查看: 4828|回复: 27
[CFD及热分析] 有关ansys_cfx做无阀压电微泵的流固耦合分析(需要帮助)
发表于 2006-11-16 10:45 | 显示全部楼层 |阅读模式
我现在用ansys_cfx做无阀压电微泵的流固耦合分析, 建完模型后,导入cfx-pre中时,出现错误!!请斑竹能帮一下忙,看一看吗?
微泵图
微泵图
错误
错误
 楼主| 发表于 2006-11-16 10:48 | 显示全部楼层
!-----------------------------------element type-----------------------------------------
/prep7
et,3,fluid142,,,,1                         !3D Fluid element with diplacement DOF option
et,4,mesh200,6        !Mesh only element (3D quad 4 nodes) to mesh surfaces used in CFXpre
!-------------------------------fluid domain geometry----------------------------------
CYL4, , , 3.5e-3,0,0,360                  ! draw a circle which r equal to 3.5e-3
K, 5,  3.4e-3,    -0.1e-3
K, 6,  7e-3,      -0.375e-3
K, 7,  7e-3,      -2.5e-3                ! draw 5, 6, 7, 8, 9,10, 11, 12 keypoints
K, 8,  8.5e-3,    -2.5e-3
K, 9,  8.5e-3,     2.5e-3
K, 10, 7e-3,       2.5e-3
k, 11, 7e-3,       0.375e-3
k, 12, 3.4e-3,  0.1e-3
a , 5, 6, 11, 12                           ! create a area from 5, 6, 11, 12 keypoints
a, 7, 8, 9, 10                            ! create a area from 7, 8, 9, 10
k, 13, -3.4e-3,   -0.375e-3
k, 14, -6.98e-3,   -0.1e-3
k, 15, -6.98e-3,  -2.5e-3
k, 16, -8.48e-3,   -2.5e-3                 ! draw 13, 14, 15, 16, 17, 18,19,20 keypoints
k, 17, -8.48e-3,   2.5e-3
k, 18, -6.98e-3,   2.5e-3
k, 19, -6.98e-3,   0.1e-3
k, 20, -3.4e-3,   0.375e-3
a, 13, 14, 19, 20                         !create a area named 4
a, 15, 16, 17, 18                         !create a area named 5
aadd,1,2,3,4,5
adele,all
lfillt, 21,28, 0.2e-3
lfillt, 24, 26, 0.2e-3                   ! create fillet between two lines which r=0.2e-3
lfillt, 31, 32, 0.2e-3
lfillt, 29,30, 0.2e-3
k, 27, -3e-3                            ! create a keypoint named 27
larc, 22, 23, 27, 3.5e-3                  ! create a arc through three keypoints
k, 28, 3e-3                             ! create a keypoint named 28
larc, 1, 5, 28, 3.5e-3                    !create a arc through three keypoints
al,5, 6, 21,22, 23, 24                    ! create a area named 1 by lines
al, 1, 2, 6, 9,10,11, 25, 26, 27, 28         !create a area named 2  by lines
al, 3,4,5,17, 18, 19, 29, 30, 31, 32         !create a area named 3 by lines
lplot, all
type, 3
mat, 3                                       !display all lines
lesi, 17, , ,10, 3,1
lesi, 19, , ,10,0.3,1
lesi, 3, , ,5, -3, 1
lesi, 4, , , 5, -3, 1
lesi, 32, , , 20, -5, 1
lesi, 30, , , 20, -5, 1
lesi, 22, , , 20, 0.2, 1
lesi, 21, , , 20, 0.2, 1
lesi, 23, , , 20, 0.2, 1
lesi, 24, , , 20, 0.2, 1                   ! specifies the divisions and spacing ratio on the lines
lesi, 1, , , 5, -3, 1
lesi, 2, , , 5, -3, 1
lesi, 28, , , 20, -5, 1
lesi, 26, , , 20, -5, 1
lesi, 11, , ,10, 0.3,1
lesi, 9, , ,10, 3,1
lesi,18, , ,20, 1, 1
lesi,31, , ,20, 1, 1
lesi,29, , ,20, 1, 1
lesi,5, , ,7, 1, 1
lesi,6, , ,7, 1, 1
lesi,25, , ,20, 1, 1
lesi,27, , ,20, 1, 1
lesi,10, , ,20, 1, 1
asel, s , , ,1
asel, a, , ,2
asel, a, , , 3
amesh, all
k, 29
k, 30, 0,0,2.0e-3
l, 29, 30
VDRAG,1,, , , , ,7,
K, 37
K, 38, 0, 0, 1.0e-3
L, 37, 38
VDRAG,2,, , , , ,38,
VDRAG,3,, , , , ,38,
Aplot
ldele, 7
ldele, 38
kdele,29, 30, 37, 38
!------------------------------FSI interface surface mesh----------------------------------
asel, s , , ,10
nsla, s, 1               !choose all entities below areas(include areas)
type,4                                !with mesh only elements
amesh,all                         !mesh the selected areas
cm,fsi,elem                           !Create component named fsi
allsel                              !choose all elements
asel, s , , ,29
cm,inlet ,elem                           !Create component named fsi
asel, s , , ,15
asel, s, , ,10
asel, a, , ,29
asel, a, , , 15
asel, inve
cm,wall ,elem                           !Create component named fsi
cdwrite,db,fluid,cdb                  !Create fluid.cdb file for CFXpre
finish
这是我写的建模和设置fsi的过程?是不是建模有问题?模型还可以简化吗?
 楼主| 发表于 2006-11-16 10:57 | 显示全部楼层
大家给提点建议吧?谢谢了,斑竹多帮帮忙了
 楼主| 发表于 2006-11-16 18:03 | 显示全部楼层
问题已经解决,过会把正确的命令流,发上来!共享
发表于 2006-11-16 19:27 | 显示全部楼层
发出来看看~~学习学习~
发表于 2006-11-16 23:38 | 显示全部楼层
说明一下问题以及解决的方法
 楼主| 发表于 2006-11-17 11:40 | 显示全部楼层
原理和ansys帮助文件里的压电微泵的例子是一样的,就是有压电效应使硅梁发生变形,从而使腔体体积发生变化,利用收缩管和扩散管原理,实现差量流动。实现微泵的泵送功能。
发表于 2006-11-17 13:46 | 显示全部楼层
问:帮助文件里的那个例子的振型图可有得到?
 楼主| 发表于 2006-11-17 15:32 | 显示全部楼层
硅片的只出现一个震荡,然后就是一条直线了,你做出来了吗?
发表于 2006-11-17 15:49 | 显示全部楼层
没有,结果和你描述的一样,郁闷~
 楼主| 发表于 2006-11-17 16:07 | 显示全部楼层
我发现结果文件比较小,不超过100兆。在结果中,应力的分布基本是一样的,相差不大。在流体的查看结果中,你得到的帮助文件的结果了吗?
 楼主| 发表于 2006-11-17 16:10 | 显示全部楼层
我的这个例子,在定义流固耦合界面时,有点错误。
发表于 2006-11-17 16:32 | 显示全部楼层
感觉mfx的例子很有问题~~太不够详细了~~
 楼主| 发表于 2006-11-17 16:47 | 显示全部楼层
如果有建模过程,就好了。你也做流固耦合吗?Qq:150973349, 有空可以交流一下
你流体的得到的结果,和例子给出的一样吗?
GMT+8, 2025-1-16 00:07 , Processed in 0.075144 second(s), 23 queries , Gzip On.
