查看: 4829|回复: 6
[编程技巧] 执行时,提示Error: Missing variable or function.请问是什么原因.
发表于 2006-10-24 21:58 | 显示全部楼层 |阅读模式
clear;
%装入原图像1
load woman;
I=X;
%小波函数
type = 'db1';
% 2维离散Daubechies小波变换
[CA1, CH1, CV1, CD1] = dwt2(I,type);
C1 = [CH1 CV1 CD1];
%系数矩阵大小
[length1, width1] = size(CA1);
[M1, N1] = size(C1);
% 定义阈值T1
T1 =50;
alpha = 0.2;
%在图像中加入水印
for counter2 = 1: 1: N1
   for counter1 = 1: 1: M1
      if( C1(counter1, counter2) > T1 )
         marked1(counter1,counter2) = randn(1,1);
         NEWC1(counter1, counter2) = double( C1(counter1, counter2) ) +…
alpha * abs( double( C1(counter1, counter2) ) ) * marked1(counter1,counter2) ;
      else
         marked1(counter1, counter2) = 0;
         NEWC1(counter1, counter2) = double( C1(counter1, counter2) );
      end;
   end;
end;
%重构图像
NEWCH1 = NEWC1(1:length1, 1:width1);
NEWCV1 = NEWC1(1:length1, width1+1:2*width1);
NEWCD1 = NEWC1(1:length1, 2*width1+1:3*width1);
R1 = double( idwt2(CA1, NEWCH1, NEWCV1, NEWCD1, type) );
%分离水印
watermark1 = double(R1) - double(I);
figure(1);
subplot(1,2,1);
image(I);
axis('square');
title('原始图像');
subplot(1,2,2);
imshow(R1/250);
axis('square');
title('Daubechies小波变换后图像');
figure(2);
imshow(watermark1*10^16);
axis('square');
title('水印图像');
% 水印检测
newmarked1 = reshape(marked1, M1*N1, 1);
% 检测阈值
T2 = 60;
            if( NEWC1(counter1, counter2) >T2 )
               NEWC1X(counter1, counter2) = NEWC1(counter1, counter2);
            else
               NEWC1X(counter1, counter2) = 0;
            end;
        end;
      end;
NEWC1X = reshape(NEWC1X, M1*N1, 1);
correlation1 = zeros(1000,1);
for corrcounter = 1: 1: 1000
      if( corrcounter == 500)
       correlation1(corrcounter,1) = NEWC1X'*newmarked1 / (M1*N1);
      else
       rnmark = randn(M1*N1,1);
       correlation1(corrcounter,1) = NEWC1X'*rnmark / (M1*N1);
      end;
end;
% 计算阈值
originalthreshold = 0;
             if( NEWC1(counter1, counter2) > T2 )
               originalthreshold = originalthreshold + abs( NEWC1(counter1, counter2) );
             end;
         end;
  end;
originalthreshold = originalthreshold * alpha / (2*M1*N1);
corrcounter = 1000;
originalthresholdvector = ones(corrcounter,1) * originalthreshold;
figure(3);
plot(correlation1, '-');
hold on;
plot(originalthresholdvector, '--');
title('原始的加水印图像');
xlabel('水印');
ylabel('检测响应');
发表于 2006-10-24 22:10 | 显示全部楼层
改为
NEWC1(counter1, counter2) = double( C1(counter1, counter2) ) …
+alpha * abs( double( C1(counter1, counter2) ) ) * marked1(counter1,counter2) ;
 楼主| 发表于 2006-10-24 22:20 | 显示全部楼层
还是不行啊
发表于 2006-10-24 22:26 | 显示全部楼层
我是可以运行的
另外m文件命名不要用中文
11
11
22
22
发表于 2006-10-24 22:27 | 显示全部楼层
第3个图
33
33
发表于 2006-10-24 22:32 | 显示全部楼层
再把m文件也传上吧,再不行我就没办法了
Untitled.m
2.52 KB, 下载次数: 2
m文件
 楼主| 发表于 2006-10-24 22:35 | 显示全部楼层
这次可以了,万分感谢你
GMT+8, 2024-10-4 01:16 , Processed in 0.066498 second(s), 22 queries , Gzip On.
