查看: 1453|回复: 2
[前后处理] 求助:求解过程中弹出的错误
发表于 2007-5-24 12:54 | 显示全部楼层 |阅读模式
*** WARNING ***                         CP =      13.500   TIME= 08:24:23
Both solid model and finite element model boundary conditions have been
applied to this model.  As solid loads are transferred to the nodes or
elements, they can overwrite directly applied loads.
*** WARNING ***                         CP =      22.266   TIME= 08:27:15
Previous testing revealed that 21 of the 254534 selected elements
violate shape warning limits.  To review warning messages, please see
the output or error file, or issue the CHECK command.
*** ERROR ***                           CP =   10193.031   TIME= 08:33:07
Large negative pivot value ( -0.471122742 ) in Eqn.system.  May be
because of a bad temperature-dependent material property used in the
model.
*** WARNING ***                         CP =   10193.422   TIME= 08:50:48
Smallest negative equation solver pivot term encountered at UY DOF of
node 38236.  Check for an insufficiently constrained model.
0***** process error reported by subroutine   xdslsl
       see    xdslsl abstract (ier =  -604)
*** ERROR ***                           CP =   10227.609   TIME= 09:07:00
Input/Output error on unit = 9.  Possible full disk.
最后也没有弹出求解结束
白白运算了24个小时,弹出了上面几个提示
请问该怎么解决啊?
都快疯了......
发表于 2007-5-24 13:05 | 显示全部楼层
求解时设置出现警告次数/NERR,100,100,OFF.default设置为5,超过5就不出现solution is done
调整一下网格
GMT+8, 2025-1-15 13:17 , Processed in 0.152711 second(s), 17 queries , Gzip On.
