查看: 14200|回复: 30
[转子动力学] [推荐]给大家推荐一本转子动力学的书
 关闭 [复制链接]
发表于 2005-8-28 17:12 | 显示全部楼层 |阅读模式
Rotordynamics (Mechanical Engineering (Marcell Dekker)) (Hardcover)
by AGNIESZKA MUSZYNSKA
我想搞转子动力学的人不用看介绍,看看作者就应该知道不会差吧
[em01]
作者花了两年时间写的,两个月前刚刚出版,我也是在一次向作者请教问题的时候获知这个消息的,前几天刚刚拿到书。
全书总共1116页,价格高点$169.95加上有邮寄费,大概折合人民币1500多,有条件的可以考虑一下。
下面介绍一下作者。
 楼主| 发表于 2005-8-28 17:15 | 显示全部楼层
回复:(aspen)[推荐]给大家推荐一本转子动力学的书
Agnieszka (Agnes) Muszynska
Dr. Agnieszka (Agnes) Muszynska is a native of Warsaw, Poland. She received her B.S. and M.S. degrees in Mechanical Engineering from the Technical University of Warsaw (M.S. in March 1960). Two years of her undergraduate studies were completed in Moscow, USSR, at Bauman Technical University. Dr. Muszynska has received her Ph.D. in Technical Sciences (October 1966) and the second level Ph.D. (habilitation, May 1977), both from the Polish Academy of Sciences. In 1998 she was awarded the highest professional degree, Professor of Technical Sciences by the President of Poland, Aleksander Kwasniewski. Dr. Muszynska is fluent in Polish, English, Russian, and French.
In February 2000 Dr. Muszynska started her own business: she created a consulting firm "A.M. Consulting." Between October 2000 and March 2001 she worked on a contract at the Institute of Robotics of the Swiss Federal Institute of Technology in Zurich, Switzerland. Her consulting work there concerned the "Rotor/Retainer Bearing Dynamics."
During the years 1981 - 1999 Dr. Muszynska worked as a Senior Research Scientist and Research Manager at Bently Nevada Corporation (BNC) and its subsidiary, Bently Rotor Dynamics Research Corporation (BRDRC). During these 18 years Dr. Muszynska conducted theoretical and experimental research on Rotating Machine Dynamics, participated as a lecturer in BNC technical training programs, and was a Member of BRDRC Board of Directors. In 1997 she served also as a Member of the BNC Board of Directors.
Bently Nevada Corporation is a manufacturer of electronic hardware and software instrumentation for vibration monitoring on machinery. Its subsidiary, BRDRC, was created in 1982 to enhance theoretical knowledge on machine dynamic behavior leading to mechanical vibrations. The vibrations occur as side effects of the main machine processes. The enhancements developed by Dr. Muszynska's contributions led BNC instrumentation to more efficient technological definition: today the instrumentation not only serves for measuring machine vibration, but also as the diagnostic and prognostic tool in machine maintenance. The knowledge-based link between vibration causes and effects led to preventive measures, thus to the development of machine vibration control technology. Dr. Muszynska brought to Bently Nevada Corporation an academic excellence in the area of Mechanical Engineering's Dynamics of Rotating Machinery. Dr. Muszynska maintains friendly relationship with BNC.
Prior to joining BNC, Dr. Muszynska held an Associate Professorship at the Institute of Fundamental Technological Research of the Polish Academy of the Sciences, where she conducted research on vibrations and machine dynamics. She also taught post-graduate classes on Vibration and Mechanical System Stability from 1967 through 1979.
From 1975 to 1977, she was a Visiting Professor at the National Institute of Applied Sciences in Lyon, France, where she taught Mechanics and Machine Dynamics and wrote a Student Manual on this subject. She was a Visiting Scientist at the University of Dayton, Ohio, from January 1980 through June 1981, during which time she worked on a contract for Wright Patterson Air Force Base involving Vibration Control of Turbomachinery Blades. She also taught the class on Dynamics of Rotating Machinery to the University of Dayton graduate students.
During her career, Dr. Muszynska has authored or co-authored over 250 technical papers on Mechanical Vibration Theory, Nonlinear Vibrations, Vibration Control, and Rotating Machine Dynamics and Vibrational Diagnostics. Her major contributions consist of the introduction of modal modeling to such systems as machinery rotors in fluid environment. Her other contributions are in stability theory of mechanical systems, in vibration control, and in bladed disk dynamics. She introduced adequate models of such phenomena as rotor-to-stator rubbing, looseness in rotor systems, lateral/torsional vibrations of rotors. Based on experimental results obtained together with Donald E. Bently, she published in 1986 the consistent theory of instability of machine shafts rotating in fluid environment. Its simplified version is now accepted as Bently Nevada training standard. Also working with Bently, she formalized and popularized application of modal testing of rotating systems with fluid interaction, as well as the implementation of the Solid/Fluid System Dynamic Stiffness concept. The experimental discovery and adequate modeling of the second and higher modes of the rotor instability phenomena - fluid whirl and fluid whip is one of her significant achievements.
Several of Dr. Muszynska's publications were nationally recognized: Dr. Muszynska's paper on Modal Analysis of Rotating Machines received the "Best Paper of the Year 1986" award from the American Society for Experimental Mechanics. Also, the report from research on Influence of Rubbing on Rotordynamics, on which Dr. Muszynska was principal researcher, has been given an award by NASA in the category of Invention/New Technology. Dr. Muszynska's paper, Stability and Instability of a Two-Mode Rotor Supported by Two Fluid-Lubricated Bearings, co-authored by J. Grant, received the "Best Paper of the Year 1991" award from the American Society of Mechanical Engineers (ASME) Gas Turbine Division, Structures & Dynamics Committee.
Dr. Muszynska served as the Scientific/Technical Editor of several books, such as Polish Academy of Science's Yearly Journal "Nonlinear Vibration Problems" (1967 - 1980), Machine Dynamics (PASci, 1974), Vibration Control (PASci, 1978), Instability in Rotating Machinery (NASA, 1985), Rotating Machinery Dynamics (ASME, 1987), Don Bently Through the Eyes of Others (Bird Rock Publishing House, 1995).
Dr. Muszynska has traveled extensively, actively participating in numerous scientific conferences, giving lectures at courses and university seminars in Europe, North America, Asia, Africa, and Australia. She has also organized or co-organized many international scientific meetings, such as the Second and the Sixth International Conferences on Nonlinear Oscillations (Warsaw 1962, Pozna?1972, Poland), workshops on Machine Dynamics (Jablonna, Poland, 1978, 1979), the International Symposium on Instability in Rotating Machinery (Carson City, Nevada, June 1985), the Session on Rotating Machinery Dynamics at the 11th Biennial ASME Design Engineering Division Conference on Vibration and Noise (Boston, Massachusetts, September 1987), the Second, Third, Fourth, Fifth, and Sixth International Symposia on Transport Phenomena, Dynamics, and Design of Rotating Machinery (Honolulu, Hawaii, 1988, 1990, 1992, 1994, 1996), and the Rotor Dynamic Session at the ASME Turbo Expo 1994 Land, Sea, and Air (The Hague, Netherlands, 1994). In 1996, Dr. Muszynska became the Chairperson of the Organizing Committee for the Seventh International Symposium on Transport Phenomena and Dynamics of Rotating Machinery, Honolulu, HI, 1998. She organized a well-received and very successful symposium for over 200 international participants, and was the Scientific Editor of the more than 1800-page Symposium Proceedings (printed and CD ROM versions).
In 1985 she was a part-time Associate Professor at the University of Nevada in Reno (UNR) and a Faculty Member of the UNR College of Engineering (1985-1989). In 1985 she lectured to UNR students on Mechanical System Vibrations.
Dr. Muszynska is a member of the ASME, the American Academy of Mechanics, the Polish Institute of Arts & Sciences of America, and Rotary International Club. In 1986-88, she was a member of the ASME Technical Committee on Vibration and Sound. From 1988 to 1994, Dr. Muszynska served as an Associate Editor of the Transactions of the ASME Journal of Vibrations and Acoustics. She is a currently member of the ASME Structures & Dynamics Committee and the Regional Editor of the International Journal of Rotating Machinery.
In 1994 Dr. Muszynska received the prestigious grade of Fellow in the American Society of Mechanical Engineers.
Dr. Muszynska received the 1996 Distinguished Research Award for Research Achievements in the Field of Rotating Machinery from the Pacific Center of the Thermal Fluid Engineering.
Dr. Muszynska was honored as the "Woman Entrepreneur of the Year 1997" by the Douglas County Republican Women's Club.
Dr. Muszynska was honored by the International Biographical Centre Cambridge, UK, as an "International Woman of the Year 1999/2000." Dr. Muszynska is also listed in the publications Marquis Who's Who in American Women, Who's Who in Polish-American, Marquis Who's Who in America -- Science and Engineering, and Marquis Who's Who in the World.
 楼主| 发表于 2005-8-28 17:16 | 显示全部楼层
List of Publications
  • Muszynska, A., Muszynski, J., ON A CERTAIN CRITERION OF THE BOUNDEDNESS OF SOLUTIONS OF PSEUDOLINEAR SECOND ORDER DIFFERENTIAL EQUATION WITH PARTIALLY NEGATIVE DISSIPATION, Nonlinear Vibration Problems (NVP), Polish Academy of Sciences (PASci), No. 6, Warsaw 1964, pp. 41-57 (in Russian).
  • Muszynska, A., Muszynski, J., ON THE BOUNDEDNESS OF SOLUTIONS OF PSEUDOLINEAR EQUATIONS WITH PARTIALLY NEGATIVE DISSIPATION AND ELASTICITY, Proceedings of the 3rd Conference on Nonlinear Vibrations, Berlin 1964; also Nonlinear Vibration Problems (NVP), No. 6, Warsaw 1966, pp. 56-62 (in Russian).
  • Muszynska, A., ON THE BOUNDEDNESS OF SOLUTIONS OF A NONLINEAR SYSTEM WITH TWO DEGREES OF FREEDOM, Nonlinear Vibration Problems (NVP), PASci, No. 7, Warsaw 1965, pp. 225-232 (in Russian).
