查看: 2543|回复: 0
[结构分析] 求助:LS-DYNA算了一定的时间总是报错,帮忙看一下,谢了!
发表于 2006-11-19 14:35 | 显示全部楼层 |阅读模式
The LS-DYNA time step size should not exceed     0.780E-06
to avoid contact instabilities.  If the step size is
bigger then scale the penalty of the offending surface.
       0 t 0.0000E+00 dt 0.00E+00 flush i/o buffers
       1 t 0.0000E+00 dt 5.03E-07 flush i/o buffers
       1 t 0.0000E+00 dt 5.03E-07 write d3plot file
       1 t 0.0000E+00 dt 5.03E-07 write ANSYS result file
    5000 t 2.5150E-03 dt 5.03E-07 flush i/o buffers
   10000 t 5.0305E-03 dt 5.03E-07 flush i/o buffers
   12920 t 6.4996E-03 dt 5.03E-07 write d3plot file
   12920 t 6.4996E-03 dt 5.03E-07 write ANSYS result file
   15000 t 7.5481E-03 dt 5.03E-07 flush i/o buffers
   20000 t 7.8478E-03 dt 1.09E-08 flush i/o buffers
*** Error negative volume in brick element #   13432 cycle   22652
******** minimum time step size reached *********
On a restart minimum timestep will be  0.000E+00
   22652 t 7.8757E-03 dt-5.63E-07 write d3plot file
   22652 t 7.8757E-03 dt-5.63E-07 write ANSYS result file
E r r o r   t e r m i n a t i o n
Memory required for explicit solution  :      2317139
Additional dynamically allocated memory:        29960
                                   Total:      2347099
T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Initialization ....... 0.0000E+00    0.00     0.0000E+00    0.00
  Element processing ... 1.6180E+03   98.42     1.6199E+03   98.49
  Binary databases ..... 1.0000E+00    0.06     8.7600E-01    0.05
  ASCII database ....... 1.0000E+00    0.06     1.2600E-01    0.01
  Contact algorithm .... 1.7000E+01    1.03     1.6665E+01    1.01
  Contact entities ..... 0.0000E+00    0.00     0.0000E+00    0.00
  Rigid bodies ......... 7.0000E+00    0.43     7.0990E+00    0.43
  Implicit Nonlinear ... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Lin. Alg. ... 0.0000E+00    0.00     0.0000E+00    0.00
  T o t a l s            1.6440E+03  100.00     1.6447E+03  100.00
Problem time       =    7.8757E-03
Problem cycle      =     22652
Total CPU time     =      1644 seconds (   0 hours 27 minutes 24 seconds)
CPU time per zone cycle  =      3151 nanoseconds
Clock time per zone cycle=      3153 nanoseconds
Number of CPU's     1
Start time   11/09/2006 23:00:12
End time     11/09/2006 23:27:42
Elapsed time     1650 seconds (   0 hours 27 minutes 30 seconds)
这个是massage里面报错的信息,哪位高手帮我看看,哪里出错了啊。
运行了27分钟就自己停下来了,是怎么回事啊? 是不是网格的划分有问题呢?
我是模拟一个物体撞击另一个物体,计算被撞物体的变形。就是按照一般的自由落体来考虑的。
谢谢!
GMT+8, 2025-1-16 02:45 , Processed in 0.067555 second(s), 18 queries , Gzip On.
