查看: 6435|回复: 4
[CATIA] 用CATScript 做的CATIA标题栏和工程图框(转贴)
发表于 2007-3-3 01:07 | 显示全部楼层 |阅读模式
使用方法:drafting--〉edit--〉background--〉tools--〉macro--〉macros中select本文件,run即可。
环境变量设置(很实用)
CATLM_ODTS=1 - Disable license error messages at startup
L_WILSON_LAN=1 - Access to Wilson's spline curves
CGM_ROLLINGOFFSET=1 - Access to the Rolling Offset option in GSD
TAILLE_MEMOIRE_CHOISIE=1 - Optimize IGES export memory
CATNoStartDocument=no - Disable product at startup
CNEXTBACKGROUND = no - Disable sky background at startup
CNEXTSPLASHSCREEN = no - Disable display of planet at startup
SHOW_CST_CHILDREN = 1 - Display stresses in the parents specification tree in sketcher
CNEXTOUTPUT = console - Display Catia's logs in command windows
MM_NO_REPLACE = 1 - Associativty about replacement of components cloned with different
 楼主| 发表于 2007-3-3 01:08 | 显示全部楼层
标题栏.CATScript
  1. 'COPYRIGHT DASSAULT SYSTEMES 2001
  2. ' ****************************************************************************
  3. ' Purpose:       To draw a Frame and TitleBlock
  4. ' Assumptions:   A Drafting document should be active
  5. ' Author:        庞军杰,王晓军
  6. ' Languages:     VBScript
  7. ' Version:       V5R7
  8. ' ****************************************************************************
  9. Public DrwDocument   As DrawingDocument
  10. Public DrwSheets     As DrawingSheets
  11. Public DrwSheet      As DrawingSheet
  12. Public DrwView       As DrawingView
  13. Public DrwTexts      As DrawingTexts
  14. Public Text          As DrawingText
  15. Public Fact          As Factory2D
  16. Public Point         As Point2D
  17. Public Line          As Line2D
  18. Public Cicle         As Circle2D
  19. Public Selection     As Selection
  20. Public GeomElems     As GeometricElements
  21. Public Height        As Double            'Sheet height
  22. Public Width         As Double            'Sheet width
  23. Public Offset        As Double            'Distance between the sheet edges and the frame borders
  24. Public OH            As Double            'Horizontal origin for drawing the titleblock
  25. Public OV            As Double            'Vertical   origin for drawing the titleblock
  26. Public Col(16)        As Double            'Columns coordinates
  27. Public Row(6)        As Double            'Rows    coordinates
  28. Public colRev(4)     As double            'Columns coordinates of revision block
  29. Public TranslationX  As Double            'Horizontal translation to operate when changing standard
  30. Public TranslationY  As Double            'Vertical   translation to operate when changing standard
  31. Public displayFormat As String            'Sheet format according to standard
  32. Public sheetFormat   As catPaperSize      'Sheet format as integer value
  33. 'new variable
  34. Public RowWidth         As Double             'Sheet width
  35. Public  ObjAmount  As Double
  36. Public Coll(8)           As Double            'Collumns coordinates
  37. Public Rowl(53)          As Double            'Rowls    coordinates  ObjAmount=i+3
  38. 'end
  39. Const mm           = 1
  40. Const Inch         = 254
  41. Const RulerLength  = 200
  42. Const MacroID      = "Drawing_Titleblock_JUNJIE"
  43. Const RevRowHeight = 10
  44. Sub CATMain()
  45.   CATInit
  46.   On Error Resume Next
  47.     name = DrwTexts.GetItem("Reference_" + MacroID).Name
  48.   If Err.Number <> 0 Then
  49.     Err.Clear
  50.     name = "none"
  51.   End If
  52.   On Error Goto 0
  53.   If (name = "none") Then
  54.     CATDrw_Creation
  55.    End If
  56. End Sub
  57. Sub CATDrw_Creation()
  58.   '-------------------------------------------------------------------------------
  59.   'How to create the FTB
  60.   '-------------------------------------------------------------------------------
  61.   CATInit       'To init public variables & work in the background view
  62.   If CATCheckRef(1) Then Exit Sub 'To check whether a FTB exists already in the sheet
  63.   CATStandard   'To compute standard sizes
  64.   CATReference  'To place on the drawing a reference point
  65.   CATFrame      'To draw the frame
  66.   CATTitleBlock 'To draw the TitleBlock and fill in it
  67. '******************************
  68. 'If ObjAmount>0  Then
  69. '   CATTitleObjBlock  'To draw the TitleBlock and fill in it
  70. '   Else  Exit Sub
  71. '   End If
  72. '******************************
  73. End Sub
  74. Sub CATInit()
  75.   '-------------------------------------------------------------------------------
  76.   'How to init the dialog and create main objects
  77.   '-------------------------------------------------------------------------------
  78.   Set DrwDocument = CATIA.ActiveDocument
  79.   Set DrwSheets   = DrwDocument.Sheets
  80.   Set Selection   = DrwDocument.Selection
  81.   Set DrwSheet    = DrwSheets.ActiveSheet
  82.   Set DrwView     = DrwSheet.Views.ActiveView
  83.   Set DrwTexts    = DrwView.Texts
  84.   Set Fact        = DrwView.Factory2D
  85.   Set GeomElems   = DrwView.GeometricElements
  86. End Sub
  87. Sub CATStandard()
  88.   '-------------------------------------------------------------------------------
  89.   'How to compute standard values
  90.   '-------------------------------------------------------------------------------