  • Muszynska, A., VIBRATIONS OF CERTAIN TYPE STRONGLY NONLINEAR, UNBALANCED ELASTICALLY SUPPORTED ROTATING SYSTEMS, Ph. D. Thesis, Institute of Fundamental Technological Research of the Polish Academy of Sciences, Warsaw 1966, pp. 1-130 (in Polish).
  • Muszynska, A., ON THE BOUNDEDNESS OF SOLUTIONS OF A SYSTEM OF DIFFERENTIAL EQUATIONS WITH GYROSCOPIC COUPLING, Godisnik Na VTUZ, Matematika, v. 3, No. 2, Sofia 1966, pp. 183-194 (in Russian).
  • Muszynska, A., ON THE "FUNDAMENTAL" PERIODIC SOLUTIONS FOR A NONLINEAR SYSTEM WITH TWO DEGREES OF FREEDOM, Nonlinear Vibration Problems (NVP), PASci, No. 8, Warsaw 1966, pp. 37-48 (in Russian).
  • Muszynska, A., ON THE STABILITY OF MOTION OF ROTATING SYSTEMS OF A CERTAIN KIND, Nonlinear Vibration Problems (NVP), PASci, No. 8, Warsaw 1966, pp. 111-118 (in Russian).
  • Muszynska, A., FORCED VIBRATIONS OF A CERTAIN MECHANICAL SYSTEM WITH TWO DEGREES OF FREEDOM, Nonlinear Vibration Problems (NVP), PASci, No. 8, Warsaw 1966, pp. 157-171 (in Russian).
  • Muszynska, A., ON THE PERIODIC SOLUTIONS OF A NONLINEAR SYSTEM WITH TWO DEGREES OF FREEDOM, Proceedings of the 3rd Conference of Linear and Nonlinear Vibrations, Poznan 1967, pp. 165-170 (in Polish).
  • Muszynska, A., ON PERIODIC SOLUTIONS OF CERTAIN NONLINEAR SYSTEM WITH TWO DEGREES OF FREEDOM, Revue Roumaine des Sci. Techn., s閞. M閏anique Appliqu閑, v. 12, No. 6, Bucurest 1967, pp.1309-1315 (in Russian).
  • Muszynska, A., ON MOTION OF THE ROTOR IN FLEXIBLE NONLINEAR BEARINGS, Institute of Fundamental Technological Research Report (IFTR)* Report, No. 19, Warsaw 1967, pp. 1-36.
  • Muszynska, A. ,PRECESSION OF THE HIGH SPEED CENTRIFUGE SUPPORTED ON BEARINGS WITH NONLINEAR CHARACTERISTICS AND PARTIALLY FILLED (WITH LIQUID) TANK, Nonlinear Vibration Problems (NVP), PASci, No. 9, Warsaw 1968, pp. 249-266 (in Russian).
  • Muszynska, A., CERTAIN PROBLEMS OF MECHANICAL SYSTEMS MODELLING, Nonlinear Vibration Problems (NVP), PASci, No. 9, Warsaw 1968, pp. 97-109 (in Polish).
  • Muszynska, A., STABILITY OF THE PERIODIC SOLUTIONS IN THE CASE OF AMPLITUDE NONUNIQUENESS, Nonlinear Vibration Problems (NVP), PASci, No. 9, Warsaw 1968, pp. 267-268 (in Russian).
  • Muszynska, A., ON BOUNDEDNESS OF MOTION OF A RIGID SHAFT WHIRLING IN BEARINGS WITH NONLINEAR ELASTIC CHARACTERISTICS, Proceedings of the 4th Conference on Nonlinear Oscillations, Prague 1967, Publ. House of the Czechoslovak Academy of Sciences, Prague 1968, pp. 385-392.
  • Muszynska, A., PRECESSION OF A CENTRIFUGE ROTATING IN BEARINGS WITH NONLINEAR CHARACTERISTICS, Proceedings of the Symposium on Dynamics of Construction, Lancut - Rzeszow, Poland 1968, pp. 45-54 (in Polish).
  • Muszynska, A., ON ROTOR PRECESSION WITH NONLINEAR RHEOLOGICAL PROPERTIES OF THE SHAFT MATERIAL TAKEN INTO ACCOUNT, Proceedings of the 5th Conference on Dynamics of Machines, Liblice, Czechoslovakia 1968, pp. 227-234 (in Polish).
  • Muszynska, A,. AN ANALYSIS OF THE MOTION OF A SHAFT WITH NONLINEAR CHARACTERISTICS OF ELASTICITY AND DAMPING, Bull. of the Polish Academy of Sciences, Ser. Sci. Techn., v. 16, No. 7, 1968, pp. 345-353.
  • Muszynska, A., Karaskiewicz, E., REPORT FROM THE FOURTH ALL-POLAND CONFERENCE ON LINEAR, NONLINEAR, AND RANDOM VIBRATIONS held in Poznan, 26-27 April 1968, Nonlin. Vibr. Problems, PASci, No. 10, Warsaw 1969, pp. 9-19.
  • Muszynska, A., ON MOTION OF A ELASTIC SHAFT ROTATING IN SUSCEPTIBLE BEARINGS, IFTR Report, 4/1969; also Rozprawy In髖nierskie, v. 17, No. 3, Warsaw 1969, pp. 531-546 (in Polish).
  • Muszynska, A., ON BOUNDEDNESS OF SOLUTIONS OF CERTAIN SET OF ORDINARY DIFFERENTIAL EQUATIONS, IFTR Report, 7/1968, also Nonlinear Vibration Problems (NVP), No. 10, Warsaw 1969, pp. 139-144 (in Russian).
  • Muszynska, A., CERTAIN MODELS OF A ROTATING SHAFT MOTION, Nonlinear Vibration Problems (NVP), PASci, No.10, Warsaw 1969, pp. 57-73 (in Russian).
  • Muszynska, A., ON SYNCHRONOUS AND ON NONSYNCHRONOUS PRECESSION OF A ROTOR IN MASS-ELASTIC SUPPORTS, Proc.of the 5th Intern.Conf.on Nonlinear Oscillations, v. 3, Kiev, USSR, 1969, pp. 498-505 (in Russian).
  • Muszynska, A., INTERNAL DAMPING IN STATICALLY UNBALANCED ROTATING SHAFTS, Proceedings of the 2nd All-Poland Conference on Dynamics of Machines, Rzeszow 1969, pp. 83-86 (in Polish).
  • Muszynska, A., Wicher, J., Radziszewski, J., Szadkowski, J., Ziemba, S., A SURVEY OF SOME DIRECTIONS AND RESEARCH IN THEORY OF VIBRATIONS AND DYNAMICS OF MACHINES, CARRIED ON BY MECHANICAL SYSTEM DEPARTMENT OF THE INSTITUTE OF FUNDAMENTAL TECHNOLOGICAL RESEARCH OF THE POLISH ACADEMY OF SCIENCES AND COOPERATING RESEARCH CENTERS, Proceedings of the 5-th International Conference on Nonlinear Oscillations, Kiev, USSR; also NVP, PASci, No. 11, Warsaw 1970, pp. 9-40 (in Russian).
  • Bogusz, W., Giergiel, J., Kasprzyk, S., Muszynska, A., Muszynski, J., Radziszewski, B., Szadkowski, J., Zabawa, M., STABILITY PROBLEMS IN LUMPED SYSTEMS, IFTR Report, 49/1970; also Nonlinear Vibration Problems (NVP), PASci, No. 12, Warsaw 1971, pp. 9-52 (in Polish)., STABILITY PROBLEMS IN LUMPED SYSTEMS, IFTR Report, 49/1970; also Nonlinear Vibration Problems (NVP), PASci, No. 12, Warsaw 1971, pp. 9-52 (in Polish).
  • Muszynska, A., ON MOTION OF A HORIZONTAL ROTOR WITH NONLINEAR ELASTIC AND INTERNAL DAMPING PROPERTIES, IFTR Report, 12/1970; also NVP, PASci, No. 12, Warsaw 1971, pp. 309-314.
  • Muszynska, A., ON INTERNAL DAMPING IN ROTATING SHAFTS, NVP, PASci., No. 11, Warsaw 1971, pp. 119-134 (in Polish).
  • Muszynska, A., ON ROTOR DYNAMICS -- SURVEY, IFTR Report, No. 14, 1971; also Nonlinear Vibration Problems (NVP), PASci., No. 13, Warsaw 1972, pp. 35-138.
  • Muszynska, A., Radziszewski, B., Szadkowski, J., Ziemba, S., SOME PROBLEMS ON THE THEORY OF VIBRATIONS, IFTR Report, No. 56, 1971; also Nonlinear Vibration Problems (NVP), PASci, No. 13, Warsaw 1972, pp. 7-20.
  • Muszynska, A., ON STABILITY OF ROTATION OF THE SHAFT, Theoretical and Applied Mechanics, Bulgarian Academy of Sciences, v. 3, No. 4, Sofia 1972, pp. 73-77 (in Russian).
  • Muszynska, A., VIBRATIONS NONLINEAIRIES DES ARBRES TOURNANTS, Academie Polonaise des Sciences, Centre Scientifigue a Paris, Conferences, Fascicule 101, PWN (Polish Scientific Publishers), Warsaw 1973.
  • Muszynska, A., AN ANALYSIS OF SELF-EXCITED VIBRATIONS OF A ROTOR WITH TWO DEGREES OF FREEDOM, Rozprawy In髖nierskie, No. 4, Warsaw 1973, pp. 535-557 (in Polish).
  • Muszynska, A., MOTION OF A ROTOR WITH NONLINEAR ELASTIC AND INTERNAL DAMPING CHARACTERISTICS, IFTR Report, No. 26, Warsaw 1973, pp. 1-32 (in Polish).
  • Muszynska, A., COMBINATIONAL VIBRATIONS OF A SYMMETRIC ROTOR, IFTR Report, No. 47, 1973, pp. 1-27 (in Polish).
  • Muszynska, A., ON DAMPING OF FLEXURAL VIBRATIONS OF ROTATING SHAFTS BY ELASTIC-DRY FRICTION DAMPERS, Archiwum Budowy Maszyn, v. 20, No. 1, Warsaw 1973, pp. 107-134 (in Polish).
  • Muszynska, A., ON OPTIMAL DAMPING IN A NONLINEAR SYMMETRICAL SYSTEM WITH TWO DEGREES OF FREE- DOM, Proc.of the 9th Confer. on Dynamics of Machines, Smolenice, Czechoslovakia 1974, pp. 127-141 (in Russian).
