCURVE,ADD,1,EngStran (1),EngStres(1)
Transversely Anisotropic FLD: Stainless Steel
MPMOD,1,54
MP,ex,1,30e6  ! Pa
MP,dens,1,.00285  ! kg/m3
TB,PLAW,1,,,10
TBDATA,1,20e3  ! Initial yield stress (Pa)
TBDATA,2,5000  ! Tangent modulus (Pa)
TBDATA,3,.2  ! Hardening parameter
TBDATA,5,1  ! Maximum yield stress curve (see EDCURVE below)
mnstrn(1) = -30,-10,0,20,40,50
mjstrn(1) = 80,40,29,39,45,44
EDCURVE,ADD,1,mnstrn (1),mjstrn(1)
Steinberg Gruneisen EOS: Stainless Steel
MPMOD,1,52
MP,gxy,1,11.16e6  ! (Pa)
MP,dens,1,.285  ! (kg/m3)
TB,EOS,1,,,5,2
TBDATA,1,49.3e3  ! Initial yield stress (Pa)
TBDATA,2,43  ! Hardening coefficient
TBDATA,3,.35  ! n
TBDATA,5,.36e6  ! Maximum yield stress (Pa)
TBDATA,10,32  ! Atomic weight
TBDATA,11,2380  ! Absolute melting temp.
TBDATA,15,2  ! Spall type
TBDATA,16,1  ! Cold compression energy flag
TBDATA,17,-50  ! Min. temp. parameter
TBDATA,18,200  ! Max. temp. parameter
TBDATA,29,.457  ! C
TBDATA,30,1.49  ! S1
TBDATA,31,0.0  ! S2
TBDATA,32,0.0  ! S3
TBDATA,33,1.93  ! 0
TBDATA,34,1.4  ! A
perry你好,谢谢你的提供。我另有一关于压电矩阵的输入问题请教。
三维压电矩阵的输入方法是:
MP,DENS,4,7700 ! Density of piezoceramic (kg/m**3)
MP,PERX,4,6.45E-9 ! Permittivity of piezoceramic (F/m)
MP,PERY,4,5.62E-9
MP,PERZ,4,6.45E-9 ! used in 3-D analysis
           ! 3-D Analysis
TB,PIEZ,4 ! Piezoelectric "e" matrix of piezoceramic TBDATA,2,-5.2 ! e31 ! (C/m^2)
TBDATA,5,15.1 ! e33
TBDATA,8,-5.2 !e31
TBDATA,10,12.7 ! e15
TBDATA,15,12.7 ! e15
TB,ANEL,4 ! Stiffness "c" matrix of piezoceramic
TBDATA,1,13.9E10,7.78E10,7.43E10 ! (N/m^2)
TBDATA,7,13.9E10,7.43E10
TBDATA,12,11.5E10
TBDATA,16,2.56E10
TBDATA,19,2.56E10
TBDATA,21,3.06E10
按照帮助文件的说法,将C矩阵变为4X4阵,E阵变为4X2阵即为二维压电矩阵,但我一直高不清 TBDATA,?,value中取值的初始序号怎样填写。请看我下面的输入对否?
TB,PIEZ,4 ! Piezoelectric "e" matrix of piezoceramic 2-D Analysis
TBDATA,2,-5.2,0,0,15.1 ! e12,e22 ! (C/m^2)
TBDATA,8,-5.2,0,12.7 ! e32,e41
TBDATA,12,11.5E10
TBDATA,16,2.56E10
望不吝赐教。在线盼复!
GMT+8, 2024-10-2 22:18 , Processed in 0.057777 second(s), 18 queries , Gzip On.