  91.   Height      = DrwSheet.GetPaperHeight
  92.   Width       = DrwSheet.GetPaperWidth
  93.   sheetFormat = DrwSheet.PaperSize
  94.   Offset = 10.*mm 'Offset default value = 10.
  95.   If (sheetFormat = CatPaperA0 Or sheetFormat = CatPaperA1 Or sheetFormat = CatPaperUser And _
  96.       (DrwSheet.GetPaperWidth > 594.*mm Or DrwSheet.GetPaperHeight > 594.*mm)) Then
  97.     Offset = 20.*mm
  98.   End If
  99.   OH = Width - Offset
  100.   OV = Offset
  101.   documentStd = DrwDocument.Standard
  102.   If (documentStd = catISO) Then
  103.     If sheetFormat = 13 Then
  104.       displayFormat = "USER"
  105.     Else
  106.       displayFormat = "A" + CStr(sheetFormat - 2)
  107.     End IF
  108.   Else
  109.     Select Case sheetFormat
  110.       Case 0
  111.         displayFormat = "Letter"
  112.       Case 1
  113.         displayFormat = "Legal"
  114.       Case 7
  115.         displayFormat = "A"
  116.       Case 8
  117.         displayFormat = "B"
  118.       Case 9
  119.         displayFormat = "C"
  120.       Case 10
  121.         displayFormat = "D"
  122.       Case 11
  123.         displayFormat = "E"
  124.       Case 12
  125.         displayFormat = "F"
  126.       Case 13
  127.         displayFormat = "J"
  128.     End Select
  129.   End If
  130. End Sub
  131. Sub CATReference()
  132.   '-------------------------------------------------------------------------------
  133.   'How to create a reference text
  134.   '-------------------------------------------------------------------------------
  135.   Set Text = DrwTexts.Add("", Width - Offset, Offset)
  136.   Text.Name = "Reference_" + MacroID
  137. End Sub
  138. Function CATCheckRef(Mode As Integer) As Integer
  139.   '-------------------------------------------------------------------------------
  140.   'How to check that the called macro is the right one
  141.   '-------------------------------------------------------------------------------
  142.   nbTexts = DrwTexts.Count
  143.   i = 0
  144.   notFound = 0
  145.   While (notFound = 0 And i<nbTexts)
  146.     i = i + 1
  147.     Set Text = DrwTexts.Item(i)
  148.     WholeName = Text.Name
  149.     leftText = Left(WholeName, 10)
  150.     If (leftText = "Reference_") Then
  151.     notFound = 1
  152.     refText = "Reference_" + MacroID
  153.     If (Mode = 1) Then
  154.       MsgBox "Frame and Titleblock already created!"
  155.       CATCheckRef = 1
  156.       Exit Function
  157.     ElseIf (Text.Name <> refText) Then
  158.       MsgBox "Frame and Titleblock created using another style:" + Chr(10) + "        " + MacroID
  159.       CATCheckRef = 1
  160.       Exit Function
  161.     End If
  162.     End If
  163.   Wend
  164.   CATCheckRef = 0
  165. End Function
  166. Sub CATFrame()
  167.   '-------------------------------------------------------------------------------
  168.   'How to create the Frame
  169.   '-------------------------------------------------------------------------------
  170.   Dim Cst_1   As Double  'Length (in cm) between 2 horinzontal marks
  171.   Dim Cst_2   As Double  'Length (in cm) between 2 vertical marks
  172.   Dim Nb_CM_H As Integer 'Number/2 of horizontal centring marks
  173.   Dim Nb_CM_V As Integer 'Number/2 of vertical centring marks
  174.   Dim Ruler   As Integer 'Ruler length (in cm)
  175.   CATFrameStandard     Nb_CM_H, Nb_CM_V, Ruler, Cst_1, Cst_2
  176.   CATFrameBorder
  177. End Sub
  178. Sub CATFrameStandard(Nb_CM_H As Integer, Nb_CM_V As Integer, Ruler As Integer, Cst_1 As Double, Cst_2 As Double)
  179.   '-------------------------------------------------------------------------------
  180.   'How to compute standard values
  181.   '-------------------------------------------------------------------------------
  182.   Cst_1 = 74.2*mm '297, 594, 1189 are multiples of 74.2
  183.   Cst_2 = 52.5*mm '210, 420, 841  are multiples of 52.2
  184.   If DrwSheet.Orientation = CatPaperPortrait And _
  185.      (sheetFormat = CatPaperA0 Or _
  186.       sheetFormat = CatPaperA2 Or _
  187.       sheetFormat = CatPaperA4) Or _
  188.       DrwSheet.Orientation = CatPaperLandscape And _
  189.      (sheetFormat = CatPaperA1 Or _
  190.       sheetFormat = CatPaperA3) Then
  191.     Cst_1 = 52.5*mm
  192.     Cst_2 = 74.2*mm
  193.   End If
  194.   Nb_CM_H = CInt(.5 * Width / Cst_1)
  195.   Nb_CM_V = CInt(.5 * Height / Cst_2)
  196.   Ruler   = CInt((Nb_CM_H - 1) * Cst_1 / 50) * 100 'here is computed the maximum ruler length
  197.   If RulerLength < Ruler Then
  198.     Ruler = RulerLength
  199.   End If
  200. End Sub
  201. Sub CATFrameBorder()
  202.   '-------------------------------------------------------------------------------
  203.   'How to draw the frame border
  204.   '-------------------------------------------------------------------------------
  205.   On Error Resume Next
  206.     Set Line = Fact.CreateLine(OV, OV             , OH, OV             )
  207.     Line.Name = "Frame_Border_Bottom"
  208.     Set Line = Fact.CreateLine(OH, OV             , OH, Height - Offset)
  209.     Line.Name = "Frame_Border_Left"
  210.     Set Line = Fact.CreateLine(OH, Height - Offset, OV, Height - Offset)
  211.     Line.Name = "Frame_Border_Top"
  212.     Set Line = Fact.CreateLine(OV, Height - Offset, OV, OV             )
  213.     Line.Name = "Frame_Border_Right"
  214.   If Err.Number <> 0 Then
  215.     Err.Clear
  216.   End If
  217.   On Error Goto 0
  218. End Sub
  219. Sub CATTitleBlock()
  220.   '-------------------------------------------------------------------------------
  221.   'How to create the TitleBlock
  222.   '-------------------------------------------------------------------------------
  223.   CATTitleBlockFrame    'To draw the geometry
  224.   CATTitleBlockText     'To fill in the title block
  225. If ObjAmount>0  Then
  226.    CATTitleObjBlock  'To draw the TitleObjBlock and fill in it
  227.    Else  Exit Sub
  228.    End If
  229. End Sub
  230. Sub CATTitleObjBlock()
  231.   '-------------------------------------------------------------------------------
  232.   'How to create the TitleObjBlock
  233.   '-------------------------------------------------------------------------------
  234.   CATTitleObjBlockFrame    'To draw the geometry
  235.   CATTitleObjBlockText     'To fill in the title Objblock
  236. End Sub
 楼主| 发表于 2007-3-3 01:09 | 显示全部楼层
  1. Sub CATTitleBlockFrame()
  3.   'How to draw the title block geometry
  5. ObjAmount=   InputBox("1.输入“0”或单击“取消”                          →零件图标题栏;                                                   2.输入零件个数“≥1”                              →带有明细栏的装配图标题栏" )
  6.   If( ObjAmount<2  and ObjAmount>101 )then
  7.    ObjAmount=   InputBox("请输入零件的数目(不大于101不小于2。):" )
  8.   End If
  9.   RowWidth        = + 7*mm   'Define rows  Rowwidth.
  10.   const Rows      =   7      'Define how many rows .
