查看: 4820|回复: 17
zz:abaqus所有参考资料列表(整理好累啊)
发表于 2006-10-24 00:23 | 显示全部楼层 |阅读模式
zz::@)分享】abaqus所有参考资料列表!:@)
Available ABAQUS Documentation
The documentation for ABAQUS is extensive and complete. The complete set of ABAQUS manuals is described briefly below in addition to other documentation that is available for ABAQUS. The documentation and publications listed below are available from ABAQUS, Inc., unless otherwise specified, in printed and online form. ABAQUS online documentation is available in two forms:
"electronic books" installed through the ABAQUS installation procedure and viewed through a proprietary browser (DynaText); and  HTML documentation supplied on a separate CD, installed separately, and viewed through any supported web browser.  For more information on accessing the online books, refer to the discussion of execution procedures in the user's manuals. Pricing information for the printed documentation can be obtained through our Documentation Price List.
Every year, ABAQUS publishes the papers presented by users at the annual ABAQUS Users' Conference in a book of conference proceedings. These proceedings present the wide range of advanced topics that users analyze with ABAQUS. The proceedings are a good place to look if you want to see whether other analysts and researchers have done work similar to the work you wish to do. The online Users' Conference bibliography allows you to search the various proceedings for topics of interest to you.
Training Manuals
Getting Started with ABAQUS/Standard: Interactive Version
This document is a self-paced tutorial designed to help new users become familiar with using ABAQUS/CAE to create solid, shell, and framework models and ABAQUS/Standard to perform static and dynamic stress analysis simulations. It contains a number of fully worked examples that provide practical guidelines for performing structural analyses with ABAQUS.
Getting Started with ABAQUS/Explicit: Interactive Version
This document is a self-paced tutorial designed to help new users become familiar with using ABAQUS/CAE to create solid, shell, and framework models and ABAQUS/Explicit to perform quasi-static and dynamic stress analysis simulations. It contains a number of fully worked examples that provide practical guidelines for performing structural analyses with ABAQUS.
Getting Started with ABAQUS/Standard: Keywords Version
This online-only document is designed to help new users become familiar with the ABAQUS/Standard input file syntax for static and dynamic stress analysis simulations. The ABAQUS/Standard keyword interface is used to model the same examples as those included in Getting Started with ABAQUS/Standard: Interactive Version.
Getting Started with ABAQUS Explicit: Keywords Version
This online-only document is designed to help new users become familiar with the ABAQUS/Explicit input file syntax for quasi-static and dynamic stress analysis simulations. The ABAQUS/Explicit keyword interface is used to model the same examples as those included in Getting Started with ABAQUS/Explicit: Interactive Version.
Lecture Notes
Notes and workshops are available for many features and applications for which ABAQUS is used, such as metal forming and heat transfer. The notes are used in the technical seminars that are offered to help users improve their understanding and usage of ABAQUS. While they are not intended as stand-alone tutorial material, they are usually comprehensive enough that they can be used in that mode. The list of available lecture notes is included in the Documentation Price List.
User's Manuals
ABAQUS/Standard User's Manual
This is the ABAQUS manual that you will use most often with ABAQUS/Standard. Split into three volumes, it is a complete reference manual for all of the capabilities of the product.
ABAQUS/Explicit User's Manual
This is the ABAQUS manual that you will use most often with ABAQUS/Explicit. It is a two-volume complete reference manual for all of the capabilities of the product.
ABAQUS/CAE User's Manual
This reference document for ABAQUS/CAE includes three comprehensive tutorials as well as detailed descriptions of how to use ABAQUS/CAE for model generation, analysis, and results evaluation.
ABAQUS/ADAMS User's Manual
This document describes how to use ABAQUS/ADAMS, an interface program that creates ABAQUS models of ADAMS components and converts the ABAQUS results into an ADAMS modal neutral file that can be used by the ADAMS/Flex program. It is the basic reference document for the ABAQUS/ADAMS program.
ABAQUS/C-MOLD User's Manual
This document describes how to use ABAQUS/C-MOLD, an interface program that creates a partial ABAQUS input file by translating results from a C-MOLD plastics molding simulation. It is the basic reference document for the ABAQUS/C-MOLD program.
ABAQUS/MOLDFLOW User's Manual
This document describes how to use the interface program ABAQUS/MOLDFLOW, which creates a partial ABAQUS input file by translating results from a MOLDFLOW polymer processing simulation. It is the basic reference document for the ABAQUS/MOLDFLOW program.
Using ABAQUS Online Documentation
This online-only manual contains instructions on using the ABAQUS online documentation server.
ABAQUS Release Notes
This document contains brief descriptions of the new features available in the latest release of the ABAQUS product line.
