查看: 2045|回复: 1
[求助]beam188单元不用加初应力吗?
发表于 2005-9-24 17:29 | 显示全部楼层 |阅读模式
用beam188单元分析结构失稳问题,打开iswrite,on,可输出的.ist文件,却没有初应力?不需要吗? <BR>
发表于 2005-9-24 21:38 | 显示全部楼层
回复:(olsieys)[求助]beam188单元不用加初应力吗?...
You can specify initial stress as a loading in ANSYS when doing a structural analysis. Initial stress loading is only allowed in a static or full transient analysis (the analysis can be linear or nonlinear). Initial stresses can be applied only in the first load step of an analysis. <BR><BR>This initial stress capability is only supported by the following element types: PLANE2, PLANE42, SOLID45, PLANE82, SOLID92, SOLID95, LINK180, SHELL181, PLANE182, PLANE183, SOLID185, SOLID186, SOLID187, BEAM188, and BEAM189.<BR>
GMT+8, 2025-1-16 19:56 , Processed in 0.057130 second(s), 17 queries , Gzip On.
