查看: 1657|回复: 1
[综合讨论] 求教关于MCR的问题
发表于 2006-9-24 16:44 | 显示全部楼层 |阅读模式
使用VC和matlab混合编程,在VC中调用matlab生成的com组件,在自己的机子上编译等都已通过。换到另一台机子时(没有安装VC和matlab),我先安装MCRinstaller.exe,之后利用命令“regsvr32”,对matlab的com组件进行了注册,也显示注册成功,运行程序,当点击让其进行计算时,显示“MCR instance is not avileable”,请问高手这是什么原因造成的?是不是我没有使用将.dll和MCRinstaller.exe绑定在一起,在安装MCR的同时让其自动注册造成的?还是别的什么原因? :'(:'(:'(:'(:'(
[ 本帖最后由 ericlin 于 2006-9-24 16:54 编辑 ]
发表于 2006-9-25 07:36 | 显示全部楼层
Subject:
Why do I receive an "MCRInstance not available" error when deploying an application built with MATLAB Compiler 4.0 (R14)?
Problem Description:
I am trying to run a stand-alone application that was generated with the MATLAB Compiler. However, I receive the following error message when I call the program:
Solution:
This bug has been fixed in Release 14 Service Pack 2 (R14SP2). For previous releases, please read below for any possible workarounds:
This error may occur if the executable file cannot find either the required MATLAB run-time libraries or the CTF archive for your application.
First, check your system path to verify that the MATLAB run-time libraries can be found. If you are testing your application on a development Windows machine, confirm that $MATLAB\bin\win32, where $MATLAB is your root MATLAB directory, appears on your system path and ahead of any other MATLAB installations.
If you are working on a target Windows machine, verify that $MCR_ROOT\runtime\win32, where $MCR_ROOT is your root MATLAB Component Runtime directory, appears on your system path.
For help viewing or modifying the system path, see:
http://www.mathworks.com/support ... ml?solution=1-15ZLK
Next, verify that the .ctf archive file that the MATLAB Compiler generated in the build process resides in the same directory as your program's executable file.
GMT+8, 2024-10-4 03:24 , Processed in 0.064055 second(s), 19 queries , Gzip On.
