查看: 4262|回复: 15
[前后处理] 大家看看我的模态分析结果为什么这么大,十分感谢!
发表于 2006-11-20 11:27 | 显示全部楼层 |阅读模式
这是我的分析结果:
SET   TIME/FREQ    LOAD STEP   SUBSTEP  CUMULATIVE
     1  1162.1             1         1         1
     2  1335.4             1         2         2
     3  1495.2             1         3         3
     4  1636.8             1         4         4
     5  1783.0             1         5         5
     6  2096.7             1         6         6
     7  2416.0             1         7         7
     8  2628.4             1         8         8
     9  2775.6             1         9         9
    10  2959.3             1        10        10
我用GUI操作的,提取的命令流:(可能有多余的命令,怕删错了,各位见谅)谢谢!
/BATCH
/input,start90,ans,'C:\Program Files\Ansys Inc\v90\ANSYS\apdl\',,,,,,,,,,,,,,,,1
/inp,bzling,anf
WPSTYLE,,,,,,,,0
~PROEIN,bzling,asm.5,,proewildfire,0,1
/NOPR
/GO
/NOPR
/PMETH,OFF,0
KEYW,PR_SET,1
KEYW,PR_STRUC,1
KEYW,PR_THERM,0
KEYW,PR_FLUID,0
KEYW,PR_ELMAG,0
KEYW,MAGNOD,0
KEYW,MAGEDG,0
KEYW,MAGHFE,0
KEYW,MAGELC,0
KEYW,PR_MULTI,0
KEYW,PR_CFD,0
/GO
ET,1,SOLID92
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2.2e11
MPDATA,PRXY,1,,0.3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,7800
VDELE,      10
FLST,2,3,6,ORDE,3
FITEM,2,2
FITEM,2,-3
FITEM,2,6
VDELE,P51X
VDELE,       5
VDELE,       9
VDELE,       8
VDELE,       7
VDELE,       1
FLST,2,1,6,ORDE,1
FITEM,2,4
VLSCAL,P51X, , ,0.1,0.1,0.1, ,1,1
FLST,2,1,6,ORDE,1
FITEM,2,4
FLST,2,1,6,ORDE,1
FITEM,2,4
VSUM, DEFAULT
MSHKEY,0
MSHAPE,1,3d
CM,_Y,VOLU
VSEL, , , ,       4
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/PREP7
FINISH
/PREP7
FINISH
/SOL
ANTYPE,2
MSAVE,0
MODOPT,LANB,10
EQSLV,SPAR
MXPAND,10, , ,0
LUMPM,0
PSTRES,0
MODOPT,LANB,10,0,0, ,OFF
MSAVE,0
MODOPT,LANB,10
EQSLV,SPAR
MXPAND,10, , ,0
LUMPM,0
PSTRES,0
FLST,2,1,5,ORDE,1
FITEM,2,129
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,130
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,131
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,132
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,133
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,134
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,127
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,128
/GO
DA,P51X,ALL,
SOLVE
FINISH
/POST1
SET,LIST
FINISH
/SOLU
FINISH
/PREP7
VCLEAR,       4
FINI
FINISH
/POST1
SET,LIST
SET,FIRST
FINISH
/RUN
FINISH
/AUX12
FINISH
/PDS
FINISH
/OPT
FINISH
/POST26
FILE,'1','rst','.'
/UI,COLL,1
NUMVAR,200
SOLU,191,NCMIT
STORE,MERGE
FILLDATA,191,,,,1,1
REALVAR,191,191
FINISH
/POST1
FINISH
/POST26
NUMVAR,200
FILLDATA,191,,,,1,1
REALVAR,191,191
FINISH
/POST1
FINISH
/SOL
十分感谢,我做的是一个底座抗震的模态分析
发表于 2006-11-20 23:17 | 显示全部楼层
现在直接看这种代码比较费尽,如果精简以下就比较清楚了。
你的代码中有很多多于的,比如KEYW,PR_THERM,0
KEYW,PR_FLUID,0
KEYW,PR_ELMAG,0
KEYW,MAGNOD,0
KEYW,MAGEDG,0
KEYW,MAGHFE,0
KEYW,MAGELC,0
KEYW,PR_MULTI,0
KEYW,PR_CFD,0
/GO
都可不要,还有很多不需要。
而且你的模型是通过导入的,我们不知道你的模型也帮不了你啊。
[ 本帖最后由 ForCan2008 于 2006-11-20 23:25 编辑 ]
 楼主| 发表于 2006-11-22 13:37 | 显示全部楼层
因为我不是用命令流做得,而且我也不大清楚那些应该删掉,如果我把模型传上来是不是就可以有助于分析?
发表于 2006-11-22 23:30 | 显示全部楼层
首先应该看看单位错了没有 再考虑别的因素
 楼主| 发表于 2006-11-23 15:03 | 显示全部楼层
单位没有错,都是国际单位制
发表于 2006-11-24 09:41 | 显示全部楼层
你这个程序不全啊,我ansys运行不了,不能帮你了
太多不用的命令在里面看的累
发表于 2006-11-24 14:02 | 显示全部楼层
就象forcan说的,命令中模型是proe导入的,命令流中没有模型根本就没法运行。
 楼主| 发表于 2006-11-28 14:20 | 显示全部楼层
要是我把我的模型附件添加,可不可以?
发表于 2006-11-28 15:19 | 显示全部楼层
什么东西?
要是发动机叶片的话,第一阶2000hz左右很正常啊。
发表于 2006-11-28 16:05 | 显示全部楼层
这是可能的.
 楼主| 发表于 2006-12-3 09:40 | 显示全部楼层
是一个齿轮泵的底座的抗震的分析,核电站的,那样的太大的可能不好吧?
 楼主| 发表于 2006-12-3 10:00 | 显示全部楼层
模型
底座的模型
底座的模型
发表于 2006-12-3 22:13 | 显示全部楼层
也不算很离谱,如果单位和材料常数没错的话,算出来多少就是多少,嗯
发表于 2006-12-8 19:41 | 显示全部楼层
1000hz,我感觉不是很大吧。如果操作没有问题的话,结果还是可信的
 楼主| 发表于 2006-12-11 09:27 | 显示全部楼层
看来只能这样了,谢谢各位
GMT+8, 2025-1-30 11:21 , Processed in 0.094423 second(s), 22 queries , Gzip On.