  • Ziemba, S., Muszynska, A., PROBLEMS OF DYNAMICS OF MACHINES, Dynamika Maszyn (Dynamics of Machines), Polish Academy of Sciences, Ossolineum, Warsaw 1974, pp. 5-11 (in Polish).
  • Muszynska, A., INTERNAL DAMPING IN MECHANICAL SYSTEMS, Dynamika Maszyn (Dynamics of Machines), Polish Academy of Sciences, Ossolineum, Warsaw 1974, pp. 164-212 (in Polish).
  • Muszynska, A., NONLINEAR EXCITED AND SELF-EXCITED PRECESSIONAL VIBRATIONS OF SYMMETRICAL ROTORS, Proc. of the Symposium of Dynamics of Rotors, IUTAM, Lyngby, Denmark 1974, Springer Verlag 1975, pp. 380-412.
  • Muszynska, A., PROGRAM FOR THE COMPUTER ODRA 1204 FOR CALCULATING ROOTS OF POLYNOMIALS, IFTR Report, No. 66, Warsaw 1974, pp. 1-20 (in Polish)
  • Muszynska, A. ,ON THE STABILITY OF ROTATING MOTION OF A ROTOR, NVP, PASci, No. 16, Warsaw 1975, pp. 137-140.
  • Muszynska, A., A LUMPED MODEL OF A SINGLE MASS ROTOR, IFTR Report, No. 20, Warsaw 1975, pp. 1-37 (in Polish).
  • Muszynska, A., A GENERALIZED MODEL OF ROTORS IN SUSCEPTIBLE BEARINGS, IFTR Report, No. 36, Warsaw 1975, pp. 1-29 (in Polish).
  • Muszynska, A., AN ANALYSIS OF COMBINATIONAL VIBRATIONS OF ROTORS APPLYING THE BALBI'S METHOD, IFTR Report, No. 48, 1975, pp. 1-21 (in Polish).
  • Muszynska, A., MODELLING AND DYNAMIC ANALYSIS OF ROTORS, Habilitation Thesis, IFTR Report, No. 52, Warsaw 1975, pp. 1-263 (in Polish).
  • Muszynska, A., CALCULATION OF CRITICAL SPEED REGIONS FOR ROTORS WITH SIX DEGREES OF FREEDOM, ODRA 1204 COMPUTER PROGRAM, IFTR Report, No. 62, Warsaw 1975, pp. 1-24 (in Polish).
  • Muszynska, A., MOTION OF A SHAFT WITH NONLINEAR ELASTIC AND INTERNAL DAMPING PROPERTIES, Nonlinear Vibration Problems, PASci, No. 17, Warsaw 1976, pp. 189-224.
  • Muszynska, A., SOME PROBLEMS OF MODELLING OF MECHANICAL SYSTEMS, Mechanika Teoretyczna i Stosowana (Theoretical and Applied Mechanics), v. 14, No. 2, 1976, 303-314 (in Polish).
  • Muszynska, A., Jones, D. I. G., AMORTISSEMENT DES STRUCTURES, Centre D'Actualisation Scientifique et Technique Seminar Notes, Institut National des Sciences Appliquees de Lyon, 1976, I-01 -III-21.
  • Muszynska, A.,ANALYSE DYNAMIQUE DES SYSTEMES MECHANIQUES, Lecture Notes, Institut National des Sciences Appliquees de Lyon, 1976, pp. 1-167.
  • Muszynska, A., Kurowski, W., Wicher, J., MODELLING OF TECHNICAL SYSTEMS, Diagnostyka Urzadzen Technicznych (Diagnosis of Technical Appliances), Ossolineum, Polish Academy of Sciences, Warsaw 1977, pp. 101-130 (in Polish).
  • Jones, D. I. G., Muszynska, A., EFFECT OF SLIP ON RESPONSE OF A VIBRATING COMPRESSOR BLADE, Gas Turbine Division of the American Society of Mechanical Engineers (ASME), Winter Annual Meeting, Atlanta, Georgia, 27 November - 2 December 1977, ASME Publ. 77-WA/GT-3, 1977, pp. 1-13.
  • Muszynska, A., Radziszewski, B., Zaleski, A., CONDITIONS OF A DYNAMIC EQUILIBRIUM OF A LIFT UNIT FRICTION BRAKE, Konf. n.t. Modelowania Maszyn Wyciagowych (Proceedings of the Conference on Modelling of Mining Lift Machines), Gliwice, Poland 1977, pp. 33-47 (in Polish).
  • Muszynska, A., INFLUENCE OF THE SLIP EFFECT AT ROOTS ON DAMPING OF ROTATING MACHINE BLADE VIBRATIONS, IFTR Report, No. 55, Warsaw 1977, pp. 1-25 (in Polish).
  • Muszynska, A., VIBRATIONS OF A COMPRESSOR BLADE WITH SLIP AT THE ROOT, Proceedings of the 48th Shock and Vibration Symposium, Huntsville, Alabama 1977, Shock and Vibration Bulletin, 48, Part 2, 1978, pp. 53-61.
  • Muszynska, A., Ziemba, S., PROBLEMS OF INTERNAL DAMPING IN MECHANICAL SYSTEMS, Nowe Materialy Magnetyczne, Materialy Piezomagnetyczne i Ich Zastosowania (New Magnetic. Piezomagnetic Materials and Their Applications), Proceedings of the Scientific Conference, Koszalin, Poland 1977, PWN (Polish Scientific Publishers), Warsaw 1978, pp. 138-158 (in Polish).
  • Muszynska, A., Radziszewski, B., ON DAMAGE POSSIBILITY OF A MACHINE UNIT CAUSED BY A SHORT PERTURBATION OF A STEADY STATE, Internal Report, Warsaw - Plock 1978 (in Polish).
  • Muszynska, A., PROFESSOR STEFAN ZIEMBA - REPORT AT HIS 45TH ANNIVERSARY OF THE SCIENTIFIC ACTIVITY AND THE 70TH ANNIVERSARY OF HIS BIRTHDAY, NVP, PASci, No. 19, Warsaw 1978, pp. 5-15.
  • Muszynska, A., VIBRATION CONTROL, Dynamika Maszyn (Dynamics of Machines), Ossolineum, PASci., Warsaw 1978, pp. 5-25 (in Polish).
  • Muszynska, A., ON MODELLING OF DAMPING PHENOMENA, Dynamika Maszyn (Dynamics of Machines), Ossolineum, Polish Academy of Sciences, Warsaw 1978, pp. 255-266 (in Polish).
  • Muszynska, A., COMBINED (EXCITED AND SELF-EXCITED) VIBRATIONS OF SYMMETRICAL ROTORS, Proceedings of the 14-th Yugoslav Congress of Rational and Applied Mechanics, Portoroz, Yugoslavia, June 1978, pp. 379-385.
  • Jones, D. I. G., Muszynska, A., NONLINEAR MODELISATION OF NONCONSERVATIVE BLADE VIBRATION RESPONSE, Proceedings of the 7th International Conference on Nonlinear Oscillations, Prague, Czechoslovakia 1978, pp. 367-372.
  • Muszynska, A., INFLUENCE OF DRY FRICTION AND IMPACTS ON VIBRATION DAMPING OF A CERTAIN MECHANICAL SYSTEM, IFTR Report, No. 1, Warsaw 1979, pp. 1-32.
  • Jones, D. I. G., Muszynska, A., HARMONIC RESPONSE OF A DAMPED TWO DEGREES OF FREEDOM SYSTEM WITH GAPS, Nonlinear Vibration Problems, PASci, No. 19, Warsaw 1979, pp. 153-179.
  • Balbi, J. H., Muszynska, A., COMBINED NONLINEAR VIBRATIONS OF SYMMETRICAL ROTORS ANALYSED BY APPLYING A GENERALIZED AVERAGE METHOD, Proceeding of the 12th Conference on Dynamics of Machines, Strbske Pleso, Czechoslovakia, April 1979.
  • Muszynska, A., ON MATHEMATICAL MODELS OF THE EXTERNAL KIND, Proceedings of the Conference on Modelling in Mechanics, Wisla, Poland 1979 (in Polish).
  • Muszynska, A., Jones, D. I. G., ON STRUCTURAL DAMPING AT ROOTS OF ROTATING MACHINERY BLADES, Proceedings of the Conference of Dynamics of Structures, Rzeszow, Poland, 1979.
  • Muszynska, A., Jones, D. I. G., ON DISCRETE MODELISATION OF RESPONSE OF BLADES WITH SLIP AND HYSTERETIC DAMPING, Proceedings of the 5-th World Congress on Theory of Machines and Mechanisms, Montreal, CA, 1979, pp. 646-649.
  • Jones, D. I. G., Muszynska, A., DESIGN OF TURBINE BLADES FOR EFFECTIVE SLIP DAMPING AT HIGH ROTATIONAL SPEEDS (U), The Shock and Vibration Bulletin, 47, Part 2, Modal and Impedance Analysis, Human Response to Vibration and Shock, Isolation and Damping, Dynamic Analysis, September 1979, pp. 87-96.
  • Muszynska, A., MODELLING OF ROTORS, Dynamika Maszyn (Dynamics of Machines), Ossolineum, Polish Academy of Sciences, Warsaw, 1979, pp. 167-252 (in Polish).
  • Muszynska, A., ON INSTABILITY DUE TO COUPLING, Mechanika Teoretyczna i Stosowana (Theoretical and Applied Mechanics), Warsaw, 1979 (in Polish).
  • Muszynska, A., METHODS OF MINIMISATION OF VIBRATIONS, Part 1 and 2, Przeglad Mechaniczny (Reviews of Mechanics), Warsaw, v. 19 and v. 20, 1980 (in Polish).
  • Done, G. T. S., Muszynska, A., BLADE INSTABILITY OF A HORIZONTAL AXIS WIND POWERED TURBINE, Proceedings of the 51st Shock and Vibration Symposium, San Diego, California, 21-23 October 1980; also The City University, Department of Mechanical Engineering Report, London, UK, 1980, pp. 1-22.
  • Muszynska, A., ROTOR DYNAMICS, Lecture Notes, Proceedings of the Dynamic Analysis in Turbomachinery Design, University of Wisconsin Short Course, Madison, Wisconsin, 1980, pp. 1-98.
