查看: 3507|回复: 6
[Hyperworks] Hypermesh菜单上的关键字释意(按字母排序)
发表于 2007-6-2 08:15 | 显示全部楼层 |阅读模式
HyperMesh Panels Listed Alphabetically
accels  Creates or updates accelerations.
align node  Projects nodes to an imaginary line passing through two nodes.
animation subpanel  Allows you to control the display of your model during animation.
apply result  Applies a displacement result to the nodes.
assemblies  Creates collections of components.
automesh  Interactively or automatically creates meshes on surfaces.
automeshing module   A subpanel for most of the plate and shell meshing operations that allows you to work interactively on mesh parameters.
axis labels  Edits axis label information.
axis scaling  Modifies plot axes.
bars  Creates or updates bar2 or bar3 elements.
beam xsect   Calculates beam section properties
border  Edits the border of an XY plot.
build menu  Redefines the layout of the HyperMesh menu system.
card  Allows you to select the entities that are viewed in the card image panel.
check elems  Verifies the quality of elements. Checks warp, aspect, skew, angles, length, jacobian, connectivity, and duplicates.
circles  Creates circles and arcs.
cntl card   Allows you to edit solver specific data on a set of entities.
collectors  Creates components that group data together.
color   Modifies the color attributes of collectors.
colors subpanel   Located on the options panel; controls user-interface colors.
command subpanel   Located on the files panel; executes a HyperMesh command file.
composites   Aligns the element material angle of a mesh of shell elements and allows you to review material angle and ply directions.
cones  Creates a surface or mesh for cones or cylinders.
config edit  Changes the configuration of existing elements.
constraints  Creates or updates constraints or enforced displacements on nodes.
constr screen   Defines data for truncation threshold and maximum number of constraints to be retained per region, per load case for a given response type.
contour   Creates contour or assignment plots of results.
control vol   Creates control volumes.
convert   Allows you to exchange some data between different solver formats
count  Sums the entities in the database.
create nodes   Creates nodes by specifying the x, y, z coordinates, picking on existing geometry, on line, or between nodes.
curve attribs  Creates and edits curves.
dconstraints   Allows you to create constraints for optimization problems.
defeature   Removes surface features.
deformed  Creates deformed plot based on displacement results.
delete  Deletes data from the database.
dependency  Finds nodes that have multiple DOF constraints.
dequations   Allows you to create user-defined functions for constraints and/or objective functions.
desvar link   Allows you to link a design variable to other design variables.
detach  Detaches elements from adjoining elements.
display  Turns collectors on and off for viewing.
distance  Finds the distance or angle between nodes.
drag  Creates a surface or mesh by dragging nodes, lines, or elements.
dummy   Allows you to rotate the dummy assemblies or specify the position of the H-Point of a dummy assembly.
edges  Finds free edges and equivalences nodes on edges.
edit curves  Creates or edits new or existing curves from files or math expressions.
edit element  Builds, combines, and splits elements.
elem offset   Creates solid elements or layers of plate or shell elements based on a plate or shell element by offsetting the shell elements in a direction normal to the surface they form.
elem types  Selects and changes existing element types.
ellipsoids   Creates and modifies single or multiple ellipsoids and cylinders.
entity sets   Creates sets of nodes or elements.
equations   Creates, reviews, and updates equations.
export subpanel   Exports HyperMesh data to solver input formats.
faces  Finds free faces and equivalences nodes on surfaces.
fatigue   Allows you to write stress/strain results from finite element analysis to an external file that can be used to set up fatigue analysis in a supported fatigue solver.
 楼主| 发表于 2007-6-2 08:16 | 显示全部楼层
fd blocks  Provides access to the Finite Difference menu panel.
features  Displays the edges of a model as one-dimensional plot elements, providing a visualization tool to see the edges of a complex model.
fe joints   Creates, reviews, or updates joints.
files  Subpanels allow you to save and retrieve files, import and export data, specify templates and results files, and run command files.
fillets  Creates or deletes fillets between two lines.
find  Finds entities (and IDs) in the database.
flux  Creates or updates flux loading to nodes.
forces  Creates or updates forces.
gaps  Creates or updates gap elements.
gauge   Creates a single design variable (DESVAR) and multiple property relation (DVPREL1) cards for the components selected for size optimization.
geom cleanup   Contains tools to help you prepare surface geometry for meshing.
global   Specifies the template file, current component, element order and size.
graphics subpanel   Determines the current graphics engine: standard or performance.
grid attribs  Edits grid information.
grid labels  Edits grid label information.
hidden line  Creates hidden line and shaded image plots of elements.
hyperbeam   Defines beam section entities before entering the HyperBeam module.
import subpanel   Imports data to HyperMesh.
integrate  Allows you to integrate a curve.
interfaces  Creates and modifies interfaces that define a contact or sliding surface.
intersect  Creates a line or lines where a plane intersects with a finite element model.
legend  Edits the plot legend.
length  Determines the length of a group of selected lines.
line drag  Creates a surface or mesh by dragging nodes, lines, or elements along a line.
line edit  Combines lines, splits lines at a point, at a joint, at a line, or at a plane, and smoothes lines.
line mesh   Creates 1-D elements between nodes or along a line.
linear 1d   Creates one-dimensional plot elements.
linear solid  Creates solid elements between two groups of plate elements.
lines  Creates lines by picking nodes.
load steps   Allows you to create and update collections of load collectors.
load types  Selects load types for new models or updates load types as defined in a template file.
mask  Masks entities from the display list.
mass calc  Obtains the mass, area, and volume of selected elements or surface.
masses   Creates or updates mass elements.
