查看: 2481|回复: 3
单元输出问题的一个方法!
发表于 2006-9-10 19:18 | 显示全部楼层 |阅读模式
通常,我们输出单元应力应变的时候,默认的是单元积分点上的,但是有的时候我们可能会需要中点、节点的值,那么可以通过参数的选取简单的实现这个要求,而不需要自己去编制小程序去进行插值了(因为我曾经就遇到过这个问题).方法如下,仅供大家参考:
Set POSITION=AVERAGED AT NODES if the values being printed are the averages of values extrapolated to the nodes of the elements in the set. Since variables may be discontinuous between elements with different properties, ABAQUS/Standard breaks the output into separate tables for different element property definitions within the element set specified. ABAQUS/Standard will also output elements of differing types separately. Thus, averaging will occur only over elements that contribute to a node that have the same type.
Set POSITION=CENTROIDAL if values are being printed at the centroid of the element (the centroid of the reference surface of a shell element, the midpoint between the end nodes of a beam element).
Set POSITION=INTEGRATION POINTS (default) if values are being printed at the integration points at which the variables are actually calculated.
Set POSITION=NODES if the values being written are extrapolated to the nodes of each element in the set but not averaged at the nodes.
发表于 2006-11-2 19:21 | 显示全部楼层
还没有试过。
谢谢分享啊。
 楼主| 发表于 2006-11-30 17:31 | 显示全部楼层
对于一个八节点四个积分点的平面单元
用POSITION=INTEGRATION POINTS (default)计算的结果:
ELEMENT  PT FOOT-       EP1         EP2
                NOTE
          75   1        -1.7197E-04  2.9731E-04
          75   2        -5.6155E-04  4.4613E-05
          75   3        -3.6136E-04  7.1631E-04
          75   4        -7.2594E-04 -8.9712E-05
MAXIMUM               -1.7197E-04  7.1631E-04
ELEMENT                    75          75
MINIMUM               -7.2594E-04 -8.9712E-05
ELEMENT                    75          75
用POSITION=NODES 计算的结果:
   THE FOLLOWING TABLE IS PRINTED AT THE NODES FOR ELEMENT TYPE CPS8R AND ELEMENT SET
   ASSEMBLY_ELEMENT7
    ELEMENT         ND   FOOT-   SP1         SP2
                         NOTE
         212        707         -1.840       3.818
         212        709         -2.305       4.594
         212        753         -1.490       10.89
         212        751         -14.32       6.142
         212        708         0.6116       1.522
         212        732          1.344       4.500
         212        752         -1.714       2.326
         212        731         -5.267       2.168
MAXIMUM                  1.344       10.89
ELEMENT                       212         212
MINIMUM                 -14.32       1.522
ELEMENT                       212         212
可见,对于应力应变要求精细的情况下,这个输出方法非常的实用
发表于 2006-12-22 22:08 | 显示全部楼层
感谢分享
GMT+8, 2024-9-30 03:26 , Processed in 0.093435 second(s), 18 queries , Gzip On.