  • Jones, D. I. G., Muszynska, A., SOME RESULTS ON THE EFFECTS OF INTERFACE FRICTION DAMPING ON TURBOMACHINERY BLADE DYNAMICS, Proceedings of the 100th Meeting of the Acoustical Society of America, Los Angeles, CA, 17-21 November 1980; also The Journal of the Acoustical Society of America, Supplement, v. 68, Fall 1980, p. 12.
  • Muszynska, A., Badziszewski, B., EXPONENTIAL STABILITY AS A CRITERION OF PARAMETRIC MODIFICATION IN VIBRATION CONTROL, Proceedings of the Euromech Symposium on Vibration Control, Edinburgh, United Kingdom, September 1978; also Nonlinear Vibration Problems, No. 20, Warsaw 1981, pp. 175-191.
  • Muszynska, A., INFLUENCE DE FROTTEMENT SEC ET DES CHOCS SUR AMORTISSEMENT D'UNE STRUCTURE MECHANIQUE, NVP, PASci, No. 20, Warsaw 1981, pp. 157-173.
  • Muszynska, A., Jones D. I. G., Lagnese, T., Whitford, L., ON NONLINEAR RESPONSE OF MULTIPLE BLADE SYSTEMS, Proceedings of the 51st Shock and Vibration Symposium, Shock and Vibration Bulletin, 51, Part 3, Analytical Methods, Dynamic Analysis, Vehicle Systems, May 1981, pp. 89-110.
  • Muszynska, A., Jones, D. I. G., A PARAMETRIC STUDY OF DYNAMIC RESPONSE OF A DISCRETE MODEL OF TURBOMACHINERY BLADED DISK, Proceedings of the Design Engineering Technical Conference, Hartford, Connecticut, 20-23 September 1981, ASME Paper 81-DET-137, pp. 1-12.
  • Muszynska, A., Jones, D. I. G., VISCOELASTIC MATERIAL DAMPING AND SLIP DAMPING IN TURBOMACHINERY BLADES AND VANES, Proceedings of the 1981 ASME Winter Annual Meeting, Washington, D.C., November 1981.
  • Muszynska, A., DRY FRICTION DAMPING, Vibration Damping Short Course, Lecture Notes, University of Dayton, OH., 1981.
  • Muszynska, A., JOINT FRICTION DAMPING, 1981 John C. Snowdon Vibration Control Seminar Lecture Notes, the Pennsylvania State University, 1981, pp. 1-58.
  • Muszynska, A., EFFECT OF FRICTION AND MISTUNING ON THE RESPONSE OF A BLADED DISK DISCRETE MODEL, Proceedings of the 52-nd Shock and Vibration Symposium, New Orleans, Louisiana, 1981.
  • Muszynska, A., A SURVEY OF VIBRATION CONTROL METHODS, Man Under Vibration, Suffering and Protection, Proceedings of the International CISM - IFToMM - WHO Symposium, Udine, Italy, April 1979; PWN (Polish Scientific Publishers), Warsaw 1981, pp. 287-314.
  • Muszynska, A., COUPLED BLADED DISK LUMPED PARAMETER STUDY, Research Report, University of Dayton/Wright Patterson Air Force Base, Contract #F33615-81-C-2012; 93881-09, Ohio, 1981.
  • Muszynska, A., Bansevivcius, R., Ragulskis, K., VIBROMOTORS, Book Review, The Shock and Vibration Digest, v. 15,No. 4, 1981.
  • Muszynska, A., Gosiewski, Z., ON THE INSTABILITY OF THE COUPLED TRANSVERSAL-TORSIONAL VIBRATIONS OF A ROTOR, Zeszyty Naukowe WSI, No. 5/BM, Ser.B, Koszalin, 1982, pp. 133-148 (in Polish).
  • Bently, D. E., Muszynska, A., STABILITY EVALUATION OF ROTOR/BEARING SYSTEM BY PERTURBATION TESTS, Workshop on Rotor Dynamic Instability Problems in High Performance Turbomachinery, Texas A&M Univ., College Station, TX, NASA Conference Publication No. 2250, 1982, pp. 307-322.
  • Muszynska, A., Jones, D. I. G., BLADED DISK DYNAMICS INVESTIGATED BY A DISCRETE MODEL: EFFECTS OF TRAVELING WAVE EXCITATION, FRICTION AND MISTUNING, Vibration Institute Proceedings, Machinery Vibration Monitoring and Analysis Meeting, Oak Brook, Illinois, 30 March - 1 April, 1982, pp. 33-49.
  • Bently, D. E., Muszynska, A., OIL WHIRL IDENTIFICATION BY PERTURBATION TEST, Advances in Computer-Aided Bearing Design, Proceedings of ASME/ASLE Lubrication Conference, Washington, D.C., October 1982, pp. 111-119.
  • Muszynska, A., SHAFT CRACK DETECTION, Proceedings of the Seventh Machinery Dynamics Seminar, National Research Council, Edmonton, Alberta, Canada, October 1982.
  • Muszynska, A., C. Cempel: FUNDAMENTALS OF VIBRO-ACOUSTICAL DIAGNOSTICS OF MACHINES (Podstawy Wibroakustycznej Diagnostyki Maszyn), Book Review, The Shock and Vibration Digest, v. 16, No. 6, 1982.
  • Muszynska, A., DYNAMIC STIFFNESS MEASUREMENTS FOR BETTER MECHANICAL SYSTEM IDENTIFICATION, Proceedings of the EPRI - Nuclear Power Division Pump Workshop, Toronto, Canada, August 1982; also BRDRC (Bently Rotor Dynamics Research Corporation) Report No. 1, Minden, NV, 1982, pp. 1-15.
  • Muszynska, A., INTRODUCTION TO DYNAMIC MOTION OF MECHANICAL SYSTEMS, BRDRC Report No. 2, Minden, Nevada, 1982, pp. 1-39.
  • Muszynska, A., INTRODUCTION TO ROTOR DYNAMICS, BRDRC Report No. 3, Minden, Nevada, 1982, pp. 1-6.
  • Muszynska, A., DYNAMIC MODE SHAPES OF ROTORS, BRDRC Report No. 4, Minden, Nevada, 1982, pp. 1-27
  • Muszynska, A., INSTABILITY OF THE ELECTRIC MACHINE ROTORS CAUSED BY IRREGULARITY OF ELECTROMAGNETIC FIELD, BRDRC Report No. 1, Minden, Nevada, 1983, pp. 1-5.
  • Muszynska, A., VIBRATION CONTROL METHODS, Nonlinear Vibration Problems (NVP -- Zagadnienia Drgan Nieliniowych), No. 21, 1983, Warsaw, Poland.
  • Muszynska, A., Jones, D. I. G., ON TUNED BLADED DISK DYNAMICS: SOME ASPECTS OF FRICTION RELATED MISTUNING, Journal of Sound and Vibration, United Kingdom, v. 86, No 1, 1983, pp. 107-128.
  • Jones, D. I. G., Muszynska, A., A DISCRETE MODEL OF A MULTIPLE BLADE SYSTEM WITH INTERBLADE SLIP, Proceedings of the 9-th Biennial ASME Conference on Mechanical Vibration and Noise of the Design and Production Engineering Technical Conferences, Vibrations of Bladed Disk Assemblies, Dearborn, Michigan, 11-14 September 1983, pp. 137-146.
  • Muszynska, A., Jones, D. I. G., ON THE MODAL IDENTIFICATION OF MULTIPLE DEGREE OF FREEDOM SYSTEM FROM EXPERIMENTAL DATA, Proceedings of the Sixth IFToMM Congress on Theory of Machines and Mechanisms, New Delhi, India, 15-20 December 1983.
  • Jones, D. I. G., Muszynska, A., ON THE MODAL IDENTIFICATION OF MULTIPLE DEGREE OF FREEDOM SYSTEMS FROM EXPERIMENTAL DATA, Proceedings of the 53-rd Shock and Vibration Bulletin, Part 2, Fluid-Structure Dynamics and Dynamic Analysis, Danvers, Mass., May 1983, pp. 91-110.
  • Bently, D. E., Muszynska, A., PERTURBATION TESTS OF BEARING/SEAL FOR EVALUATION OF DYNAMIC COEFFICIENTS, Symposium on Rotor Dynamical Instability, Summer Annual Conference of ASME Applied Mechanics Division, Houston, TX, Rotor Dynamical Instability, AMD, v. 55, 1983, pp. 75-88.
  • Muszynska, A., RUB -- AN IMPORTANT MALFUNCTION IN ROTATING MACHINERY, Proceedings of the Senior Mechanical Engineering Seminar, Carson City, Nevada, 13-17 June 1983, pp. 1-130; also BRDRC Report No. 3, 1983, pp. 1-130.
  • Muszynska, A., OIL WHIRL AND WHIP -- IMPORTANT ROTOR/BEARING DYNAMIC PHENOMENA, Bently Nevada Corporation, BRDRC Report No. 4, 1983; Proceedings of Senior Mech. Engng. Seminar, Carson City, Nevada, 1983.
  • Muszynska, A., ANALYSIS OF FRICTION DAMPING, Proceeding of the ASME Short Course on Damping Control for Design Flexibility, Norfolk, VA, March 1983; also BRDRC Report No. 2, 1983.
  • Muszynska, A., PARTIAL LATERAL ROTOR TO STATOR RUBS, Proceedings of the Third International Conference, Vibrations in Rotating Machinery, IMechE, C 281/84, York, UK, 1984, pp. 227-236.
  • Jones, D. I. G., Muszynska, A., DAMPING MEASUREMENT BY DYNAMIC STIFFNESS METHODS, Proceedings of the Vibration Damping Workshop, Long Beach, California, February 1984, pp. 1-25.
  • Bently, D. E., Muszynska, A. THE DYNAMIC STIFFNESS CHARACTERISTICS OF HIGH ECCENTRICITY RATIO BEARINGS AND SEALS BY PERTURBATION TESTING, Rotordynamics Instability Problems in High Performance Turbomachinery, Texas A&M University Workshop, College Station, Texas, NASA Conference Publication No. 2338, May 1984, pp. 481-491.
  • Muszynska, A., ROTOR INSTABILITY, Bently Rotor Dynamics Research Corporation, BRDRC Report No. 1, 1984, Proceedings of the Senior Mechanical Engineering Seminar, Carson City, Nevada, June 1984.
