查看: 3163|回复: 5
[AutoCAD] 三种曲线的画法,LISP语言
发表于 2007-6-5 08:33 | 显示全部楼层 |阅读模式
  1. ;画正弦曲:x=a , y=sin a ;
  2. (defun c:zxqx(/ da bp Ai lpt bp1 bp2)
  3. (initget 1)
  4. (setq bp (getpoint "\n 起始点?:"))
  5. (initget 7)
  6. (setq da (getangle "\n 角度增量?:"))
  7. (setq Ai 0 Ae (* pi 2.0) bp1 (car bp) bp2 (car (cdr bp)))
  8. (while (< Ai Ae)
  9. (setq lpt (append lpt (list (list (+ bp1 Ai) (+ bp2 (sin Ai))))))
  10. (setq Ai (+ Ai da))
  11. )
  12. (setq lpt (append lpt (list (list (+ bp1 Ae) (+ bp2 (sin Ae))))))
  13. (setvar "cmdecho" 0)
  14. (command "pline")
  15. (foreach pt lpt (command pt))
  16. (command ^c)
  17. (command "pedit" "l" "f")
  18. (command ^c)
  19. (setvar "cmdecho" 1)
  20. )
 楼主| 发表于 2007-6-5 08:34 | 显示全部楼层
  1. ;渐开线画法x=br*(cos(a)+a*sin(a))
  2. y=br*(sin(a)-a*cos(a));
  3. (defun c:jkx(/ ti lpt ae pt bp1 bp2)
  4. (initget 1)
  5. (setq bp (getpoint "\n 起始点?:"))
  6. (initget 7)
  7. (setq br (getreal "\n 基圆半径?:"))
  8. (initget 5)
  9. (setq ai (getangle "\n 起始角度?:"))
  10. (initget 7)
  11. (setq ae (getangle "\n 终止角度?:"))
  12. (initget 7)
  13. (setq da (getangle "\n 角度增量?:"))
  14. (setq bp1 (car bp) bp2 (car (cdr bp)))
  15. (while (< ai ae)
  16. (setq lpt (append lpt (list (list (+ bp1 (* br (+ (cos ai) (* ai (sin ai))))) (+ bp2 (* br (- (sin ai) (* ai (cos ai)))))))))
  17. (setq ai (+ ai da))
  18. )
  19. (setq lpt (append lpt (list (list (+ bp1 (* br (+ (cos ae) (* ae (sin ae))))) (+ bp2 (* br (- (sin ae) (* ae (cos ae)))))))))
  20. (setvar "cmdecho" 0)
  21. (command "pline")
  22. (foreach pt lpt (command pt))
  23. (command ^c)
  24. (command "pedit" "l" "f")
  25. (command ^c)
  26. (setvar "cmdecho" 1)
  27. )
 楼主| 发表于 2007-6-5 08:35 | 显示全部楼层
螺旋线画法:x=r*cos(2pi/k) , y=r*sin(2pi/k) , z=(+/-)s/k .
  1. ; s:导程(+=右旋,-=左旋),k:每圈等分数。
  2. (defun c:yzlxx(/ bp r a s k n bp1 bp2 bp3 dmax di da pt lpt)
  3. (initget 1)
  4. (setq bp (getpoint "\n 螺旋线中心:"))
  5. (initget 7)
  6. (setq r (getdist bp "\n 螺旋线半径:"))
  7. (initget 3)
  8. (setq s (getreal "\n 导程:(+/右旋,-/左旋)"))
  9. (initget 7)
  10. (setq n (getreal "\n 圈数:"))
  11. (initget 6)
  12. (setq k (getint "\n 每圈等分数<36>:(宜取36的整倍数)"))
  13. (if (not k) (setq k 36))
  14. (setq bp1 (car bp) bp2 (cadr bp) bp3 (caddr bp))
  15. (setq dmax (fix(* k n)))
  16. (setq da (/(* 2 pi) k))
  17. (setq a 0)
  18. (setq di 0)
  19. (while (<= di dmax)
  20. (setq lpt (append lpt (list (list (+ bp1 (* r (cos a))) (+ bp2 (* r (sin a))) (+ bp3 (* (/ s k) di))))))
  21. (setq di (+ di 1))
  22. (setq a (+ da a))
  23. )
  24. (setvar "cmdecho" 0)
  25. (command "3dpoly")
  26. (foreach pt lpt (command pt))
  27. (command ^c)
  28. (setvar "cmdecho" 1)
  29. )
发表于 2007-6-16 14:22 | 显示全部楼层
楼主~您这贴确实值得顶一下~
发表于 2007-7-16 16:51 | 显示全部楼层
好东西!!
发表于 2009-6-21 17:06 | 显示全部楼层
请教楼主一个问题,如何将一张图中所有直线的端点坐标导出到EXCEL中呢
GMT+8, 2025-7-11 11:31 , Processed in 0.081852 second(s), 18 queries , Gzip On.
