查看: 1465|回复: 2
[前后处理] 大家看看这是什么错误?
发表于 2006-11-3 19:21 | 显示全部楼层 |阅读模式
我在使用自适应网格重画时出现如下错误?
       1 t 0.0000E+00 dt 2.15E-08 flush i/o buffers
       1 t 0.0000E+00 dt 2.15E-08 write d3plot file
     463 t 9.9973E-06 dt 2.15E-08 write d3plot file
     928 t 1.9986E-05 dt 2.14E-08 write d3plot file
     928 t 2.0007E-05 dt 2.14E-08 write adaptivity stress file
expanding   memory to    25993093
    Remeshing surface mesh
    Minimum edge length = 4.00000E-01
    Maximum edge length = 1.00000E+00
    Volume before remeshing = 2.26528E+04
    Volume after remeshing  = 2.26525E+04
    Relative volume change  =-1.62956E-05
    Mesh generation of tet elements
    Mesh generation finished
expanding   memory to    26303989
contracting memory to           1
expanding   memory to     3002772
expanding   memory to     5985544
expanding   memory to     7158748
expanding   memory to    20608222
expanding   memory to    20638222
expanding   memory to    20698222
expanding   memory to    20718835
expanding   memory to    20739035
expanding   memory to    26904113
expanding   memory to    27098647
expanding   memory to    27293181
expanding   memory to    27487715
expanding   memory to    40892189
expanding   memory to    41086723
expanding   memory to    43032068
expanding   memory to    43226602
expanding   memory to    43421136
expanding   memory to    43810204
expanding   memory to    44006738
expanding   memory to    44186738
     928 t 2.0007E-05 dt 2.14E-08 increase bricks from  155448 to  744693
expanding   memory to        2387
expanding   memory to        9985
expanding   memory to     8388635
expanding   memory to    25422409
expanding   memory to    27656468
expanding   memory to    28401161
expanding   memory to    47670878
expanding   memory to    47672904
expanding   memory to    47673188
expanding   memory to    47722528
expanding   memory to    54254324
expanding   memory to    57466090
*** Error Input error found
*** Error reading sliding interface control card no.  1
     928 t 2.0007E-05 dt 2.14E-08 write d3plot file
E r r o r   t e r m i n a t i o n
这是什么错误呀?
我在仿真一塑料环套到钢环上,钢环有三瓣(120度一瓣)被塑料环束缚在一起,钢环前端受力,现在想仿真塑料环被撑断的过程,塑料环采用网格重画技术,但出现上面错误。他们之间用单面自动接触。
 楼主| 发表于 2006-11-4 22:11 | 显示全部楼层
希望达人指点,自己顶一个
 楼主| 发表于 2006-11-5 21:12 | 显示全部楼层
高手指点一下,急呀
GMT+8, 2025-1-16 01:37 , Processed in 0.078770 second(s), 17 queries , Gzip On.