  11.   Col(1)  = -180*mm
  12.   Col(2)  = -170*mm
  13.   Col(3)  = -168*mm
  14.   Col(4)  = -160*mm
  15.   Col(5)  = -156*mm
  16.   Col(6)  = -146*mm
  17.   Col(7)  = -140*mm
  18.   Col(8)  = -128*mm
  19.   Col(9)  = -116*mm
  20.   Col(10) = -100*mm
  21.   Col(11) = -93.5*mm
  22.   Col(12) = -  87*mm
  23.   Col(13) = -80.5*mm
  24.   Col(14) = -  74*mm
  25.   Col(15) = -  62*mm
  26.   Col(16) = -  50*mm
  27.   Row(1) = +  9*mm
  28.   Row(2) = + 18*mm
  29.   Row(3) = + 28*mm
  30.   Row(4) = + 42*mm
  31.   Row(5) = + 56*mm
  32.   Row(6) = + 38*mm    'revised
  33.
  34.   On Error Resume Next
  35.      'Rows
  36.     Set Line      = Fact.CreateLine(OH + Col(1), OV         , OH         , OV         )
  37.     Line.Name     = "TitleBlock_Line_Bottom"
  38.     Set Line      = Fact.CreateLine(OH + Col(1), OV + Row(5), OH         , OV + Row(5))
  39.     Line.Name     = "TitleBlock_Line_Top"
  40.     Set Line      = Fact.CreateLine(OH +Col(10),OV + Row(1) , OH +Col(16) , OV + Row(1))
  41.     Line.Name     = "TitleBlock_Line_Row_1"
  42.     Set Line      = Fact.CreateLine(OH +Col(10), OV + Row(2), OH         , OV + Row(2))
  43.     Line.Name     = "TitleBlock_Line_Row_2"
  44.     Set Line      = Fact.CreateLine(OH +Col(10), OV + Row(3), OH+Col(16) , OV + Row(3))
  45.     Line.Name     = "TitleBlock_Line_Row_3"
  46.     Set Line      = Fact.CreateLine(OH + Col(16), OV + Row(6), OH        , OV + Row(6))
  47.     Line.Name     = "TitleBlock_Line_Row_4"
  48.     For i=1 to  Rows
  49.     Set Line      = Fact.CreateLine(OH + Col(1), OV + (7*i), OH+ Col(10)  , OV + (7*i))
  50.     Line.Name     = "TitleBlock_Line_LeftRow_"&i
  51.     Next
  52.      'Cols
  53.     Set Line      = Fact.CreateLine(OH + Col(1), OV         , OH + Col(1), OV + Row(5))
  54.     Line.Name     = "TitleBlock_Line_Left"
  55.     Set Line      = Fact.CreateLine(OH         , OV         , OH         , OV + Row(5))
  56.     Line.Name     = "TitleBlock_Line_Right"
  57.
  58.     Set Line      = Fact.CreateLine(OH + Col(2), OV+ Row(3) , OH + Col(2), OV + Row(5))
  59.     Line.Name     = "TitleBlock_Line_Column_1"
  60.     Set Line      = Fact.CreateLine(OH + Col(3), OV         , OH + Col(3), OV + Row(3))
  61.     Line.Name     = "TitleBlock_Line_Column_2"
  62.     Set Line      = Fact.CreateLine(OH + Col(4), OV+ Row(3) , OH + Col(4), OV + Row(5))
  63.     Line.Name     = "TitleBlock_Line_Column_3"
  64.     Set Line      = Fact.CreateLine(OH + Col(5), OV         , OH + Col(5), OV + Row(3))
  65.     Line.Name     = "TitleBlock_Line_Column_4"
  66.     Set Line      = Fact.CreateLine(OH + Col(6), OV+ Row(3) , OH + Col(6), OV + Row(5))
  67.     Line.Name     = "TitleBlock_Line_Column_5"
  68.     Set Line      = Fact.CreateLine(OH + Col(7), OV         , OH + Col(7), OV + Row(3))
  69.     Line.Name     = "TitleBlock_Line_Column_6"
  70.     Set Line      = Fact.CreateLine(OH + Col(8), OV         , OH + Col(8), OV + Row(5))
  71.     Line.Name     = "TitleBlock_Line_Column_7"
  72.     Set Line      = Fact.CreateLine(OH + Col(9), OV         , OH + Col(9), OV + Row(5))
  73.     Line.Name     = "TitleBlock_Line_Column_8"
  74.     Set Line      = Fact.CreateLine(OH +Col(10), OV         , OH +Col(10), OV + Row(5))
  75.     Line.Name     = "TitleBlock_Line_Column_9"
  76.     Set Line      = Fact.CreateLine(OH + Col(11), OV+ Row(1), OH + Col(11), OV + Row(2))
  77.     Line.Name     = "TitleBlock_Line_Column_10"
  78.     Set Line      = Fact.CreateLine(OH + Col(12), OV+ Row(1), OH + Col(12), OV + Row(2))
  79.     Line.Name     = "TitleBlock_Line_Column_11"
  80.     Set Line      = Fact.CreateLine(OH + Col(13), OV+ Row(1), OH + Col(13), OV + Row(2))
  81.     Line.Name     = "TitleBlock_Line_Column_12"
  82.     Set Line      = Fact.CreateLine(OH + Col(14), OV+ Row(1), OH + Col(14), OV + Row(3))
  83.     Line.Name     = "TitleBlock_Line_Column_13"
  84.     Set Line      = Fact.CreateLine(OH + Col(15), OV+ Row(1), OH + Col(15), OV + Row(3))
  85.     Line.Name     = "TitleBlock_Line_Column_14"
  86.     Set Line      = Fact.CreateLine(OH + Col(16), OV        , OH + Col(16), OV + Row(5))
  87.     Line.Name     = "TitleBlock_Line_Column_15"
  88.