  • Muszynska, A., ROTOR/SEAL FULL ANNULAR RUB, Bently Rotor Dynamics Research Corporation, BRDRC Report No. 2, 1984 Proceedings of the Senior Engineering Seminar, Carson City, Nevada, June 1984.
  • Muszynska, A., APPLICATION OF THE PERTURBATION METHOD TO ROTATING MACHINES, Bently Rotor Dynamics Research Corporation, BRDRC Report No. 3, 1984, Proceedings of the Senior Mechanical Engineering Seminar, Carson City, NV, June 1984.
  • Muszynska, A., LATERAL-TORSIONAL VIBRATIONS OF A ROTOR, Bently Rotor Dynamics Research Corporation, BRDRC Report No. 2, Minden, Nevada, 1984, pp. 1-10.
  • Muszynska, A., SYNCHRONOUS AND SELF-EXCITED ROTOR VIBRATIONS CAUSED BY A FULL ANNULAR RUB, Proceedings of the Eighth Machinery Dynamics Seminar NRC, NRC No. 23619, Halifax, Nova Scotia, Canada, October 1984, pp. 22.1-22.21.
  • Bently, D. E., Muszynska, A., Jones, D. I. G., SOME ASPECTS OF THE APPLICATION OF MECHANICAL IMPEDANCE FOR TURBOMACHINERY AND STRUCTURAL SYSTEM PARAMETER IDENTIFICATION, Proceedings of the 3-rd International Modal Analysis Conference, Orlando, FLA, January 1985, pp. 177-186.
  • Bently, D. E., Muszynska, A., PERTURBATION STUDY OF A ROTOR/BEARING SYSTEM: IDENTIFICATION OF THE OIL WHIRL AND OIL WHIP RESONANCES, The Tenth ASME Design Engineering Division Conference on Mechanical Vibration and Noise, Paper 85-DET-142, Cincinnati, Ohio, 10-13 September 1985.
  • Bently, D. E., Muszynska, A., IDENTIFICATION OF BEARING AND SEAL DYNAMIC STIFFNESS PARAMETERS BY STEADY-STATE LOAD AND SQUEEZE FILM TESTS, Proceedings of the Symposium on Instability in Rotating Machinery, Carson City, NV, June 1985; NASA Conference Publication, No. 2409, 1985, pp. 301-316.
  • Muszynska, A., Bently, D. E., MEASUREMENT OF ROTOR SYSTEM DYNAMIC STIFFNESS BY PERTURBATION TESTING, Proceedings of the Symposium on Instability in Rotating Machinery, Carson City, NV, June 1985; NASA C.P., No. 2409, 1985, pp. 47-58.
  • Bently, D. E., Muszynska, A., WHY HAVE HYDROSTATIC BEARINGS BEEN AVOIDED AS A STABILIZING ELEMENT FOR ROTATING MACHINES? Proceedings of the Symposium on Instability in Rotating Machinery, Carson City, NV, June 1985; NASA C.P., No. 2409, 1985, pp. 59-64.
  • Bently, D. E., Muszynska, A., ROTOR INTERNAL FRICTION INSTABILITY, Proceedings of the Symposium on Instability in Rotating Machinery, Carson City, NV, June 1985; NASA C.P., No. 2409, 1985, pp. 337-348.
  • Muszynska, A., DEMONSTRATION OF VARIOUS ROTOR INSTABILITIES (Exhibit of the Bently Rotor Dynamics Research Corporation Laboratory Rigs at the Symposium on Instability in Rotating Machinery), Proceedings of the Symposium on Instability in Rotating Machinery, Carson City, NV, June, 1985, NASA C.P., No. 2409, 1985, pp. 409-414, 423-426, 431-442, 447-456, 459-464.
  • Muszynska, A., WHIRL AND WHIP -- ROTOR/BEARING STABILITY PROBLEMS, Proceedings of the Symposium on Instability in Rotating Machinery, Carson City, Nevada, NASA C. P. No. 2409, June 1985, pp. 155-178.
  • Muszynska, A., MECHANICAL VIBRATIONS, Lecture Notes, University Nevada Reno, BRDRC Report No. 2, Minden, Nevada, 1985, pp. 1-95.
  • Muszynska, A., CRACKED SHAFT DETECTION BY VIBRATION MONITORING, BRDRC Report No. 1, Minden, Nevada, 1985, pp. 1-26.
  • Muszynska, A., SHAFT CRACK DETECTON TOPICS: INTRODUCTION TO SHAFT CRACK DETECTION. IDENTIFICATION OF SHAFT CRACK RADIAL LOCATION. CRACKED SHAFT DETECTION BY VIBRATION MONITORING. CRACKED SHAFT REFERENCE MATERIAL 1933-1986. BRDRC Shaft Crack Detection Seminar Proceedings, Atlanta, GA, February 1986.
  • Bently, D. E., Muszynska, A., MODAL TESTING AND PARAMETER IDENTIFICATION OF ROTATING SHAFT/FLUID LUBRICATED BEARING SYSTEM, Proceedings of 4-th International Modal Analysis Conference, Los Angeles, CA, February 1986, pp. 1393-1402.
  • Muszynska, A., WHIRL AND WHIP -- ROTOR/BEARING STABILITY PROBLEMS, Journal of Sound and Vibration, United Kingdom, v. 110, No. 3, 1986, pp. 443-462.
  • Bently, D. E., Zimmer, S., Palmatier, G., Muszynska, A., INTERPRETING VIBRATION INFORMATION FROM ROTATING MACHINERY, Proceedings of the VDI Conference on Vibrational Monitoring of Machines, Hamburg, Germany, 7-8 November 1985; also Sound and Vibration, v. 20, No. 2, February 1986, pp. 14-23.
  • Laws, W. C., Muszynska, A., PERIODIC AND CONTINUOUS VIBRATION MONITORING AND DIAGNOSTICS FOR PREDICTIVE MAINTENANCE, Presented at The Chinese Society of Machine Diagnostic Technique International Conference on Vibration Problems in Engineering, Xian, China, June 1986, pp. 1-14.
  • Bently, D. E., Muszynska, A., Olas, A., IDENTIFICATION OF THE MODAL PARAMETERS BY PERTURBATION TESTING OF A ROTOR WITH STRONG GYROSCOPIC EFFECT, Proceedings of the International Conference on Rotordynamics, Tokyo, Japan, 14-17 September 1986, pp. 189-194.
  • Muszynska, A., FUNDAMENTAL RESPONSE OF A ROTOR, Bently Rotor Dynamics Research Corporation, BRDRC Report No. 1, Minden, Nevada, 1986, pp. 1-22.
  • Muszynska, A., MODAL TESTING OF ROTOR/BEARING SYSTEMS, The International Journal of Analytical and Experimental Modal Analysis, v. 1, No. 3, July 1986, pp. 15-34.
  • Bently, D. E., Muszynska, A., ANTI-SWIRL ARRANGEMENTS PREVENT ROTOR/SEAL INSTABILITY, Proc. of Post IFTOMM Conference on Flow Induced Force in Rotating Machinery, Kobe University, Japan, September 1986, pp. 1-31; also Proc. of Session on Thermo-Fluid Dynamics of Rotating Machinery, 2nd ASME-JSME Thermal Engineering Conference, Honolulu, Hawaii, 22-27 March 1987, pp. 127-134; also Trans. of the ASME Journal of Vibration, Acoustics, Stress and Reliability in Design, v. 111, No. 2, April 1989, pp. 156-162.
  • Bently, D. E., Muszynska, A., DETECTION OF ROTOR CRACKS, Proceedings of Texas A&M University 15th Turbomachinery Symposium and Short Courses, Corpus Christi, TX, November 1986, pp. 129-139.
  • Bently, D. E., Muszynska, A., EARLY DETECTION OF SHAFT CRACKS ON FLUID-HANDLING MACHINES, Proceedings of the ASME International Symposium on Fluid Machinery Trouble Shooting, 1986 Winter Annual Meeting, Anaheim, California, 7-12 December 1986, pp. 53-58.
  • Muszynska, A., FLUID-RELATED ROTOR/BEARING/SEAL INSTABILITY PROBLEMS, Bently Rotor Dynamics Research Corporation, BRDRC Report No. 2, Minden, Nevada, 1986, pp. 1-119.
  • Bently, D. E., Muszynska, A., LIFE EXTENSION OF ROTATING MACHINERY WITH VIBRATION MONITORING, Proceedings of the EPRI Rotating Machinery Dynamics, Bearings, and Seals Symposium, St. Louis, MO, Sept. 1986.
  • Muszynska, A., TRACKING THE MYSTERY OF OIL WHIRL, Sound and Vibration, February 1987, pp. 8-12; also SPIN, The Technical Journal of Concepts ETI, Inc., v. 1, No. 3, May/June 1987, p. 1.
  • Muszynska, A., IMPROVEMENTS IN LIGHTLY LOADED ROTOR/BEARING AND ROTOR/SEAL MODELS, Publ. #H0400A, Boston, Massachusetts, September 1987, pp. 91-98; also Trans. of the ASME, Journal of Vibration, Acoustics, Stress and Reliability in Design, v. 110, No. 2, April 1988, pp. 129-136.
 楼主| 发表于 2005-8-28 17:17 | 显示全部楼层
  • Muszynska, A., Franklin, W. D., Bently, D. E., ROTOR ACTIVE "ANTI-SWIRL" CONTROL, Rotating Machinery Dynamics, 11th Biennial ASME Design Engineering Division Conference on Vibration and Noise, ASME Publ. #H0400A, Boston, Massachusetts, September 1987, pp. 215-222; also Trans. of the ASME, Journal of Vibration, Acoustics, Stress, and Reliability in Design, v. 110, No. 2, April 1988, pp. 143-150.
  • Tam, L. T., Przekwas, A. J., Muszynska, A., Hendricks, R. C., Braun, M. J., Mullen, R.L., NUMERICAL AND ANALYTICAL STUDY OF FLUID DYNAMIC FORCES IN SEALS AND BEARINGS, Rotating Machinery Dynamics, 11th Biennial ASME Design Engineering Division Conference on Vibration and Noise, ASME Publ. #H0400B, Boston, Massachusetts, September 1987, pp. 359-370; also Trans. of the ASME, Journal of Vibration, Acoustics, Stress and Reliability in Design, v. 110, No. 3, July 1988, pp. 315-325.
