查看: 1085|回复: 2
[绘图技巧] 如何使坐标轴以大数开始,以小数结束?
发表于 2007-1-30 22:59 | 显示全部楼层 |阅读模式
请问如何在MATLAB中,使得让坐标轴以大数开始,以小数结束。比如Z周上面为0,下面为10
这种问题已经讨论过多次,建议发贴前先搜索论坛.
by xjzuo
[ 本帖最后由 xjzuo 于 2007-1-31 18:35 编辑 ]
发表于 2007-1-31 13:14 | 显示全部楼层
图形截面编辑中可以顺向(由小到大),也可以逆向(由大到小)。选择逆向即可!(Matlab7.0)
发表于 2007-1-31 14:42 | 显示全部楼层
原帖由 heaventian 于 2007-1-30 22:59 发表
楼上的提示是界面实现,下面是程序实现的介绍:
  1. XDir, YDir, ZDir             {normal} | reverse
  2. Direction of increasing values. A mode controlling the direction of increasing axis values. Axes form a right-hand coordinate system. By default, x-axis values increase from left to right. To reverse the direction of increasing x values, set this property to reverse.
  3. set(gca,'XDir','reverse')
  4. y-axis values increase from bottom to top (2-D view) or front to back (3-D view). To reverse the direction of increasing y values, set this property to reverse.
  5. set(gca,'YDir','reverse')
  6. z-axis values increase pointing out of the screen (2-D view) or from bottom to top (3-D view). To reverse the direction of increasing z values, set this property to reverse.
  7. set(gca,'ZDir','reverse')
GMT+8, 2024-10-3 17:16 , Processed in 0.057913 second(s), 18 queries , Gzip On.