ABAQUS Site Guide
This document describes how to install ABAQUS and how to configure the installation for particular circumstances. Some of the information, of most relevance to users, is also provided in the user's manuals.
Examples Manuals
ABAQUS Example Problems Manual
This volume contains more than 75 detailed examples designed to illustrate the approaches and decisions needed to perform meaningful linear and nonlinear analysis. Typical cases are large motion of an elastic-plastic pipe hitting a rigid wall; inelastic buckling collapse of a thin-walled elbow; explosive loading of an elastic, viscoplastic thin ring; consolidation under a footing; buckling of a composite shell with a hole; and deep drawing of a metal sheet. It is generally useful to look for relevant examples in this manual and to review them when embarking on a new class of problem.
ABAQUS Benchmarks Manual
This online-only volume contains over 200 benchmark problems and standard analyses used to evaluate the performance of ABAQUS; the tests are multiple element tests of simple geometries or simplified versions of real problems. The NAFEMS benchmark problems are included in this manual.
ABAQUS Verification Manual
This online-only volume contains more than 5000 basic test cases, providing verification of each individual program feature (procedures, output options, MPCs, etc.) against exact calculations and other published results. It may be useful to run these problems when learning to use a new capability. In addition, the supplied input data files provide good starting points to check the behavior of elements, materials, etc.
Reference Manuals
ABAQUS Keywords Manual
This volume contains a complete description of all the input options that are available in ABAQUS/Standard and ABAQUS/Explicit.
ABAQUS Theory Manual
This online-only volume contains detailed, precise discussions of all theoretical aspects of ABAQUS.
ABAQUS Scripting Manual
This online-only manual provides a description of the ABAQUS Scripting Interface. The manual describes how commands can be used to create and analyze ABAQUS/CAE models, to view the results of the analysis, and to automate repetitive tasks. It also contains information on using the ABAQUS Scripting Interface or C++ as an application programming interface (API).
ABAQUS Scripting Command Reference
This online-only manual provides a command reference that lists the syntax of each command in the ABAQUS Scripting Interface.
ABAQUS Input Files
This online-only manual contains all the input files that are included with the ABAQUS release and referred to in the ABAQUS Example Problems Manual, the ABAQUS Benchmarks Manual, and the ABAQUS Verification Manual. They are listed in the order in which they appear in the manuals, under the title of the problem that refers to them. The input file references in the manuals hyperlink directly to this book.
Quality Assurance Plan
This document describes QA procedures followed by ABAQUS. It is a controlled document, provided to customers who subscribe to either the Nuclear QA Program or the Quality Monitoring Service.
[ 本帖最后由 ydliu_zn 于 2006-10-24 00:25 编辑 ]
发表于 2006-10-24 00:31 | 显示全部楼层
版主这么辛苦,再鼓励一把,有这么负责人的版主,abaqus论坛人气一定会蒸蒸日上的
发表于 2006-10-25 18:03 | 显示全部楼层
相信版主的工作能得到大家的肯定
发表于 2006-10-28 11:55 | 显示全部楼层
支持整理工作,感谢版主!
发表于 2007-4-17 20:26 | 显示全部楼层
感谢版主!:handshake
这些帮助文档在那里去下载呢 ?
发表于 2007-4-18 09:46 | 显示全部楼层
大部分都是ABAQUS DOC中的
当然正版用户还会有这些书
很多很厚
一大箱
发表于 2007-5-6 17:11 | 显示全部楼层
原帖由 zyxie 于 2006-10-24 00:31 发表
:handshake :handshake   感谢版主
发表于 2007-5-16 19:02 | 显示全部楼层
鼓励下版主 辛苦了:@D
发表于 2007-5-18 14:55 | 显示全部楼层
鼓励下,辛苦版主 了:victory: :victory: :victory:
发表于 2012-6-26 15:02 | 显示全部楼层
呵呵,路过,看看
发表于 2012-7-2 10:44 | 显示全部楼层
版主辛苦啦!多谢多谢!高手!
发表于 2012-7-18 14:25 | 显示全部楼层
版主  想请教你个问题  模拟多次激光冲击,第一次先显示动态模拟后再导入静态进行回弹分析,那么想在这基础上进行第二次冲击模拟,怎样把第一次静态模拟后的结果导入到第二次的动态中啊?
发表于 2012-7-18 16:07 | 显示全部楼层
abqus相对于ansys bench哪一个要强大一些 啊?
发表于 2012-7-19 15:49 | 显示全部楼层
发表于 2013-11-18 20:10 | 显示全部楼层
我想要参考这个ABAQUS/CAE User's Manual,请问如何找到
GMT+8, 2024-11-17 11:47 , Processed in 0.071566 second(s), 19 queries , Gzip On.