  89.   If Err.Number <> 0 Then
  90.     Err.Clear
  91.   End If
  92.   On Error Goto 0
  93. End Sub
  94. Sub CATTitleBlockText()
  95.   '-------------------------------------------------------------------------------
  96.   'How to fill in the title block
  97.   '-------------------------------------------------------------------------------
  98.   CATLinks
  99.   'The Left-down subBlock.
  100.   Text_01  = "指导教师"
  101.   Text_02  = "审核"
  102.   Text_03  = "设计"
  103.   Text_04  = "张国建"
  104.   Text_05  = "03.09.25"
  105.   Text_06  = "标准化"
  106.   Text_07  = "(签名)"
  107.   Text_08  = "(年月日)"
  108.   Text_09  = "批准"
  109.   Text_001  = " "
  110.
  111.   'The Left-up subBlock.
  112.   Text_10  = "标记"
  113.   Text_11  = "处数"
  114.   Text_12  = "分区"
  115.   Text_13  = "更改文件号"
  116.   Text_14  = "(签名)"
  117.   Text_15  = "(年月日)"
  118.
  119.   'The Middle subblock
  120.   Text_16 = "   共  张      第  张   "
  121.   Text_17 = "比例"
  122.   Text_18 = "重量"
  123.   Text_19= " 阶 段 标 记"
  124.   Text_20 = "(材料标记)"
  125.   'The right subblock
  126.   Text_21 = "上海方宇工业设计"
  127.   Text_22 ="(图样名称)"
  128.   Text_23 = "课程设计专用图纸"
  129.     'The Left-down subBlockText.
  130.   Set Text     = DrwTexts.Add(Text_01 , OH + Col(1)            , OV+1                     )
  131.   CATFormatTBText "TitleBlock_Text_Techer"      ,catBottomLeft  ,   4
  132.   Set Text     = DrwTexts.Add("   ", OH + Col(3)            , OV+1                     )
  133.   CATFormatTBText "TitleBlock_Text_Tec_1"       ,catBottomLeft  ,   5
  134.   Set Text     = DrwTexts.Add("   ", OH + Col(5) + 3.       , OV+1                     )
  135.   CATFormatTBText "TitleBlock_Text_Tec_2"       ,catBottomLeft  ,   5
  136.   Set Text     = DrwTexts.Add(Text_02 ,  OH + Col(1)+2             , OV + Rowwidth         )
  137.   CATFormatTBText "TitleBlock_Text_checker"      ,catBottomLeft  ,   5
  138.   Set Text     = DrwTexts.Add("   ", OH + Col(3) + 1.       , OV + Rowwidth          )
  139.   CATFormatTBText "TitleBlock_Text_chec_1"       ,catBottomLeft  ,   5
  140.   Set Text     = DrwTexts.Add("   ", OH + Col(5) + 1.       , OV + Rowwidth          )
  141.   CATFormatTBText "TitleBlock_Text_chec_2"       ,catBottomLeft  ,   5
  142.   Set Text     = DrwTexts.Add(Text_03 , OH + Col(1) + 2.       , OV + (Rowwidth*3)      )
  143.   CATFormatTBText "TitleBlock_Text_design"       ,catBottomLeft  ,   5
  144.   Set Text     = DrwTexts.Add("    " , OH + Col(1) + 1.       , OV + (Rowwidth*2)      )
  145.   CATFormatTBText "TitleBlock_Text_des_1 "       ,catBottomLeft  ,   5
  146.   Set Text     = DrwTexts.Add(Text_04 , OH + Col(3) + 1.       , OV+ (Rowwidth*3)       )
  147.   CATFormatTBText "TitleBlock_Text_Sign "       ,catBottomLeft  ,   5
  148.   Set Text     = DrwTexts.Add("   ", OH + Col(3) + 1.       , OV+ (Rowwidth*2)       )
  149.   CATFormatTBText "TitleBlock_Text_Sign_1 "     ,catBottomLeft  ,   5
  150.   Set Text     = DrwTexts.Add(Text_05 , OH + Col(5) + 1.       , OV+ (Rowwidth*3)       )
  151.   CATFormatTBText "TitleBlock_Text_Date "       ,catBottomLeft  ,   4
  152.   Set Text     = DrwTexts.Add("   ", OH + Col(5) + 1.       , OV+ (Rowwidth*2)       )
  153.   CATFormatTBText "TitleBlock_Text_Date_1 "     ,catBottomLeft  ,   5
  154.   Set Text     = DrwTexts.Add(Text_06 , OH + Col(7) + 1.       , OV + (Rowwidth*3)      )
  155.   CATFormatTBText "TitleBlock_Text_Standard"       ,catBottomLeft  ,   5
  156.   Set Text     = DrwTexts.Add("   ", OH + Col(7) + 1.       , OV + (Rowwidth*2)      )
  157.   CATFormatTBText "TitleBlock_Text_Std_1 "       ,catBottomLeft  ,   5
  158.   Set Text     = DrwTexts.Add("   ", OH + Col(7) + 1.       , OV+ (Rowwidth*1)       )
  159.   CATFormatTBText "TitleBlock_Text_Std_1 "       ,catBottomLeft  ,   5
  160.   Set Text     = DrwTexts.Add(Text_07 , OH + Col(8) + 1.       , OV+ (Rowwidth*3)       )
  161.   CATFormatTBText "TitleBlock_Text_Sign2 "       ,catBottomLeft  ,   5
  162.   Set Text     = DrwTexts.Add("   ", OH + Col(8) + 1.       , OV+ (Rowwidth*2)      )
  163.   CATFormatTBText "TitleBlock_Text_Sign2_1 "     ,catBottomLeft  ,   5
  164.   Set Text     = DrwTexts.Add("   ", OH + Col(8) + 1.       , OV+ (Rowwidth*1)      )
  165.   CATFormatTBText "TitleBlock_Text_Sign2_2 "     ,catBottomLeft  ,   5
  166.   Set Text     = DrwTexts.Add(Text_08 , OH + Col(9) + 1.       , OV+ (Rowwidth*3)      )
  167.   CATFormatTBText "TitleBlock_Text_Date2 "       ,catBottomLeft  ,   5
  168.   Set Text     = DrwTexts.Add("   ", OH + Col(9) + 1.       , OV+ (Rowwidth*2)      )
  169.   CATFormatTBText "TitleBlock_Text_Date2_1 "     ,catBottomLeft  ,   5
  170.   Set Text     = DrwTexts.Add("   ", OH + Col(9) + 1.       , OV+ (Rowwidth*1)      )
  171.   CATFormatTBText "TitleBlock_Text_Date2_2 "     ,catBottomLeft  ,   5
  172.   Set Text     = DrwTexts.Add(Text_09 , OH + Col(7) + 3.       , OV                     )
  173.   CATFormatTBText "TitleBlock_Text_Allow"        ,catBottomLeft  ,   5
  174.   Set Text     = DrwTexts.Add("   ", OH + Col(8) + 1.       , OV                     )
  175.   CATFormatTBText "TitleBlock_Text_Allow_1"       ,catBottomLeft  ,   5
  176.   Set Text     = DrwTexts.Add("   ", OH + Col(9) + 1.       , OV                     )
  177.   CATFormatTBText "TitleBlock_Text_Allow_2"       ,catBottomLeft  ,   5
  178.   'The Left-up subBlockText.
