查看: 3774|回复: 6
能帮我看看这些错误是怎么回事吗?
发表于 2005-8-30 17:18 | 显示全部楼层 |阅读模式
<P><BR> *** WARNING ***                         CP=     10.685   TIME= 17:07:03<BR> Real constant 2 referenced by at least element types 4 and 2.           </P>
<P> *** WARNING ***                         CP=     10.826   TIME= 17:07:03<BR> Finer mesh required near center line for element 5957.                  </P>
<P> *** WARNING ***                         CP=     10.826   TIME= 17:07:03<BR> Finer mesh required near center line for element 5982.                  </P>
<P> *** WARNING ***                         CP=     10.826   TIME= 17:07:03<BR> Finer mesh required near center line for element 6007.                  </P>
<P> *** ERROR ***                           CP=     10.826   TIME= 17:07:03<BR> Negative radius on element 6257.       <BR><BR><BR>怎么处理?谢谢                                 </P>
发表于 2005-8-30 17:25 | 显示全部楼层
回复:(yuqiangliu)能帮我看看这些错误是怎么回事吗...
<P>应该是面的尺寸相差太大的原因造成的<BR><BR>用手动定义一下,然后再mesh看看</P>
发表于 2005-8-30 22:34 | 显示全部楼层
*** WARNING ***                         CP=     10.685   TIME= 17:07:03<br>Real constant 2 referenced by at least element types 4 and 2.   <br>两种单元类型共用同一个realconstant设定,你设置的时候有没有弄错?<br><br>*** WARNING ***                         CP=     10.826   TIME= 17:07:03<br>Finer mesh required near center line for element 5957. <br>单元尺寸太大了似乎。<br><br>*** ERROR ***                           CP=     10.826   TIME= 17:07:03<br>Negative radius on element 6257.       <br>只可能就是单元尺寸不合适带来的后果。<br><br>按visualsun建议的做吧
[此贴子已经被作者于2005-8-30 22:35:19编辑过]
 楼主| 发表于 2005-8-31 16:06 | 显示全部楼层
<P>感谢 非常  非常感谢!</P>
 楼主| 发表于 2005-8-31 16:13 | 显示全部楼层
请大家再帮我看看这个错误好吗?
<P>** WARNING ***                         CP=     15.653   TIME= 14:25:05<BR> Both solid model and finite element model boundary conditions have been <BR> applied to this model.  As solid loads are transferred to the nodes or  <BR> elements, they can overwrite directly applied loads.                    </P>
<P> *** WARNING ***                         CP=     17.645   TIME= 14:26:14<BR> Constraint from line 5 not transferred to undefined or unselected node  <BR> 253. </P>
<P> *** WARNING ***   SUPPRESSED MESSAGE    CP=     22.382   TIME= 14:31:15<BR> Node 6470 on element 2352 is unselected.             <BR><BR><BR>请问这些错误 我怎么处理啊?<BR>还有我分析一个房间的墙壁隔声效果?用2d分析  怎么加约束?是不是一定要加约束的啊?谢谢                                                     </P>
发表于 2005-8-31 16:40 | 显示全部楼层
*** WARNING ***   SUPPRESSED MESSAGE    CP=     22.382   TIME= 14:31:15<BR>Node 6470 on element 2352 is unselected.  <BR>unselected node 在分析中会被剔除掉,所以在solve之前,要把所有有关的node,element 选择上。<BR><BR>** WARNING ***                         CP=     15.653   TIME= 14:25:05<BR>Both solid model and finite element model boundary conditions have been <BR>applied to this model.  As solid loads are transferred to the nodes or  <BR>elements, they can overwrite directly applied loads. <BR>所有施加在实体上的载荷在求解之前会被ansys转化为节点载荷,所以在模型中如果同时施加实体载荷和节点或单元载荷,就需要注意两者不要冲突了。实体载荷是在直接施加的节点载荷之后进行处理的,所以会把直接施加的节点载荷覆盖掉。<BR><BR><BR>建议你提问的时候把题目写清楚,这样方便别人也方便你自己。
 楼主| 发表于 2005-9-1 07:24 | 显示全部楼层
<STRONG><FONT face=Verdana color=#da2549>FSI 谢谢你  下次我会把题目尽量写清楚。谢谢的热情回答</FONT></STRONG>
GMT+8, 2025-1-16 19:54 , Processed in 0.070903 second(s), 17 queries , Gzip On.