  • Jones, D. I. G., Muszynska, A., STRUCTURAL MODIFICATION OF ADVANCED TURBOMACHINE BLADING BY DYNAMIC STIFFNESS MATRIX OPERATIONS, Modal Testing and Analysis, 11th Biennial ASME Design Engineering Division Conf. on Vibration and Noise, ASME Publ. #H00403, Boston, Massachusetts, September 1987, pp. 59-64; also Trans. of the ASME, Journ. of Vibration, Acoustics, Stress and Reliability in Design, v. 110, No. 4, October 1988, pp. 450-455.
  • Jones, D. I. G., Muszynska, A., MECHANICAL STRUCTURE IMPROVEMENT BY DYNAMIC STIFFNESS METHODS, The International Journal of Analytical and Experimental Modal Analysis, v. 2, No. 2, 1987.
  • Laws, W. C., Muszynska, A., PERIODIC AND CONTINUOUS VIBRATION MONITORING FOR PREVENTIVE/PREDICTIVE MAINTENANCE OF ROTATING MACHINERY, ASME Winter Annual Meeting, Miami Beach, Florida, November 1985; also Trans. ASME, Journal of Engineering for Gas Turbines and Power, v. 109, April 1987, pp. 159-167.
  • Muszynska, A., INTRODUCTION TO BALANCING, BRDRC Report No. 1, 1987, pp. 1-44.
  • Bently, D. E., Muszynska, A., Franklin, W. D., HIGH-CYCLE AND LOW-CYCLE FATIGUE -- MAJOR SOURCE OF ROTOR CRACKS, Report on Experimental Study Prepared for The Travelers Companies, Hartford, Connecticut by Bently Rotor Dynamics Research Corporation, Minden, Nevada, July 1987, pp. 1-65.
  • Bently, D. E., Muszynska, A., Franklin, W., D., EXPERIMENTAL STUDY ON LOW-CYCLE FATIGUE SHAFT CRACKING DUE TO ROTOR MISALIGNMENT FOR CRACK EARLY DETECTION THROUGH VIBRATION MONITORING, Report prepared for The Arkwright-Boston Insurance Company, Waltham, Massachusetts, by BRDRC, Minden, Nevada, September 1987, pp. 1-322.
  • Bently, D. E., Muszynska, A., Thomson, A. S., VIBRATION MONITORING TECHNIQUES AND SHAFT CRACK DETECTION ON REACTOR COOLANT PUMPS AND RECIRCULATION PUMPS, Proceedings of the EPRI Workshop on Reactor Coolant Pump and Recirculation Pump Monitoring, Toronto, Ontario, Canada, 29-31 March 1988.
  • Muszynska, A., MULTI-MODE WHIRL AND WHIP IN ROTOR/BEARING SYSTEMS, Dynamics of Rotating Machinery, Proceedings of The Second International Symposium on Transport Phenomena, Dynamics, and Design of Rotating Machinery (ISROMAC-2), v. 2, Hemisphere Publishing Corporation, Honolulu, Hawaii, 4-6 April 1988, pp. 326-340.
  • Bently, D. E., Muszynska, A., ROLE OF CIRCUMFERENTIAL FLOW IN THE STABILITY OF FLUID-HANDLING MACHINE ROTORS, Proceedings of the Fifth Workshop on Rotordynamics Instability Problems in High Performance Turbomachinery, Texas A&M University, College Station, Texas, NASA CP 3026, 16-18 May 1988, pp. 415-430.
  • Muszynska, A., EFFECTS OF LOOSE ROTATING PARTS ON ROTOR DYNAMICS, Proceedings of he 4th International Conference on Vibrations in Rotating Machinery, No. C241/88, Heriot-Watt University, Edinburgh, Scotland, 13-15 September 1988, pp. 573-578.
  • Muszynska, A., Bently, D. E., MODAL TESTING OF ROTATING MACHINERY, Letter to the Editor of "Sound and Vibration," S&V Observer, Sound and Vibration, June 1988, pp. 6-14.
  • Muszynska, A., Franklin, W. D., Hayashida, R. D., INFLUENCE OF RUBBING ON ROTOR DYNAMICS, Proceedings of NASA 1988 Conference on Advanced Earth-to-Orbit Propulsion Technology, NASA CP 3012, v. 2, Huntsville, Alabama, 11-13 May 1988, pp. 149-164.
  • Hendricks, R. C., Tam, L. T., Przekwas, A., Muszynska, A., Braun, M. J., Mullen, R. L., NUMERICAL MODELING OF MULTIDIMENSIONAL FLOW IN SEALS AND BEARINGS, NASA Technical Memorandum No. 100779; also Proceedings of The Second International Symposium on Transport Phenomena, Dynamics, and Design of Rotating Machinery (ISROMAC-2), v. 1, Honolulu, Hawaii, 4-6 April 1988, pp. 134-151.
  • Muszynska, A., STABILITY OF WHIRL AND WHIP IN ROTOR/BEARING SYSTEMS, Journal of Sound and Vibration, U.K. v. 127, No. 1, 1988, pp. 49-64.
  • Muszynska, A., THE ROLE OF TANGENTIAL FORCES AND CIRCUMFERENTIAL FLOW IN ROTOR/BEARING/SEAL SYSTEM STABILITY, Proceedings of the Sixth Annual ROMAC Short Course, University of Virginia, Minden, Nevada, 23-26 May 1988, pp. 1-35.
  • Muszynska, A., MODAL ANALYSIS OF ROTATING MACHINES, Bently Rotor Dynamics Research Corporation Report No. 1, 1988; also Proceedings of the 13th International Conference on "Models in Designing and Constructions of Machines," Zakopane, April 1989, Zeszyty Naukowe Politechniki Slaskiej, z.91, Gliwice, Poland, 1989, pp. 127-138.
  • Bently, D. E., Muszynska, A., THE APPLICATIONS OF INSTRUMENTATION AND MATHEMATICAL MODELING FOR THE SOLUTION OF ROTOR DYNAMIC PROBLEMS, Proceedings of the 10-th Machinery Dynamics Seminar, NRC, Calgary, Canada, September 1988.
  • Muszynska, A., RECOMMENDATIONS FOR SHAFT CRACK DETECTION IN ROTATING MACHINERY, Bently Nevada Applications Note, Orbits, Machinery Protection and Diagnostic Topics, BRDRC Report No. 2, 1988.
  • Muszynska, A., Bently, D. E., COMMENTS ON FREQUENCY SWEPT ROTATING INPUT PERTURBATION TECHNIQUES AND IDENTIFICATION OF THE FLUID FORCE MODELS IN ROTOR/BEARING/SEAL SYSTEMS AND FLUID HANDLING MACHINES, STLE 1989 Annual Meeting, Condition Monitoring and Preventative Maintenance, Atlanta, Georgia, 1-4 May 1989; also The Sixth Workshop on Rotordynamic Instability Problems in High Performance Turbomachinery, Texas A&M University, College Station, TX, 21-23 May 1990, NASA CP 3122, 1990, pp. 391-410.
  • Muszynska, A., ROTOR-TO-STATIONARY ELEMENT RUB-RELATED VIBRATION PHENOMENA IN ROTATING MACHINERY; LITERATURE SURVEY, The Shock and Vibration Digest, v. 21, No. 3, March 1989, pp. 3-11.
  • Muszynska, A., Bently, D. E., FLUID-GENERATED INSTABILITIES OF ROTORS, Orbit, v. 10, No. 1, April 1989, pp. 6-14.
  • Muszynska, A., Bently, D. E., Franklin, W. D., Hayashida, R. D., IDENTIFICATION OF MODAL PARAMETERS OF ROTATING SYSTEMS USING PERTURBATION TECHNIQUES, PART 1 AND PART 2, Rotating Machinery Dynamics DE-V. 18-1 H0508A, Twelfth Biennial ASME Conference on Mechanical Vibration and Noise, Montreal, Canada, 17-20 September 1989, pp. 107-118.
  • Muszynska, A., Bently, D. E., Franklin, W. D., Hayashida, R. D., Kingsley, L. M., Curry, A. E., INFLUENCE OF RUBBING ON ROTOR DYNAMICS, PART 1 AND PART 2, Final Report, NASA #NAS8-36719, March 1989, pp. 1-798.
  • Muszynska, A., MISALIGNMENT AND SHAFT-CRACK-RELATED PHASE RELATIONSHIPS FOR AND VIBRATION COMPONENTS OF ROTORS, Orbit, v. 10, No. 2, Sept. 1989, pp. 4-8.
  • Bently, D. E., Muszynska, A., Biggs, D. H., Southwick, G. D., APPLICATION OF ADVANCED COMPUTERS IN VIBRATION MONITORING AND DIAGNOSTICS OF ROTATING MACHINERY MALFUNCTIONS, Proceedings of the Symposium on Advanced Computers for Dynamics and Design '89, Tsuchiura, Japan, 6-8 September 1989, pp. 273-277.
  • Muszynska, A., MISALIGNMENT MODEL, Bently Rotor Dynamics Research Corporation, BRDRC Report No. 1, 1989, pp. 1-8.
  • Bently, D. E., Muszynska, A., VIBRATION MONITORING AND SHAFT CRACK DETECTION, Proceedings of the American Nuclear Society 1989 Winter Meeting, San Francisco, California, 26-30 November 1989.
  • Bently, D. E., Bosmans, R. F., Muszynska, A., Southwick, G. D., Werner, M. J., VIBRATION MONITORING OF TURBOMACHINERY FOR SPACE PROPULSION SYSTEMS, Proc. of the First Annual Health Monitoring Conference for Space Propulsion Systems, Cincinnati, Ohio, 14-15 November 1989.
  • Muszynska, A., SHAFT VIBRATION VERSUS SHAFT STRESS, Orbit, v. 10, No. 3, 1989, pp. 4-7.
  • Muszynska, A., THE ROLE OF FLOW-RELATED TANGENTIAL FORCES IN ROTOR/BEARING/SEAL SYSTEM STABILITY, Proceedings of the Third International Symposium on Transport Phenomena and Dynamics of Rotating Machinery (ISROMAC-3), Honolulu, Hawaii, 1-4 April 1990.
