查看: 4434|回复: 16
[ProENGINEER] 二次开发求助
发表于 2007-5-27 00:38 | 显示全部楼层 |阅读模式
:hug: 求助:
       pro/e三维基本零件的参数化设计```   急```
发表于 2007-5-27 08:12 | 显示全部楼层
这方面的书籍很多
可以解一本或者买一本或者下载一本看看。
 楼主| 发表于 2007-5-30 18:44 | 显示全部楼层
望各位大侠帮助小弟解迷题!!!
我在做makefile文件的时候,用VC调试,出现如下内容``
--------------------Configuration: make_gear1 - Win32 Debug--------------------
Microsoft (R) Program Maintenance Utility   Version 6.00.8168.0
Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
NMAKE : fatal error U1073: don't know how to make 'E:\ProE\bishe\GEAR\make_gear/gear.c'
Stop.
Error executing NMAKE.
make_gear1.exe - 1 error(s), 0 warning(s)
请问如何解决```...
发表于 2007-6-1 10:58 | 显示全部楼层
把make文件贴出来看看
建议参考机械工业出版社出版的《pro/toolkit程序设计》
[ 本帖最后由 MVH 于 2007-6-1 11:00 编辑 ]
 楼主| 发表于 2007-6-3 20:38 | 显示全部楼层
请问make文件需要重新改写吗?
贴到哪个位置?
谢谢楼上指教```
发表于 2007-6-4 14:11 | 显示全部楼层
原帖由 huyoyu 于 2007-6-3 20:38 发表
请问make文件需要重新改写吗?
贴到哪个位置?
谢谢楼上指教```
make文件的内容贴到论坛中来看看
 楼主| 发表于 2007-6-11 08:57 | 显示全部楼层
请楼上的高人看看:
# File Name
MAKEFILENAME = gear
# Machine Type
PRO_MACHINE_TYPE = i486_nt
# Executable names
EXE = gear.exe
EXE_DLL = gear.dll
# Pro/Toolkit Source & Machine Loadpoint  (EXTERNAL USE - DEFAULT)
PTC_DIR = D:\Program Files\proeWildfire 2.0
PROTOOL_SRC = $(PTC_DIR)/protoolkit
PROTOOL_SYS = $(PROTOOL_SRC)/$(PRO_MACHINE_TYPE)
PROTOOL_SRC = $(PTC_DIR)/prodevelop
# Pro/Toolkit Source & Machine Loadpoint  (PTC INTERNAL USE)
#PROTOOL_SRC = $(PTCSRC)/protoolkit
#PROTOOL_SYS = $(PTCSYS)
#PROTOOL_SRC = $(PTCSRC)/prodevelop
# Include File Paths
INCS = -I. -I$(PROTOOL_SRC)/protk_appls/includes
-I$(PROTOOL_SRC)/includes \
    -I$(PRODEV_SRC)/includes
      -I$(protk_appls)/includes
# Compiler Flags //
CC = cl
MACH = -DPRO_MACHINE=29 -DPRO_OS=4
CCFLAGS = -Dhypot=_hypot -DMSB_LEFT -Dfar=ptc_far -Dhuge=p_huge -Dnear=p_near -c -W2 -G4 -Za -D_X86_=1 -D_WSTDIO_DEFINED
CFLAGS = $(CCFLAGS) $(INCS) $(MACH)
# Libraries
PTCLIBS = $(PRODEV_SYS)/obj/prodevelop.lib
$(PROTOOL_SYS)/obj/protoolkit.lib
PTCLIBS_DLL = $(PRODEV_SYS)/obj/prodev_dll.lib
$(PROTOOL_SYS)/obj/protk_dll.lib
LIBS = kernel32.lib user32.lib advapi32.lib mpr.lib winspool.lib netapi32.lib adcapi32.lib protk_dll.lib  prodev_dll.lib  wsock32.lib
# Object files //
OBJS = gear.obj
# Linker //
LINK = link
$(EXE) :  $(OBJS) $(PTCLIBS)
        @echo Start at `date`
        @echo PROTOOL_SRC = $(PROTOOL_SRC)
        @echo PROTOOL_SYS = $(PROTOOL_SYS)
        $(LINK) /subsystem:console -out:$(EXE) /debug:none /debugtype:coff /machine:i386 @<<longline.list
$(OBJS) $(PTCLIBS) $(LIBS)
        @echo Finished at 'date'
        del $(OBJS)
# Dll target
dll: $(EXE_DLL)
$(EXE_DLL) :  $(OBJS) $(PTCLIBS_DLL)
        @echo Start at 'date'
        $(LINK) /subsystem:console -out:$(EXE_DLL) /debug:none /debugtype:coff /machine:i386 /dll @<<longline.list
$(OBJS) $(PTCLIBS_DLL) $(LIBS)
        del $(OBJS)
# object dependencies
PROTK_APPLS = E:\ProE二次开发实用教程\第五章\5.2\GEAR
gear.obj:  $(PROTK_APPLS)/gear.c
        $(CC) $(CFLAGS) $(PROTK_APPLS)/gear.c
clean :
        del $(OBJS)
        del $(EXE)
        nmake -f $(MAKEFILENAME)
clean_dll :
        del $(OBJS)
        del $(EXE_DLL)
        nmake -f $(MAKEFILENAME) dll
 楼主| 发表于 2007-6-11 08:59 | 显示全部楼层
出现的错误如下``` 还请高人指点 小弟在此谢谢了
--------------------Configuration: gear1 - Win32 Debug--------------------
gear.mak(29) : fatal error U1034: syntax error : separator missing
Stop.
 楼主| 发表于 2007-6-11 09:25 | 显示全部楼层
请楼上高人加QQ聊!
QQ 458487032
[ 本帖最后由 mjhzhjg 于 2007-6-11 21:47 编辑 ]
发表于 2007-6-11 15:43 | 显示全部楼层
原帖由 huyoyu 于 2007-6-11 08:59 发表
Copyright (C) Microsoft Corp 1988-1998. All rights res ...
29行缺少分割符
 楼主| 发表于 2007-6-11 21:43 | 显示全部楼层
谢谢楼上高人指点
 楼主| 发表于 2007-6-11 21:51 | 显示全部楼层
请问一下,具体怎么修改
第一次接触pro/e二次开发,还请高人指点
 楼主| 发表于 2007-6-11 22:39 | 显示全部楼层
还请问楼上高人 ,我compile时没有问题,但是在Build源文件时出现如下错误提示:
Linking...
LINK : fatal error LNK1117: syntax error in option "subsystem:console/incremental:yes"
Error executing link.exe.
gear.exe - 1 error(s), 0 warning(s)
我在网上搜索资料,一些朋友是去掉incremental:yes,错误消失了,但是小弟去掉之后,还是不行,还请高人指点!!!
发表于 2007-6-12 08:43 | 显示全部楼层
在Project中的Setting中,选Link选项,下面的文本框里把/subsystem:console改为/subsystem:windows
 楼主| 发表于 2007-6-12 08:55 | 显示全部楼层
我修改了,但是修改后,又出现上面LINK : fatal error LNK1117: syntax error in option "subsystem:windows/incremental:yes"
还请高人指点
GMT+8, 2024-11-17 17:51 , Processed in 0.059434 second(s), 18 queries , Gzip On.