  179.   Set Text     = DrwTexts.Add(Text_10 , OH + Col(1) + 1.       , OV+ (Rowwidth*4)       )
  180.   CATFormatTBText "TitleBlock_Text_Mark"         ,catBottomLeft  ,   5
  181.   Set Text     = DrwTexts.Add("   ", OH + Col(1) + 1.       , OV+ (Rowwidth*5)       )
  182.   CATFormatTBText "TitleBlock_Text_Mark_1"       ,catBottomLeft  ,   5
  183.   Set Text     = DrwTexts.Add("   ", OH + Col(1) + 1.       , OV+ (Rowwidth*6)       )
  184.   CATFormatTBText "TitleBlock_Text_Mark_2"       ,catBottomLeft  ,   5
  185.   Set Text     = DrwTexts.Add("   ", OH + Col(1) + 1.       , OV+ (Rowwidth*7)       )
  186.   CATFormatTBText "TitleBlock_Text_Mark_3"       ,catBottomLeft  ,   5
  187.   Set Text     = DrwTexts.Add(Text_11 , OH + Col(2) + 1.       , OV+ (Rowwidth*4)       )
  188.   CATFormatTBText "TitleBlock_Text_Amout"         ,catBottomLeft  ,   5
  189.   Set Text     = DrwTexts.Add("   ", OH + Col(2) + 1.       , OV+ (Rowwidth*5)       )
  190.   CATFormatTBText "TitleBlock_Text_Amout_1"       ,catBottomLeft  ,   5
  191.   Set Text     = DrwTexts.Add("   ", OH + Col(2) + 1.       , OV+ (Rowwidth*6)       )
  192.   CATFormatTBText "TitleBlock_Text_Amout_2"       ,catBottomLeft  ,   5
  193.   Set Text     = DrwTexts.Add("   ", OH + Col(2) + 1.       , OV+ (Rowwidth*7)       )
  194.   CATFormatTBText "TitleBlock_Text_Amout_3"       ,catBottomLeft  ,   5
  195.   Set Text     = DrwTexts.Add(Text_12 , OH + Col(4) +3.       , OV+ (Rowwidth*4)       )
  196.   CATFormatTBText "TitleBlock_Text_District"      ,catBottomLeft  ,   5
  197.   Set Text     = DrwTexts.Add("   ", OH + Col(4) + 1.       , OV+ (Rowwidth*5)       )
  198.   CATFormatTBText "TitleBlock_Text_Dis_1"         ,catBottomLeft  ,   5
  199.   Set Text     = DrwTexts.Add("   ", OH + Col(4) + 1.       , OV+ (Rowwidth*6)       )
  200.   CATFormatTBText "TitleBlock_Text_Dis_2"         ,catBottomLeft  ,   5
  201.   Set Text     = DrwTexts.Add("   ", OH + Col(4) + 1.       , OV+ (Rowwidth*7)       )
  202.   CATFormatTBText "TitleBlock_Text_Dis_3"         ,catBottomLeft  ,   5
  203.   Set Text     = DrwTexts.Add(Text_13 , OH + Col(6) + 1.       , OV+ (Rowwidth*4)       )
  204.   CATFormatTBText "TitleBlock_Text_ReviseList"    ,catBottomLeft  ,  5
  205.   Set Text     = DrwTexts.Add("   ", OH + Col(6) + 1.       , OV+ (Rowwidth*5)       )
  206.   CATFormatTBText "TitleBlock_Text_RevL_1"        ,catBottomLeft  ,   5
  207.   Set Text     = DrwTexts.Add("   ", OH + Col(6) + 1.       , OV+ (Rowwidth*6)       )
  208.   CATFormatTBText "TitleBlock_Text_RevL_2"        ,catBottomLeft  ,   5
  209.   Set Text     = DrwTexts.Add("   ", OH + Col(6) + 1.       , OV+ (Rowwidth*7)       )
  210.   CATFormatTBText "TitleBlock_Text_RevL_3"        ,catBottomLeft  ,   5
  211.   Set Text     = DrwTexts.Add(Text_14 , OH + Col(8) + 1.       , OV+ (Rowwidth*4)       )
  212.   CATFormatTBText "TitleBlock_Text_SignL"         ,catBottomLeft  ,   5
  213.   Set Text     = DrwTexts.Add("   ", OH + Col(8) + 1.       , OV+ (Rowwidth*5)       )
  214.   CATFormatTBText "TitleBlock_Text_SignL_1"       ,catBottomLeft  ,   5
  215.   Set Text     = DrwTexts.Add("   ", OH + Col(8) + 1.       , OV+ (Rowwidth*6)       )
  216.   CATFormatTBText "TitleBlock_Text_SignL_2"       ,catBottomLeft  ,   5
  217.   Set Text     = DrwTexts.Add("   ", OH + Col(8) + 1.       , OV+ (Rowwidth*7)       )
  218.   CATFormatTBText "TitleBlock_Text_SignL_3"       ,catBottomLeft  ,   5
  219.   Set Text     = DrwTexts.Add(Text_15 , OH + Col(9) + 1.       , OV+ (Rowwidth*4)       )
  220.   CATFormatTBText "TitleBlock_Text_DateL"         ,catBottomLeft  ,   5
  221.   Set Text     = DrwTexts.Add("   ", OH + Col(9) + 1.       , OV+ (Rowwidth*5)       )
  222.   CATFormatTBText "TitleBlock_Text_DateL_1"       ,catBottomLeft  ,   5
  223.   Set Text     = DrwTexts.Add("   ", OH + Col(9) + 1.       , OV+ (Rowwidth*6)       )
  224.   CATFormatTBText "TitleBlock_Text_DateL_2"       ,catBottomLeft  ,   5
  225.   Set Text     = DrwTexts.Add("   ", OH + Col(9) + 1.       , OV+ (Rowwidth*7)       )
  226.   CATFormatTBText "TitleBlock_Text_DateL_3"       ,catBottomLeft  ,   5
  227.   'The Middle subblockText.
