查看: 1798|回复: 3
[前后处理] 移动温度载荷计算方法
 关闭 [复制链接]
发表于 2006-9-2 17:50 | 显示全部楼层 |阅读模式
移动温度载荷计算方法
/com, units: SI, m - degree C - W - kg -sec - J
! Bi=h*dx/K = 60*0.002/51.9 = 0.0023 < 1
! F0 = ( Kdt ) / (rho*C*dx^2)
! assume F0= beta = 0.4
! dt = (beta*rho*C*dx^2)/K = 0.1179 (sec)
/title,transient analysis 2 (moving heat flux)
/filnam,transient-2
/triad,rbot
/prep7
wpstyle,,,,,,,,1
wpstyle,0.01,0.01,0,0.1,0.003,0,1,,5
blc4,0,0.1,0.1,-0.1 !0.1*0.1 m
cyl4,0.03,0.05,0.01
asba, 1, 2 !drill a hole
blc4,0.1,0.1,-0.01,-0.1
flst,2,2,5,orde,2
fitem,2,1
fitem,2,3
aovlap,p51x
wpstyle,,,,,,,,0
aplot
et,1,plane55
keyopt,1,1,0
keyopt,1,3,0 !2d plane problem
keyopt,1,4,0
keyopt,1,8,0
keyopt,1,9,0
!aisi 1045 steel
uimp,1,dens, , ,7870 , !kg/m3
uimp,1,kxx, , , 51.9 , !w/m-c
uimp,1,c, , , 486, !w-s / kg-c
type,1
mat,1
esize,0.002, !element size = 0.002 m
mshkey,1
amesh,1
mshkey,0
amesh,2
!boundary conditions
/psf,hflu, ,2,0
!convection
flst,2,1,4,orde,1
fitem,2,4
sfl,p51x,conv,50, ,25,
finish
/solu
antype,trans
trnopt,full
nropt,auto, ,
eqslv,
solcontrol,on
autots,on
kbc,1 !step
outres,all,all,
!load step 1, initial conditions 25 c
time,0.001
deltim,0.001,0.001,0.001
timint,off !time integration = off
tunif,25,
solve
!load step 2..... , apply moving heat flux
timint,on !time integration = on
j=1
*do,i,200,80,-5
time,j
deltim,0.11,0.11,0.11,
sfedele,i+5,2,hflux !delete heat flux of previous step
sfe,i,2,hflux, ,5/0.002/0.002, , , !apply heat flux, face 2 , 5 w
eplot
solve
j=j+1
*enddo
finish
/post1
/eface,1
set,last
plnsol,temp, ,0,
finish
发表于 2006-9-2 20:38 | 显示全部楼层
谢谢楼主分享,好东西,正好学习
发表于 2006-9-3 11:12 | 显示全部楼层
谢谢!学习中。。。。。
发表于 2007-4-26 22:51 | 显示全部楼层
谢谢啊!正是需要的时候!
GMT+8, 2024-10-3 02:26 , Processed in 0.061340 second(s), 19 queries , Gzip On.
