查看: 2321|回复: 2
[前后处理] 关于网格的细划加密问题
发表于 2007-6-28 13:32 | 显示全部楼层 |阅读模式
网格局部细划的命令apdl怎么使用?
发表于 2007-6-28 13:56 | 显示全部楼层
8.1.1. How to Refine a Mesh
You must follow these two steps to refine a mesh:
1.Select the entity (or set of entities) around which refinement will be done.
2.Specify the level of refinement to be done (in other words, the desired size of the elements in the refinement region, relative to the size of the original elements). The refined elements will always be smaller than the original elements; the local mesh refinement process does not provide mesh coarsening (LEVEL).
发表于 2007-6-28 13:58 | 显示全部楼层
具体的命令是EREFINE、AREFINE、LREFINE、KREFINE、NREFINE
GMT+8, 2024-10-2 22:28 , Processed in 0.049932 second(s), 18 queries , Gzip On.