  228.   Set Text     = DrwTexts.Add(Text_16  , OH + Col(10) + 1.        , OV                   )
  229.   CATFormatTBText "TitleBlock_Text_Acount  "      ,catBottomLeft  ,   5
  230.   Set Text     = DrwTexts.Add("   " , OH + Col(12) -5.       , OV                     )
  231.   CATFormatTBText "TitleBlock_Text_Acount_1"      ,catBottomLeft  ,   5
  232.   Set Text     = DrwTexts.Add("   " , OH + Col(15) + 1.       , OV                     )
  233.   CATFormatTBText "TitleBlock_Text_Acount_2"      ,catBottomLeft  ,   5
  234.   Set Text     = DrwTexts.Add(Text_17  ,  OH + Col(15) + 2.       , OV +(Row(2)+3)         )
  235.   CATFormatTBText "TitleBlock_Text_Scale"         ,catBottomLeft  ,   5
  236.   Set Text     = DrwTexts.Add("   " ,  OH + Col(15)         , OV+(Row(1)+3)           )
  237.   CATFormatTBText "TitleBlock_Text_Scale_1"       ,catBottomLeft  ,   5
  238.   Set Text     = DrwTexts.Add(Text_18   , OH + Col(14) + 2.      , OV +(Row(2)+3)          )
  239.   CATFormatTBText "TitleBlock_Text_Weight"         ,catBottomLeft  ,   5
  240.   Set Text     = DrwTexts.Add("   " , OH + Col(14) + 2.      , OV+(Row(1)+3)           )
  241.   CATFormatTBText "TitleBlock_Text_Weight_1"       ,catBottomLeft  ,   5
  242.   Set Text     = DrwTexts.Add(Text_19   ,  OH + Col(10) + 1.     , OV +(Row(2)+3)          )
  243.   CATFormatTBText "TitleBlock_Text_PhaseSign"         ,catBottomLeft  ,   5
  244.   Set Text     = DrwTexts.Add("   " , OH + Col(10) + 1.      , OV+(Row(1)+2)           )
  245.   CATFormatTBText "TitleBlock_Text_Phs_1"             ,catBottomLeft  ,   5
  246.   Set Text     = DrwTexts.Add("   "  , OH + Col(11) + 1.      , OV+(Row(1)+2)           )
  247.   CATFormatTBText "TitleBlock_Text_Phs_1"             ,catBottomLeft  ,   5
  248.   Set Text     = DrwTexts.Add("   "  , OH + Col(12) + 1.      , OV+(Row(1)+2)           )
  249.   CATFormatTBText "TitleBlock_Text_Phs_1"             ,catBottomLeft  ,   5
  250.   Set Text     = DrwTexts.Add("   "  , OH + Col(13) + 1.      , OV+(Row(1)+2)           )
  251.   CATFormatTBText "TitleBlock_Text_Phs_1"             ,catBottomLeft  ,   5
  252.   Set Text     = DrwTexts.Add(Text_20   , OH + Col(10) + 25.     , OV +(Row(3)+5)          )
  253.   CATFormatTBText "TitleBlock_Text_MaterialSign"      ,catBottomCenter,   10
  254.    'The right subblockText.
  255.   Set Text     = DrwTexts.Add(Text_21  , OH + Col(16) +25.       , OV +Row(4)        )
  256.   CATFormatTBText "TitleBlock_Text_School"            ,catBottomCenter,      7
  257.   Set Text     = DrwTexts.Add(Text_22  , OH + Col(16) +25.       , OV +(Row(2)+5)         )
  258.   CATFormatTBText "TitleBlock_Text_DrawingName"       ,catBottomCenter,      7
  259.   Set Text     = DrwTexts.Add(Text_23  , OH + Col(16) +25.       , OV +5                 )
  260.   CATFormatTBText "TitleBlock_Text_Use  "             ,catBottomCenter,      7
  261.
  262. End Sub
  1. Sub CATTitleObjBlockFrame()
  3.   'How to draw the title Objblock geometry
  5.   Coll(1) = -180*mm
  6.   Coll(2) = -172*mm
  7.   Coll(3) = -134*mm
  8.   Coll(4) = -90*mm
  9.   Coll(5) = - 82*mm
  10.   Coll(6) = - 44*mm
  11.   Coll(7) = - 34*mm
  12.   Coll(8) = - 24*mm
  13.
  14.   Rowl(1) = + 56*mm
  15.   Rowl(2) = + 63*mm
  16.   Rowl(3) = + 70*mm
  17.   For   i=1 to  ObjAmount
  18.    Rowl(i+3)= + (70+7*i)*mm
  19.   Next
  20.
  21.   'MsgBox "Frame and Titleblock already created!"
  22.   On Error Resume Next
  23.     'creat TitleObjBlock RowlLines .
  24.     Set Line      = Fact.CreateLine(OH + Coll(6), OV +Rowl(2)        , OH+ Coll(8)         , OV + Rowl(2)  )
  25.     Line.Name     = "TitleObjBlock_Shotest_Bottom"
  26.     Set Line      = Fact.CreateLine(OH + Coll(1), OV +Rowl(3)        , OH                 , OV + Rowl(3)  )
  27.     Line.Name     = "TitleObjBlock_RowlLine_Bottom"
  28.
