查看: 1494|回复: 1
[前后处理] 求助:单元类型
发表于 2007-3-20 16:37 | 显示全部楼层 |阅读模式
缩减积分单元和全积分单元有什么区别
等参六面体是什么意思
发表于 2007-5-31 11:41 | 显示全部楼层
  • Uniform reduced integration method
    Helps to prevent volumetric mesh locking in nearly incompressible cases. However, hourglass mode might propagate in the model if there are not at least two layers of elements in each direction.
  • Full integration
    The full integration method does not cause hourglass mode, but can cause volumetric locking in nearly incompressible cases. This method is mainly used for purely linear analyses, or when the model has only one layer of elements in each direction.
GMT+8, 2025-1-15 13:17 , Processed in 0.076763 second(s), 20 queries , Gzip On.