  • Muszynska, A., APHT PLOT, BRDRC Report No. 2, 1989.
  • Muszynska, A., TWO-MODE ROTOR WITH NONSYMMETRIC SUPPORTS AND NONSYMMETRIC TANGENTIAL FORCE, BRDRC Report No. 3, 1989.
  • Muszynska, A., Franklin, W. D., Hayashida, R. D., ROTOR-TO-STATOR PARTIAL RUBBING AND ITS EFFECTS ON ROTOR DYNAMIC RESPONSE, The Sixth Workshop on Rotordynamic Instability Problems in High Performance Turbomachinery, College Station, TX, NASA CP 3122, 21-23 May 1990, pp. 345-362.
  • Muszynska, A., Grant, J. W., STABILITY AND INSTABILITY OF A TWO-MODE ROTOR SUPPORTED BY TWO FLUID-LUBRICATED BEARINGS, BRDRC Report No. 1/90, 1990; also Trans. of the ASME Journal of Vibration and Acoustics, v. 113, No. 3, 1991, pp. 316-324; also Proc. of the STLE Annual Meeting, Montreal, Canada, 29 April-2 May 1991; also ASME Turbo Expo International Gas Turbine Conference and Exhibition, Orlando, FLA, 91-GT-118, June 1991.
  • Muszynska, A., Bently, D. E., FREQUENCY SWEPT ROTATING INPUT PERTURBATION TECHNIQUES AND IDENTIFICATION OF THE FLUID FORCE MODELS IN ROTOR/BEARING/SEAL SYSTEMS AND FLUID HANDLING MACHINES, Journal of Sound and Vibration, U.K. v. 143, No. 1, 1990, pp. 103-124.
  • Muszynska, A., EXPERIMENTAL RESULTS ON INTERACTION OF FLUID- AND RUB-INDUCED VIBRATIONS OF A ROTOR, BRDRC Report No. 2, 1990.
  • Muszynska, A., EXPERIMENTAL RESULTS ON VIBRATIONAL RESPONSE OF A ROTOR WITH ONE OVERSIZED BRASS BUSHING OILITE BEARING, BRDRC Report No. 3, 1990.
  • Goldman, P., Muszynska, A., Bently, D. E., ANALYTICAL AND EXPERIMENTAL SIMULATION OF LOOSE PEDESTAL DYNAMIC EFFECTS ON A ROTATING MACHINE VIBRATION RESPONSE, BRDRC Report No. 4, 1990.
  • Bently, D. E., Muszynska, A., INFLUENCE OF FLUID-INDUCED "CROSS-STIFFNESS" IN ROTOR/BEARING MODELS, Orbit, v. 11, No. 3, 1990, pp. 5-7.
  • Muszynska, A., EFFECTS OF AN OVERSIZED BEARING BUSHING ON ROTORDYNAMIC RESPONSE, BRDRC Report No 5, 1990.
  • Bently, D. E., Muszynska, A., LECTURE NOTES OF THE WORKSHOP ON THE RESPONSE, STABILITY, AND IDENTIFICATION OF NONLINEAR ROTORDYNAMIC SYSTEMS, v. 1 & 2, Institute and Deptartment of Aeronautics and Astronautics, National Cheng Kung University, January 1991, pp.1-369.
  • Muszynska, A., ROTATING MACHINERY MALFUNCTION DIAGNOSTICS THROUGH VIBRATION MONITORING, Proceedings of the 5-th Conference on Mechanical Design and Production, Cairo University, December 1991; also BRDRC Report No. 2, 1991, pp. 1-20.
  • Goldman, P., Muszynska, A., ANALYTICAL AND EXPERIMENTAL SIMULATION OF LOOSE PEDESTAL DYNAMIC EFFECTS ON A ROTATING MACHINE VIBRATIONAL RESPONSE, Rotating Machinery Dynamics, DE-Vol. 35, The 13th Biennial ASME Conference on Mechanical Vibration and Noise, Miami, Florida, 1991, pp. 11-17.
  • Bently, D. E., Muszynska, A., Goldman, P., TORSIONAL/LATERAL VIBRATION CROSS COUPLING DUE TO SHAFT ASYMMETRY, BRDRC Report No. 1, 1991.
  • Muszynska, A., ONE LATERAL MODE ISOTROPIC ROTOR RESPONSE TO NONSYNCHRONOUS EXCITATION, BRDRC Report No. 4, 1991, pp. 1-31; also the Course on "Rotor Dynamics and Vibration in Turbomachinery," Von Karman Institute for Fluid Dynamics, Belgium, 21-25 September 1992.
  • Bently, D. E., Muszynska, A., THE USE OF THE EXPRESSION ... 'NEGATIVE DAMPING,' Orbit, v. 12, No. 3, October 1991.
  • Muszynska, A. , EFFECTS OF AN OVERSIZE, POORLY LUBRICATED BEARING ON ROTORDYNAMIC RESPONSE. PART I: EXPERIMENTAL RESULTS, PART II: ANALYTICAL MODELLING, Proceedings of the ISROMAC-4, Honolulu, Hawaii, April 1992, pp. 432-452; also "Rotating Machinery 1992", Vol. 2, Ed.: Wen-Jei Yang & J. H. Kim, Begell House, Inc., New York, Walingford, U.K., 1992, pp. 1105-1125.
  • Muszynska, A., Goldman, P., Bently, D. E., TORSIONAL/LATERAL CROSS-COUPLED RESPONSES DUE TO SHAFT ANISOTROPY: A NEW TOOL IN SHAFT CRACK DETECTION, Conference, "Vibrations in Rotating Machinery," IMechE, C 432-090, Bath, U.K. 1992; also BRDRC Report No. 5, 1991.
  • Goldman, P., Muszynska, A., RESONANCES IN THE SYSTEM OF THE INTERACTED SOURCES OF VIBRATION, PART 1, FORMULATION OF PROBLEM AND GENERAL RESULTS, International Journal for Nonlinear Mechanics, v. 29, No. 1, 1994, pp. 49-63.
  • Goldman, P., Muszynska, A., ANALYTICAL MODEL OF THE IMPACT BETWEEN ROTATING AND NONROTATING ELEMENTS AND ITS APPLICATION IN ROTOR-TO-STATOR RUBBING, BRDRC Report No.1, 1992, pp. 1-31.
  • Muszynska, A., Bently, D. E., FUNDAMENTALS OF ROTATING MACHINE DIAGNOSTICS, 10th School of Diagnostics, "Diagnostics 92," University of Poznan, Poland, September 1992.
  • Muszynska, A., Bently, D. E., Franklin, W. D., Grant, J. W., Goldman, P., APPLICATIONS OF SWEEP FREQUENCY ROTATING FORCE PERTURBATION METHODOLOGY IN ROTATING MACHINERY FOR DYNAMIC STIFFNESS IDENTIFICATION, 92-GT-176, ASME International Gas Turbine and Aeroengine Congress and Exposition, Cologne, Germany, 1-4 June 1992, pp. 1-6; also Trans. of ASME, Journal of Engineering for Gas Turbines and Power, v. 115, April 1993, pp. 266-271.
  • Goldman, P., Muszynska, A., DYNAMIC EFFECTS IN MECHANICAL STRUCTURES WITH GAPS AND IMPACTING: ORDER AND CHAOS, Transactions of the ASME, Journal of Vibration and Acoustics, v. 116, October 1994, pp. 541-547.
  • Gosiewski, Z., Muszynska, A., DYNAMICS OF ROTATING MACHINES (in Polish), Dynamika Maszyn Wirnikowych, Skrypty, Higher Engineering School in Koszalin, Poland, 1992, pp. 1-185.
  • Muszynska, A., PERTURBATION TECHNIQUE FOR IDENTIFICATION OF THE LOWEST MODES OF ROTORS WITH FLUID INTERACTION, the course on "Rotor Dynamics and Vibration in Turbomachinery," Von Karman Institute for Fluid Dynamics, Belgium, 21-25 September 1992.
  • Muszynska, A., VIBRATIONAL DIAGNOSTICS OF ROTATING MACHINERY MALFUNCTIONS, the course on "Rotor Dynamics and Vibration in Turbomachinery," von Karman Institute for Fluid Dynamics, Belgium, 21-25 September 1992; also International Journal of Rotating Machinery, v. 1, No. 3-4, 1995, pp. 237-266.
  • Muszynska, A., INSTABILITY OF ROTORS DUE TO FLUID INTERACTION EFFECTS, Przeglad Mechaniczny, No. 1, Warsaw, Poland, 1993, pp. 7-11 (in Polish).
  • Muszynska, A., MECHANICAL/THERMAL EFFECT OF ROTOR-TO-STATOR RUBS IN ROTATING MACHINERY, BRDRC Report No 2,1992.
  • Muszynska, A., Goldman, P., TORSIONAL VIBRATION MEASUREMENTS HELP IN SHAFT CRACK DIAGNOSTICS, Orbit, Vol. 13, No. 4, December 1992, pp. 5-7.
  • Petchenev, A., Goldman, P., Muszynska, A., Bently, D. E., THE ANALYTICAL DESCRIPTION OF THE FLUID FILM JOURNAL BEARINGS OF FINITE LENGTH, BRDRC Report No. 5, 1992.
  • Muszynska, A., THERMAL RUB EFFECT IN ROTATING MACHINES, Orbit, March 1993, pp. 8-13.
  • Muszynska, A.,THERMAL/MECHANICAL EFFECT OF ROTOR-TO-STATOR RUBS IN ROTATING MACHINERY, Vibration of Rotating Systems, DE-Vol. 60, ASME Vibration and Noise Conference, Albuquerque, New Mexico, September 1993, pp. 1-6.
  • Franklin, W., Muszynska, A., Bently, D. E., ESTIMATION OF VIBRATION AT CRITICAL LOCATIONS USING AVAILABLE MEASUREMENTS AND MACHINE CONFIGURATION DATA, 1993, ASME TURBO EXPO Conference, 93-GT-34, Cincinnati, Ohio, May 1993; also Orbit, March 1994, pp. 5-10.
  • Muszynska, A., EXPERIMENTAL AND ANALYTICAL STUDY ON FLUID WHIRL AND FLUID WHIP MODES, 7th Workshop on Rotordynamic Instability Problems in High Performance Turbomachinery, Texas A&M, College Station, TX, 1993.