  29.    For i=1 to ObjAmount
  30.     Set Line      = Fact.CreateLine(OH + Coll(1), OV +Rowl(i+3)      , OH                 , OV + Rowl(i+3))
  31.     Line.Name     = "TitleObjBlock_RowlLine_No." & i
  32.     DrawingDimLine.thickness=1
  33. Next
  34.      'creat TitleObjBlock CollLines .
  35.     Set Line      = Fact.CreateLine(OH + Coll(8), OV +Rowl(1)        , OH+ Coll(8)         , OV + Rowl( ObjAmount+3)  )
  36.     Line.Name     = "TitleObjBlock_Collline_No.8"
  37.     Set Line      = Fact.CreateLine(OH + Coll(7), OV +Rowl(2)        , OH+ Coll(7)         , OV + Rowl( ObjAmount+3)  )
  38.     Line.Name     = "TitleObjBlock_Collline_No.7"
  39.     Set Line      = Fact.CreateLine(OH + Coll(6), OV +Rowl(1)        , OH+ Coll(6)         , OV + Rowl( ObjAmount+3)  )
  40.     Line.Name     = "TitleObjBlock_Collline_No.6"
  41.     Set Line      = Fact.CreateLine(OH + Coll(5), OV +Rowl(1)        , OH+ Coll(5)         , OV + Rowl( ObjAmount+3)  )
  42.     Line.Name     = "TitleObjBlock_Collline_No.5"
  43.     Set Line      = Fact.CreateLine(OH + Coll(4), OV +Rowl(1)        , OH+ Coll(4)         , OV + Rowl( ObjAmount+3)  )
  44.     Line.Name     = "TitleObjBlock_Collline_No.4"
  45.     Set Line      = Fact.CreateLine(OH + Coll(3), OV +Rowl(1)        , OH+ Coll(3)         , OV + Rowl( ObjAmount+3)  )
  46.     Line.Name     = "TitleObjBlock_Collline_No.3"
  47.     Set Line      = Fact.CreateLine(OH + Coll(2), OV +Rowl(1)        , OH+ Coll(2)         , OV + Rowl( ObjAmount+3)  )
  48.     Line.Name     = "TitleObjBlock_Collline_No.2"
  49.     Set Line      = Fact.CreateLine(OH + Coll(1), OV +Rowl(1)        , OH+ Coll(1)         , OV + Rowl( ObjAmount+3)  )
  50.     Line.Name     = "TitleObjBlock_Collline_No.1"
  51.    If Err.Number <> 0 Then
  52.     Err.Clear
  53.    End If
  54.   On Error Goto 0
  55. End Sub
  56. Sub CATTitleObjBlockText()
  57.     '-------------------------------------------------------------------------------
  58.     'How to fill in the title Objblock.
  59.     '----------------------------------------------------------------------------
  60.     Text_01 = "序"
  61.     Text_02 = "号"
  62.     Text_03 = Chr(15) +"代       号"
  63.     Text_04 = Chr(15) +"  名         称"
  64.     Text_05 = "数"
  65.     Text_06 = "量"
  66.     Text_07 = Chr(20) +"  材       料"
  67.     Text_08 = "单件"
  68.     Text_09 = "总计"
  69.     Text_10 = Chr(10) +"重量(Kg)"
  70.     Text_11 = Chr(15) +"备     注"
  71.     TextO_01 = "  "
  72.     TextO_02 = "   "
  73.     TextO_03 = "   "
  74.     TextO_04 = "   "
  75.     TextO_05 = "   "
  76.     TextO_06 = "   "
  77.     TextO_07 = "   "
  78.     TextO_08 = "   "
  79.
  80.   Set Text     = DrwTexts.Add(Text_01, OH + Coll(1) + 4.       , OV + (Rowl(2)+3)        )
  81.   CATFormatTBText "ObjTitleBlock_Text_xu"         ,catMiddleCenter,    5
  82.   Set Text     = DrwTexts.Add(Text_02, OH + Coll(1) + 4.       , OV + (Rowl(1)+3)        )
  83.   CATFormatTBText "ObjTitleBlock_Text_hao"        ,catMiddleCenter,    5
  84.   Set Text     = DrwTexts.Add(Text_03, OH + Coll(2) + 4.       , OV + (Rowl(1)+3)        )
  85.   CATFormatTBText "ObjTitleBlock_Text_Cname"      , catBottomLeft ,    5
  86.   Set Text     = DrwTexts.Add(Text_04, OH + Coll(3) + 4.       , OV + (Rowl(1)+3)        )
  87.   CATFormatTBText "ObjTitleBlock_Text_Name"       , catBottomLeft ,    5
  88.   Set Text     = DrwTexts.Add(Text_05, OH + Coll(4) + 4.       , OV + (Rowl(2)+3)        )
  89.   CATFormatTBText "ObjTitleBlock_Text_shu"        ,catMiddleCenter,    5
  90.   Set Text     = DrwTexts.Add(Text_06, OH + Coll(4) + 4.       , OV + (Rowl(1)+3)        )
  91.   CATFormatTBText "ObjTitleBlock_Text_liang"      ,catMiddleCenter,    5
  92.   Set Text     = DrwTexts.Add(Text_07, OH + Coll(5) + 1.       , OV + (Rowl(1)+3)        )
  93.   CATFormatTBText "ObjTitleBlock_Text_Materia"    , catBottomLeft ,    5
  94.   Set Text     = DrwTexts.Add(Text_08, OH + Coll(6) + 2        , OV + (Rowl(2)+1)        )
  95.   CATFormatTBText "ObjTitleBlock_Text_Single"     , catBottomLeft ,    5
  96.   Set Text     = DrwTexts.Add(Text_09, OH + Coll(7) + 2.       , OV + (Rowl(2)+1)        )
  97.   CATFormatTBText "ObjTitleBlock_Text_Amount"     , catBottomLeft ,    5
  98.   Set Text     = DrwTexts.Add(Text_10, OH + Coll(6) + 3.       , OV + (Rowl(1)+1)        )
  99.   CATFormatTBText "ObjTitleBlock_Text_weigt"      , catBottomLeft ,    5
  100.   Set Text     = DrwTexts.Add(Text_11, OH + Coll(8) + 1.       , OV + (Rowl(1)+3)        )
  101.   CATFormatTBText "ObjTitleBlock_Text_Backface"   , catBottomLeft ,    5
  102.   For   i=1 to  (ObjAmount)
  103.   Set Text     = DrwTexts.Add(TextO_01, OH + Coll(1) + 2.       , OV + (Rowl(i+2)+1)         )
  104.   CATFormatTBText "ObjTitleBlock_TextO_coll_"&i       , catBottomLeft  ,   5
