查看: 2245|回复: 2
[求助]请教一个关于ansys建模的问题
发表于 2005-9-10 17:22 | 显示全部楼层 |阅读模式
Boolean operation failed. Try adjusting the tolerance value on the BTOL command to some fraction of the minimum keypoint distance. Model Size (current problem)4.451204e-002, current BTOL setting 1.000e-005, minimum KPT distance 5.984424e-006.<BR>想问下,这个问题该怎么处理,我想把两个体加在一起,该怎么设置才行? <BR>
发表于 2005-9-10 20:10 | 显示全部楼层
I am a real rookie on ansys.Im glad to exchange my view with everyone.
<P>Im glad  to exchange my view  with everyone.<BR>I'm sorry that i can't understand your problem clearlly on following two points:<BR>first,the exact location of the two poits of your solid  model in your problem<BR>second, IN ANSYS,THE POINT COINCIDENCE TOLERANCE CAN BE  ADJUSTED AUTOMATICALLY,BUT WHY DOESN'T IT WOK IN YOUR PROBLEM.<BR><BR><BR>SUGGESTION:MAY BE YOU CAN SET THE TORLERANCE A BIT LARGER.<BR><BR>I am a real rookie on ansys.</P>
发表于 2005-9-11 08:43 | 显示全部楼层
<P>另一个建议,检查你的几何模型,那里可能有问题。<BR><BR>如果不介意的话发一张图上来看看</P>
GMT+8, 2025-1-16 18:57 , Processed in 0.189218 second(s), 19 queries , Gzip On.
