查看: 4175|回复: 6
[结构分析] 达人帮忙看看我这个模型问题出在哪儿
发表于 2006-12-5 13:27 | 显示全部楼层 |阅读模式
这是一个分析充液双层壳的模态分析模型,两端简支。
/prep7
et,1,shell63
et,2,fluid30
r,1,0.005
mp,ex,1,1.92e11
mp,prxy,1,0.3
mp,dens,1,7800
mp,sonc,2,1400
mp,dens,2,1000
cyl4,,,0.06,,0.1
l,1,6
l,2,8
l,3,7
l,4,5
lsel,s,,,9
lsel,a,,,10
lsel,a,,,11
lsel,a,,,12
cm,sublines,line
asbl,1,sublines
numcmp,all
csys,1
lsel,s,loc,x,0.06
lsel,a,loc,x,0.1
lesize,all,,,10
lsel,s,loc,x,0.08
lesize,all,,,3
allsel
type,1
mat,1
real,1
amesh,all
csys,0
k,20,
k,21,0,0,1
l,20,21
esize,0.02
type,2
mat,2
vdrag,1,2,3,4,,,13
csys,1
asel,s,loc,x,0.06
asel,a,loc,x,0.1
asel,a,loc,z,1
asel,a,loc,z,0
cm,fsi,area
type,1
mat,1
amesh,all
csys,0
allsel
finish
/solu
antype,2
modopt,unsym,10
eqslv,front
mxpand,10,,,1
nsel,s,loc,z,0
nsel,a,loc,z,1
d,all,,0,,,,ux,uy,uz
allsel
sfa,fsi,,fsi
allsel
solve
finish
执行之后出现的警告和提示:
*** WARNING ***                         CP =     293.000   TIME= 12:22:08
Real constant 1 referenced by at least element types 1 and 2.
*** WARNING ***                         CP =     320.641   TIME= 12:22:41
Coefficient ratio exceeds 1.0e8 - Check results.
*** WARNING ***                         CP =     525.703   TIME= 12:26:12
There are 1 positive pivots with ratios less than 1.E-13 indicating a
possible poorly conditioned stiffness matrix.
*** WARNING ***                         CP =     570.250   TIME= 12:27:24
Lanczos recursions terminated after 3 vectors.  Apply a new shift
(FREQB) using MODOPT command and re-run for additional eigenvalues of
the problem.
There are no solutions in the selected range.
*** ERROR ***     SUPPRESSED MESSAGE    CP =     570.250   TIME= 12:27:29
Mode file does not exist.
不知道出了什么问题,怎么得不到结果。。。。
发表于 2006-12-5 19:08 | 显示全部楼层
我也遇到过
同求高手指点
 楼主| 发表于 2006-12-5 20:01 | 显示全部楼层
无计可施了,折腾了几遍还是解决不了,望高手帮忙看看~~
 楼主| 发表于 2006-12-6 09:52 | 显示全部楼层
自己顶哈,期待解答~
发表于 2006-12-6 10:56 | 显示全部楼层
这个机子上没装ansys,你的警告应该是网格的质量太差导致的
以前遇到过求解后没有模态结果的情况,我请教过别人
他们给我的建议是:改变初始频率后,就可能会解决了。我的就是这样解决的,但是原因我也没搞懂
发表于 2006-12-6 11:51 | 显示全部楼层
the problem.
这两条说的就是网格差,刚度矩阵不合理以及更改频率重新计算
 楼主| 发表于 2006-12-6 16:19 | 显示全部楼层
原帖由 bangder_ing 于 2006-12-6 10:56 发表
恩,确实,改变初始频率才能得到结果~
期待高人解释原因~
GMT+8, 2025-1-30 11:14 , Processed in 0.092697 second(s), 17 queries , Gzip On.
