查看: 3277|回复: 0
[计算力学] [求助]用近似算法算得的简支平板的挠度比Levy的精确解小
发表于 2005-9-10 17:29 | 显示全部楼层 |阅读模式
A simple method consisting of a combination of the solutions given by the theory of small deflections and the membrane theory is used to get an approximate solution for a simply supported rectangular plate. the fornula of the approximate method is illustrated below. but the result i get from this formula is smaller than that from Levy's "exact solution". does anyone know why?
GMT+8, 2025-8-11 11:56 , Processed in 0.086568 second(s), 22 queries , Gzip On.
