查看: 2108|回复: 10
[综合讨论] 请教如何将wave文件变成matlab数据文件?
发表于 2006-12-20 20:12 | 显示全部楼层 |阅读模式
请教如何将wave文件变成matlab数据文件?也就是变成Matlab data file,而不是matlab M-file?非常感谢!
发表于 2006-12-20 22:39 | 显示全部楼层
可以先在VC++中把wave文件数据读到一个数组中,然后用c语言把这个数组写成.mat文件格式.
在VC++中读写mat文件的代码可以参考如下代码:
* MAT-file creation program
* See the MATLAB API Guide for compiling information.
* Calling syntax:
*   matcreat
* Create a MAT-file which can be loaded into MATLAB.
* This program demonstrates the use of the following functions:
*  matClose
*  matGetVariable
*  matOpen
*  matPutVariable
*  matPutVariableAsGlobal
* Copyright 1984-2000 The MathWorks, Inc.
* $ Revision: 1.13 $
#include <stdio.h>
#include <string.h> /* For strcmp() */
#include <stdlib.h> /* For EXIT_FAILURE, EXIT_SUCCESS */
#include "mat.h"
#define BUFSIZE 256
int main() {
  MATFile *pmat;
  mxArray *pa1, *pa2, *pa3;
  double data[9] = { 1.0, 4.0, 7.0, 2.0, 5.0, 8.0, 3.0, 6.0, 9.0 };
  const char *file = "mattest.mat";
  char str[BUFSIZE];
  int status;
  printf("Creating file %s...\n\n", file);
  pmat = matOpen(file, "w");
  if (pmat == NULL) {
    printf("Error creating file %s\n", file);
    printf("(Do you have write permission in this directory?)\n");
    return(EXIT_FAILURE);
  pa1 = mxCreateDoubleMatrix(3,3,mxREAL);
  if (pa1 == NULL) {
      printf("%s : Out of memory on line %d\n", __FILE__,
              __LINE__);
      printf("Unable to create mxArray.\n");
  pa2 = mxCreateDoubleMatrix(3,3,mxREAL);
  if (pa2 == NULL) {
             __LINE__);
  memcpy((void *)(mxGetPr(pa2)), (void *)data, sizeof(data));
  pa3 = mxCreateString("MATLAB: the language of technical
                         computing");
  if (pa3 == NULL) {
              __LINE__);
      printf("Unable to create string mxArray.\n");
  status = matPutVariable(pmat, "LocalDouble", pa1);
  if (status != 0) {
      printf("%s :  Error using matPutVariable on line %d\n",
              __FILE__, __LINE__);
  status = matPutVariableAsGlobal(pmat, "GlobalDouble", pa2);
  if (status != 0) {
      printf("Error using matPutVariableAsGlobal\n");
  status = matPutVariable(pmat, "LocalString", pa3);
  if (status != 0) {
   * Ooops! we need to copy data before writing the array.  (Well,
   * ok, this was really intentional.) This demonstrates that
   * matPutVariable will overwrite an existing array in a
MAT-file.
  memcpy((void *)(mxGetPr(pa1)), (void *)data, sizeof(data));
  if (status != 0) {
  /* Clean up. */
  mxDestroyArray(pa1);
  mxDestroyArray(pa2);
  mxDestroyArray(pa3);
  if (matClose(pmat) != 0) {
    printf("Error closing file %s\n",file);
  /* Re-open file and verify its contents with matGetVariable. */
  pmat = matOpen(file, "r");
  if (pmat == NULL) {
    printf("Error reopening file %s\n", file);
  /* Read in each array we just wrote. */
  pa1 = matGetVariable(pmat, "LocalDouble");
  if (pa1 == NULL) {
    printf("Error reading existing matrix LocalDouble\n");
  if (mxGetNumberOfDimensions(pa1) != 2) {
    printf("Error saving matrix: result does not have two
            dimensions\n");
  pa2 = matGetVariable(pmat, "GlobalDouble");
  if (pa2 == NULL) {
    printf("Error reading existing matrix GlobalDouble\n");
  if (!(mxIsFromGlobalWS(pa2))) {
    printf("Error saving global matrix: result is not global\n");
  pa3 = matGetVariable(pmat, "LocalString");
  if (pa3 == NULL) {
    printf("Error reading existing matrix LocalString\n");
  status = mxGetString(pa3, str, sizeof(str));
  if(status != 0) {
      printf("Not enough space. String is truncated.");
  if (strcmp(str, "MATLAB: the language of technical
             computing")) {
    printf("Error saving string: result has incorrect
            contents\n");
  /* Clean up before exit. */
  printf("Done\n");
  return(EXIT_SUCCESS);
希望对你有帮助哦
发表于 2006-12-21 11:41 | 显示全部楼层
原帖由 cattle421 于 2006-12-20 20:12 发表
没有记错的话,matlab中有相应的函数读取,搜索一下版面吧
 楼主| 发表于 2006-12-21 14:39 | 显示全部楼层
多谢各位,VC我不是太懂,楼上的方法我试过好像只能存为matlab M-file,没有Matlab data file
发表于 2006-12-21 14:58 | 显示全部楼层
用wavread函数读进来,然后再save成dat文件应该没有问题啊
 楼主| 发表于 2006-12-22 13:13 | 显示全部楼层
“然后再save成dat文件应该没有问题啊”
请问楼上,这句话用语句怎么写?
发表于 2006-12-22 15:17 | 显示全部楼层
原帖由 cattle421 于 2006-12-22 13:13 发表
请问楼上,这句话用语句怎么写?
比如你的数据在矩阵a中
save('a.mat',a)
数据就保存在当前工作目录下的a.mat文件里了
 楼主| 发表于 2006-12-23 16:24 | 显示全部楼层
请问楼上,这句话用语句怎么写?
这个就是我题目上说的啊,存为的是matlab M-file,好像不是Matlab data file
不知道是我概念不清还是这两个就是一回事?
发表于 2006-12-23 22:07 | 显示全部楼层
.mat 好象是数据文件哦
只能按照特定的数据结构写吧?
发表于 2006-12-24 21:57 | 显示全部楼层
原帖由 mulan 于 2006-12-22 15:17 发表
比如你的数据在矩阵a中
save('a.mat',a)
应该是save('a.mat','a')
发表于 2007-2-28 13:22 | 显示全部楼层
请问如何在VC++中将wave文件格式转换成数组呢,然后怎么写成.mat格式呢??
GMT+8, 2024-10-3 17:09 , Processed in 0.059987 second(s), 19 queries , Gzip On.