  105.    Set Text     = DrwTexts.Add(TextO_02, OH + Coll(2) + 2.       , OV + (Rowl(i+2)+1)        )
  106.   CATFormatTBText "ObjTitleBlock_TextO_coll_"&i       , catBottomLeft  ,   5
  107.    Set Text     = DrwTexts.Add(TextO_03, OH + Coll(3) + 2.       , OV + (Rowl(i+2)+1)        )
  108.   CATFormatTBText "ObjTitleBlock_TextO_coll_"&i       , catBottomLeft  ,   5
  109.    Set Text     = DrwTexts.Add(TextO_04, OH + Coll(4) + 1.       , OV + (Rowl(i+2)+1)        )
  110.   CATFormatTBText "ObjTitleBlock_TextO_coll_"&i       , catBottomLeft  ,   5
  111.    Set Text     = DrwTexts.Add(TextO_05, OH + Coll(5) + 2.       , OV + (Rowl(i+2)+1)        )
  112.   CATFormatTBText "ObjTitleBlock_TextO_coll_"&i       , catBottomLeft  ,   5
  113.    Set Text     = DrwTexts.Add(TextO_06, OH + Coll(6) + 2.       , OV + (Rowl(i+2)+1)        )
  114.   CATFormatTBText "ObjTitleBlock_TextO_coll_"&i       , catBottomLeft  ,   5
  115.   Set Text     =  DrwTexts.Add(TextO_07, OH + Coll(7) + 2.       , OV + (Rowl(i+2)+1)        )
  116.   CATFormatTBText "ObjTitleBlock_TextO_coll_"&i       , catBottomLeft  ,   5
  117.    Set Text     = DrwTexts.Add(TextO_08, OH + Coll(8) + 2.       , OV + (Rowl(i+2)+1)        )
  118.   CATFormatTBText "ObjTitleBlock_TextO_coll_"&i       , catBottomLeft  ,   5
  119. Next
  120.   CATLinks
  121. End Sub
  122. Sub CATFormatFText(textName As String, angle As Double)
  123.   '-------------------------------------------------------------------------------
  124.   'How to format the texts belonging to the frame
  125.   '-------------------------------------------------------------------------------
  126.   Text.Name           = textName
  127.   Text.AnchorPosition = CATMiddleCenter
  128.   Text.Angle          = angle
  129. End Sub
  130. Sub CATFormatTBText(textName As String, anchorPosition As String, fontSize)
  131.   '-------------------------------------------------------------------------------
  132.   'How to format the texts belonging to the titleblock
  133.   '-------------------------------------------------------------------------------
  134.   Text.Name           = textName
  135.   Text.SetFontName      0, 0, "FangSong_GB2312"
  136.   Text.AnchorPosition = anchorPosition
  137.   Text.SetFontSize      0, 0, fontSize
  138. End Sub
  139. Sub CATLinks()
  140.   '-------------------------------------------------------------------------------
  141.   'How to fill in texts with data of the part/product linked with current sheet
  142.   '-------------------------------------------------------------------------------
  143.   On Error Resume Next
  144.     Dim ProductDrawn As ProductDocument
  145.     Set ProductDrawn = DrwSheet.Views.Item("Front view").GenerativeBehavior.Document
  146.   If Err.Number = 0 Then
  147.     DrwTexts.GetItem("TitleBlock_Text_Number_1").Text = ProductDrawn.PartNumber
  148.     DrwTexts.GetItem("TitleBlock_Text_Title_1").Text  = ProductDrawn.Definition
  149.     Dim ProductAnalysis As Analyze
  150.     Set ProductAnalysis = ProductDrawn.Analyze
  151.     DrwTexts.GetItem("TitleBlock_Text_Weight_1").Text = FormatNumber(ProductAnalysis.Mass,2)
  152.   End If
  153. '-------------------------------------------------------------------------------
  154.   'Display sheet format
  155.   '-------------------------------------------------------------------------------
  156.   Dim textFormat As DrawingText
  157.   Set textFormat = DrwTexts.GetItem("Text_23")
  158.   textFormat.Text = displayFormat
  159.   If (Len(displayFormat) > 4 ) Then
  160.     textFormat.SetFontSize 0, 0, 2.5
  161.   Else
  162.     textFormat.SetFontSize 0, 0, 4.
  163.   End If
  164.   '-------------------------------------------------------------------------------
  165.   'Display sheet numbering
  166.   '-------------------------------------------------------------------------------
  167.   Dim nbSheet  As Integer
  168.   Dim curSheet As Integer
  169.   nbSheet  = 0
  170.   curSheet = 0
  171. If (not DrwSheet.IsDetail) Then
  172.     For i = 1 To DrwSheets.Count
  173.       If (not DrwSheets.Item(i).IsDetail) Then
  174.         nbSheet = nbSheet + 1
  175.       End If
  176.     Next
  177.     For i = 1 To DrwSheets.Count
  178.       If (not DrwSheets.Item(i).IsDetail) Then
  179.         On Error Resume Next
  180.         curSheet = curSheet + 1
  181.         DrwSheets.Item(i).Views.Item(2).Texts.GetItem("TitleBlock_Text_Sheet_1").Text = CStr(curSheet) & "/" & CStr(nbSheet)
  182.       End If
  183.     Next
  184.   End If
  185.   On Error Goto 0
  186. End Sub
发表于 2012-8-16 11:46 | 显示全部楼层
楼主:
您好!
按你提供的方法创建的标题栏的所有线型均是粗实线
有没有办法选择性生成“细实线”呀
GMT+8, 2025-6-25 04:36 , Processed in 0.092097 second(s), 19 queries , Gzip On.
