查看: 1751|回复: 4
[结构分析] 求助:圆柱壳屈曲分析
发表于 2007-4-14 12:23 | 显示全部楼层 |阅读模式
为什么我在对圆柱壳进行特征值屈曲分析是施加压力时没有结果,而施加一个力时可以,请高手赐教!
发表于 2007-4-14 13:02 | 显示全部楼层
不太明白你的意思
发表于 2007-4-14 14:50 | 显示全部楼层
施加的压力有什么特点,如果是对称的话应该是不会屈曲的
我做旋转壳的屈曲分析施加压力就可以啊
 楼主| 发表于 2007-4-14 16:45 | 显示全部楼层
多谢楼上指点。
 楼主| 发表于 2007-4-14 19:24 | 显示全部楼层
这是我的命令流请指点,非常感谢!
/units,si
/PREP7
ET,1,SHELL63
R,1,0.009, , , , , ,
RMORE, , , ,
RMORE
RMORE, ,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2e11
MPDATA,PRXY,1,,0.3
CYL4, , ,1.2, , , ,0.685
VDELE,       1
FLST,2,2,5,ORDE,2
FITEM,2,1
FITEM,2,-2
ADELE,P51X, , ,1
wpro,,,-30.000000
wpro,,,-30.000000
wpro,,,-30.000000
FLST,2,2,5,ORDE,2
FITEM,2,3
FITEM,2,-4
ASBW,P51X
FLST,2,4,5,ORDE,4
FITEM,2,1
FITEM,2,-2
FITEM,2,5
FITEM,2,-6
AGLUE,P51X
/DIST,1,1.08222638492,1
/REP,FAST
/VIEW,1,,,1
/ANG,1
/REP,FAST
/REP,FAST
/USER,  1
/VIEW,  1, -0.161276477605    , -0.206184459926    ,  0.965131009893
/ANG,   1,   1.39709431221
/REPLO
/REP,FAST
/AUTO,1
/REP,FAST
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
APLOT
ESIZE,0.06,0,
MSHAPE,0,2D
MSHKEY,1
FLST,5,4,5,ORDE,4
FITEM,5,1
FITEM,5,-2
FITEM,5,5
FITEM,5,-6
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FINISH
/SOL
FLST,2,4,4,ORDE,2
FITEM,2,1
FITEM,2,-4
/GO
DL,P51X, ,ALL,
FLST,2,4,5,ORDE,4
FITEM,2,1
FITEM,2,-2
FITEM,2,5
FITEM,2,-6
/GO
SFA,P51X,1,PRES,800000
PSTRES,1
/STATUS,SOLU
SOLVE
FINISH
/SOLUTION
ANTYPE,1
BUCOPT,LANB,1,0,0
MXPAND,1,0,1e8,0,0.001,
/STATUS,SOLU
SOLVE
GMT+8, 2025-1-15 16:33 , Processed in 0.078382 second(s), 18 queries , Gzip On.
