查看: 2080|回复: 6
[前后处理] 请高手帮我看看这个模态分析的命令流计算结果是什么?
发表于 2006-11-3 14:08 | 显示全部楼层 |阅读模式
命令流如下:请大家看一看,谢谢(本人刚开始学习),十分感谢!:@L已经修改了
/BATCH
/input,start90,ans,'C:\Program Files\Ansys Inc\v90\ANSYS\apdl\',,,,,,,,,,,,,,,,1
/inp,bzling,anf
WPSTYLE,,,,,,,,0
~PROEIN,bzling,asm.5,,proewildfire,0,1
/NOPR
/GO
/NOPR
/PMETH,OFF,0
KEYW,PR_SET,1
KEYW,PR_STRUC,1
KEYW,PR_THERM,0
KEYW,PR_FLUID,0
KEYW,PR_ELMAG,0
KEYW,MAGNOD,0
KEYW,MAGEDG,0
KEYW,MAGHFE,0
KEYW,MAGELC,0
KEYW,PR_MULTI,0
KEYW,PR_CFD,0
/GO
ET,1,SOLID92
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2.2e11
MPDATA,PRXY,1,,0.3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,7800
VDELE,      10
FLST,2,3,6,ORDE,3
FITEM,2,2
FITEM,2,-3
FITEM,2,6
VDELE,P51X
VDELE,       5
VDELE,       9
VDELE,       8
VDELE,       7
VDELE,       1
FLST,2,1,6,ORDE,1
FITEM,2,4
VLSCAL,P51X, , ,0.1,0.1,0.1, ,1,1
FLST,2,1,6,ORDE,1
FITEM,2,4
FLST,2,1,6,ORDE,1
FITEM,2,4
VSUM, DEFAULT
MSHKEY,0
MSHAPE,1,3d
CM,_Y,VOLU
VSEL, , , ,       4
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FINISH
/SOL
ANTYPE,2
EXPASS,0
MSAVE,0
MODOPT,LANB,5
EQSLV,SPAR
MXPAND,5, , ,0
LUMPM,0
PSTRES,0
MODOPT,LANB,5,0,0, ,OFF
FLST,2,1,5,ORDE,1
FITEM,2,127
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,128
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,129
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,130
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,131
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,132
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,134
/GO
DA,P51X,ALL,
FLST,2,1,5,ORDE,1
FITEM,2,133
/GO
DA,P51X,ALL,
FINISH
/POST1
SET,LIST
FINISH
/SOL
SOLVE
FINISH
/POST1
SET,LIST
SET,FIRST
/CWD,'E:\yx\design\ansys-design\bengti\xiaolunwen'
SET,LIST
FINISH
/SOL
SOLVE
FINISH
/POST1
SET,LIST
SET,FIRST
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,LAST
/CWD,'E:\yx\design\ansys-design\bengti\dalw'
SET,LIST
SET,LIST
FINISH
/SOL
ANTYPE,2
MSAVE,0
MODOPT,LANB,5
EQSLV,SPAR
MXPAND,5, , ,0
LUMPM,0
PSTRES,0
SOLVE
FINISH
/POST1
SET,LIST
SET,FIRST
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
/POST1
SET,LIST
[ 本帖最后由 dlxhong 于 2006-11-3 19:09 编辑 ]
发表于 2006-11-3 15:24 | 显示全部楼层
:@L没看明白,感觉不是命令流。是GUI操作了N次后把log文件贴过来了。
 楼主| 发表于 2006-11-3 19:11 | 显示全部楼层
已经修改了,麻烦再看一下
发表于 2006-11-3 19:12 | 显示全部楼层
把不必要的删除掉看来方便一些
发表于 2006-11-5 14:11 | 显示全部楼层
不知道你要问什么?
做了个模态分析,然后这里
/POST1
SET,LIST
SET,FIRST
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
SET,NEXT
是不是在查看振型之类的,问清楚点好回答啊!
发表于 2006-11-5 14:25 | 显示全部楼层
唉,太乱了,错误一大堆,改不了啊,你自己再改改吧。
 楼主| 发表于 2006-11-6 15:41 | 显示全部楼层
http://forum.vibunion.com/forum/thread-27520-1-14.html
这是我上次作的结果,差异很大,高手指点之后,我自己重做了几遍还是不正确。模态分析的结果太大。
我做的是底座的抗震分析。
麻烦各位了
GMT+8, 2025-1-16 02:01 , Processed in 0.108368 second(s), 17 queries , Gzip On.
