查看: 1777|回复: 1
[前后处理] 大家帮忙看看这些错误和警告,是DYNA的,谢谢
发表于 2006-9-3 19:22 | 显示全部楼层 |阅读模式
*** Error line number 172645 contains improperly formatted data
           (This is line# 172645 of file
F:\76DYNA~1\765CC4~1\76DYNA~1.K)
--------------------------------------------------------------line# 172645 -----
   172632 2.630100798E+01 3.493054389G+02 0.000000000E+00       0       0
*** Error reading *NODE card.
*** Error in keyword command:
  172633 2.625614564E+01 3.493018195E+02 0.000000000E+00       0       0
           Check near line #  172646
           (This is line# 172646 of file
*** Warning The following lines will be skipped:
   1.   172634 2.621128329E+01 3.492982001E+02 0.000000000E+00       0
   2.   172635 2.616642095E+01 3.492945807E+02 0.000000000E+00       0
   3.   172636 2.612155861E+01 3.492909613E+02 0.000000000E+00       0
   4.   172637 2.607669626E+01 3.492873419E+02 0.000000000E+00       0
   5.   172638 2.603183392E+01 3.492837225E+02 0.000000000E+00       0
   6.   172639 2.598697157E+01 3.492801030E+02 0.000000000E+00       0
发表于 2006-9-6 06:30 | 显示全部楼层
文件中的数据格式有错误,按照按Kword格式,用文本编辑器编辑一下
GMT+8, 2025-1-16 06:55 , Processed in 0.065885 second(s), 17 queries , Gzip On.
