查看: 1032|回复: 7
[编程技巧] 初学者问个问题
发表于 2006-10-24 15:05 | 显示全部楼层 |阅读模式
Error: Missing variable or function.
??? Error :while evaluating uimenu Callback.
在使用callback属性时,,就出现这样的错误,,这是为什么啊??
发表于 2006-10-24 15:16 | 显示全部楼层
给程序吧
 楼主| 发表于 2006-10-24 15:24 | 显示全部楼层
popcol=uicontrol(gcf,'Style','popup',...
    'String','red|blue|green|yellow',...
    'Position',[100 100 100 80],...
    'CallBack',['cbcol=["R","B","G","Y"];',...
    'set(gcf,"Color",cbcol(get(popcol,"Vaule")))']);
发表于 2006-10-24 17:34 | 显示全部楼层
  1. popcol=uicontrol(gcf,'Style','popup',...
  2.     'String','red|blue|green|yellow',...
  3.     'Position',[100 100 100 80]);
  4. set(popcol,'CallBack','callpopup(popcol)');
  1. function callpopup(popcol)
  2. cbcol=['R','B','G','Y'];
  3. set(gcf,'Color',cbcol(get(popcol,'value')))
 楼主| 发表于 2006-10-25 16:29 | 显示全部楼层
运行之后还是不行咯
??? Undefined command/function 'callpopup'.
??? Error while evaluating uicontrol Callback.
发表于 2006-10-25 16:33 | 显示全部楼层
代码没问题的
发表于 2006-10-25 16:35 | 显示全部楼层
将第二个保存为callpopup
在命令窗口输入第一个
应该没问题的
 楼主| 发表于 2006-10-26 17:11 | 显示全部楼层
可以了,,多谢,
GMT+8, 2024-10-4 01:24 , Processed in 0.060203 second(s), 20 queries , Gzip On.