menu config subpanel  Located on the options panel; changes the size of HyperMesh menu and graphics fonts and cursor size, and specifies the Macro Menu.
moments  Creates or updates moments.
multibody joints   Defines kinematic joints between two local coordinate systems to connect two multibody collectors.
multibody planes   Creates rectangular, planar surfaces for use in multibody analysis.
node edit  Associates, moves, or places nodes on a surface.
normals  Displays and adjusts the normal of elements or surfaces.
numbers  Displays the IDs of entities.
objective   Allows you to define objective functions for optimization problems.
opti control   Allows you to control the optimization process.
options  Allows you to determine tolerance, zoom factor, element shrink, pick handles, etc.
optimization module   Perform topology, topography, size, and shape optimizations.
opti rename   Renames the label of the optimization entities individually, or all at once.
opti reorder   Reorders optimization entities.
optistruct solver   Writes out OptiStruct input files and then solve by clicking the optistruct. button.
order change  Changes elements from first to second order, or vise versa.
organize  Moves or copies entities between components.
ossmooth   Extracts and imports the final design geometry from OptiStruct抯 topology, topography, and shape optimization results into HyperMesh
output blocks   Creates and updates blocks of entities used for output requests.
page names subpanel  Located on the files panel; customizes the page names and titles of the main menu.
penetration   Checks groups for initial penetration problems.
permute  Switches x, y, z data of entities.
planes  Creates a planar surface or mesh bounded by planar lines.
plot titles  Edits plot titles.
plots  Creates new plots and allows you to select curves to include on the plot.
position  Positions entities in space by selecting nodes.
postscript subpanel  Located on the options panel; produces PostScript images (also use function key F4).
pressures  Creates or updates pressures.
project   Projects entities to a plane, vector, or surface.
quality index   Calculates a single value to represent the quality of the displayed shell (2D) model.
query curves  Allows you to find the x and y values of a point in a curve.
rbe3  Creates or updates RBE3 elements.
read curves   Allows you to input an xy data set from an ASCII file.
reflect  Mirrors entities about a plane.
remap  Re-maps nodes onto a line.
rename  Changes collector names.
renumber  Renumbers entities.
reorder   Changes the order of named entities in the database.
reparam  Condenses line data to help increase processing speed.
replace  Allows you to manually equivalence nodes.
replay  Replays previously saved animation sequences.
responses  Allows you to create responses for an optimization.
results curves  Allows you to create curves by extracting data from a HyperMesh results file.
rigid walls   Creates and updates rigid walls.
rigids  Creates or updates rigid or rigidlink elements.
rods  Creates or updates rod elements.
rotate  Rotates entities about a vector.
ruled  Creates a surface or mesh from nodes or lines which are unconnected.
safety module   Contains the panels used for safety analysis.
scale  Modifies the size of entities.
seatbelt   Allows you to create and route seatbelts onto a dummy.
section cut  Cuts a planar section through a group of lines.
sensor   Create and edit sensors.
shape   Allows you to perform shape optimization.
simple math  Allows you to perform simple math functions on a curve.
size   Allows you to setup and perform size optimization.
skin  Creates a surface or mesh skin across a set of lines.
smooth  Improves element quality on a surface mesh.
solid map  Creates a solid mesh by defining source, destination, and along surfaces.
solid mesh  Creates a solid mesh within a volume defined by edge lines.
solver  Allows you to run an external program from within HyperMesh or assign and run a solver.
spaceball subpanel  Located on the options panel; allows changes to the operating characteristics of a spaceball device.
spheres  Creates a spherical surface or mesh.
spin  Creates a surface or mesh by rotating nodes, lines, or elements about a vector.
spline  Creates a surface or mesh with lines.
split  Splits elements into pre-defined patterns.
spotweld  Creates or updates spotweld elements.
springs  Creates or updates spring elements.
summary  Creates a summary of elements, loads, and properties.
super elems  Assigns nodes to a super element set and displays the nodes of a super element set.
surf lines  Changes the number of surface visualization lines.
surface edit  Trims surfaces with lines or surfaces, untrims surfaces, and creates surfaces that fill gaps in the model.
systems  Creates local coordinate systems.
table entries   Allows you to specify values for the constraints used in defining functions.
tags   Allows you to assign names to entities.
tangents  Creates tangent lines between a node and line or between two lines.
temp nodes  Adds or removes temporary nodes.
temperatures  Creates or updates temperatures.
tetramesh   Allows you to fill an enclosed volume with first or second-order tetrahedral elements.
titles  Creates and edits screen titles.
topography   Allows you to setup and define topography optimizations.
topology   Allows you to setup and define topology optimizations.
torus  Creates a toroidal surface or mesh.
transient  Creates an animation sequence from transient results.
translate  Moves entities along a vector.
vectors   Allows you to create a HyperMesh vector entity.
vector plot  Creates vector plots from vector quantity results.
velocities  Creates or updates velocities.
vis   Determines the display of entities in the model.
xy plots   XY plotting module contains the xy plotting panels.
发表于 2007-9-11 10:51 | 显示全部楼层
ding
hao tie
发表于 2007-9-11 12:43 | 显示全部楼层
看着有点乱哦,版主最好稍微整理一下,呵呵,这样看着还蛮累的!
发表于 2007-10-12 18:14 | 显示全部楼层
不错
 楼主| 发表于 2007-10-29 09:37 | 显示全部楼层
原帖由 octopussheng 于 2007-9-11 12:43 发表
等有时间的吧
GMT+8, 2025-7-29 03:06 , Processed in 0.085826 second(s), 18 queries , Gzip On.