  • Goldman, P., Muszynska, A., CHAOTIC BEHAVIOR OF ROTOR/STATOR SYSTEMS WITH RUBS, ASME Turbo Expo Conference, 93-GT-387, Cincinnati, OH, 1993; also Journal of Engineering for Gas Turbines and Power, v. 116, July 1994, pp. 692-701.
  • Grant, J., Muszynska, A., Bently, D. E., PARAMETER IDENTIFICATION OF A ROTOR SUPPORTED IN A PRESSURIZED BEARING LUBRICATED WITH WATER, 7th Workshop on Rotordynamic Instability Problems in High Performance Turbomachinery, Texas A&M, College Station, TX, May 1993.
  • Muszynska, A., Goldman, P., CHAOTIC VIBRATIONS OF ROTOR/BEARING/STATOR SYSTEMS WITH LOOSENESS OR RUBS, ASME Vibration and Noise Conference, Nonlinear Vibrations, DE-Vol. 54, Albuquerque, NM, September 1993, pp. 187-194.
  • Muszynska, A., MODAL TESTING OF ROTORS WITH FLUID INTERACTION, Colloquium on Turbomachinery, Turbo and Power Machinery Research Center, Seoul National University, Seoul, Korea, 27 June - 2 July 1993; also International Journal of Rotating Machinery, Vol. 1, No. 2, 1995, pp. 83-116.
  • Muszynska, A. ,HALF-POWER BANDWIDTH METHOD FOR THE EVALUATION OF SYNCHRONOUS AND NON- SYNCHRONOUS QUADRATURE STIFFNESSES, BRDRC Centerlines, Orbit, June 1994, pp. 7-10.
  • Muszynska, A., APPLICATION OF MULTI-MODE MODAL MODELS IN ROTOR DYNAMICS, Proceedings of the ISROMAC-5, Maui, Hawaii, 1994.
  • Muszynska, A., Hatch, C. T., Bently, D. E., APPLICATION OF MULTI-MODE MODELS AND ROOT LOCUS TECHNIQUE FOR STABILITY ANALYSIS OF ROTOR SYSTEMS, Proceedings of the ISROMAC-5, Maui, Hawaii, 1994.
  • Franklin, W. D., Muszynska, A., Bently, D. E., PARAMETER IDENTIFICATION WITH NONCOLLOCATION OF FORCE AND MEASUREMENT LOCATIONS USING NONSYNCHRONOUS PERTURBATION AND OPTIMIZATION TECHNIQUES, 39-th ASME TURBO EXPO, 94-GT-127, The Hague, The Netherlands, June 1994.
  • Goldman, P., Muszynska, A. , ROTOR-TO-STATOR, RUB-RELATED THERMAL/MECHANICAL EFFECTS IN ROTATING MACHINERY, "Chaos, Solitons and Fractals" Special Issue, Vol. 5, No. 9, Pergamon Press, Paris, France, 1995, pp. 1579-1601.
  • Muszynska, A., Goldman, P., CHAOTIC RESPONSES OF UNBALANCED ROTOR/BEARING/STATOR SYSTEMS WITH LOOSENESS OR RUBS, "Chaos, Solitons and Fractals" Special Issue, Vol. 5, No. 9, Pergamon Press, Paris, France, 1995, pp. 1683-1704.
  • Petchenev, A., Muszynska, A., ANALYTICAL DERIVATION OF THE DYNAMIC PARAMETERS OF A FLUID JOURNAL BEARING IN THE CASE OF A SHAFT WITH AN EXTERNAL RADIAL FORCE, BRDRC Report No. 1, 1994.
  • Goldman, P., Muszynska, A., Bently, D. E., TORSIONAL/LATERAL CROSS COUPLING DUE TO THE SHAFT ASYMMETRY: ANALYTICAL STUDY AND COMPUTER SIMULATION, BRDRC Report No. 2, 1994 (new title: '"Snapping" Torsional Response of the Anisotropic Radially Loaded Rotor.')
  • Muszynska, A., Bently, D. E., FLUID DYNAMIC FORCE MODEL FOR ROTORS WITH SEALS OR LIGHTLY-LOADED BEARINGS, Orbit, December 1994, Vol. 15, No. 4, pp. 5-7.
  • Bently, D. E., Goldman, P., Muszynska, A., "SNAPPING" TORSIONAL RESPONSE OF AN ANISOTROPIC RADIALLY LOADED ROTOR, ASME Turbo Expo, 95-GT-396, Houston, Texas, June 1995; also Trans. of the ASME, Journal of Engrg. for Gas Turbines and Power, Vol. 119, No. 2, 1997, pp. 397-403.
  • Petchenev, A., Goldman, P., Muszynska, A., Bently, D. E., ANALYTICAL STUDY ON THE FLUID JOURNAL BEARING/SEAL/ROTOR SYSTEM, The Joint American Society of Mechanical Engineers & Japan Society of Mechanical Engineers Fluids Engineering Annual Conference & Exhibition, Hilton Head Island, SC, 13-18 August 1995.
  • Muszynska, A., FORWARD AND BACKWARD PRECESSION OF A VERTICAL ANISOTROPICALLY SUPPORTED ROTOR, BRDRC Report No 7, 1994; also Journal of Sound and Vibration, Vol. 192, 1st Issue, 25 April 1996, pp. 207-222.
  • Bently, D. E., Goldman, P., Muszynska, A., "SNAPPING" TORSIONAL RESPONSE CAN LEAD TO A WORSENING CRACK SITUATION, Orbit, Vol. 16, No. 2, June 1995, pp. 6-11.
  • Goldman, P., Muszynska, A., SMOOTHING TECHNIQUE FOR RUB OR LOOSENESS-RELATED ROTOR DYNAMIC PROBLEMS, Proceedings of the 15-th ASME Biennial Vibration and Noise Conference, Boston, Mass., 1995.
  • Muszynska, A., DATA PROCESSING FOR ANISOTROPICALLY SUPPORTED ROTORS, BRDRC Report No. 2, 1995.
  • Muszynska, A., Bently, D. E., FLUID-INDUCED INSTABILITIES OF ROTORS, WHIRL AND WHIP, BRDRC Report No. 3, 1995.
  • Muszynska, A., Bently, D. E., VIBRATION MONITORING AND ANALYSIS FOR ROTATING MACHINERY, Key Note Address, Noise and Vibration '95 Conference and Workshop, Pretoria, South Africa, 1995, pp. 1-24.
  • Muszynska, A., CASE HISTORY: PARTIAL RUB EXPERIMENT, BRDRC Report No. 4, 1995.
  • Muszynska, A., CASE HISTORY: ROTOR RESPONSES TO A LOOSE BRASS OILITE BEARING, BRDRC Report No. 5, 1995.
  • Muszynska, A., CASE HISTORY: VIBRATION RESPONSES OF A ROTOR WITH A LOOSE ROTATING PART, BRDRC Report No. 6, 1995.
  • Muszynska, A., Bently, D. E., FLUID-INDUCED INSTABILITIES OF ROTORS: WHIRL AND WHIP -- SUMMARY OF RESULTS, Noise and Vibration '95 Conference and Workshop, Pretoria, South Africa, 1995, pp. 79-88; also Orbit, March 1996, pp. 7-15.
  • Jang, Eungu, Park, Young-Pil, Kim, Chang-Ho, Muszynska, A., IDENTIFICATION OF THE QUADRATURE RESONANCES USING MODAL NONSYNCHRONOUS PERTURBATION TESTING AND DYNAMIC STIFFNESS APPROACH FOR AN ANISOTROPIC ROTOR SYSTEM WITH FLUID INTERACTION, International Journ. of Rotating Machinery, v. 2, No. 3, 1996, pp. 187-199.
  • Muszynska, A., Hatch, C. T., Bently, D. E., DYNAMICS OF ANISOTROPICALLY SUPPORTED ROTORS, Proceedings of the International Symposium on Transport Phenomena and Dynamics of Rotating Machinery, ISROMAC-6, Honolulu, Hawaii, February 1996; also International Journal of Rotating Machinery, v. 3, No. 2, 1997.
  • Goldman, P., Petchenev, A., Bently, D. E., Muszynska, A., TORQUE AND POWER LOSS IN A CYLINDRICAL FLUID-LUBRICATED BEARING/ROTOR SYSTEM, 96-GT-408, ASME International Gas Turbine and Aeroengine Congress & Exhibition, Birmingham, U.K., June 1996.
  • Muszynska, A., STRESS IN ROTATING AND LATERALLY VIBRATING MACHINERY ROTORS, IMechE Conference, "Vibrations in Rotating Machinery Conference," Oxford, U.K., C500/069/96, 1-14 September 1996.
  • Muszynska, A., EVALUATION OF DAMPING IN NONROTATING STRUCTURES AND QUADRATURE DYNAMIC STIFFNESS IN ROTATING STRUCTURES, BRDRC Report No. 2, 1996.
  • Bently, D. E., Muszynska, A., Littrell, N. B., MARGIN OF STABILITY, Orbit, BNC, v. 17, No. 2, June 1996, pp. 4-6.
  • Muszynska, A., SPECIFICS OF DAMPING EVALUATION IN ROTATING MACHINES, Proceedings of ASME/IGTI Turbo Asia '96 Conference, 5-7 November 1996.
  • Goldman, P., Bently, D. E., Muszynska, A., THE MULTIMODAL CRACKED ROTOR SYNCHRONOUS RESPONSE, BRDRC Report No. 4, 1996.
  • Goldman, P., Bently, D. E., Muszynska, A., THE MODAL DIAGNOSTICS OF ROTORS WITH CRACKS, ASME 1996/IMechE Symposium on "Nonlinear Dynamics and Control," DE-Vol. 91, Atlanta, Georgia, Nov. 1996, pp. 185-190.
  • Muszynska, A., Petchenev, A., Bently, D. E., VIBRATION RESPONSE OF A ROTOR SUPPORTED IN ONE RIGID AND ONE POORLY LUBRICATED FLUID FILM BEARING, Orbit, BNC, v. 17, No. 3, 1996, pp. 7-9.
  • Muszynska, A., Petchenev, A., Bently, D. E., CASE HISTORY ON VIBRATION RESPONSE OF A ROTOR SUPPORTED IN ONE RIGID AND ONE POORLY LUBRICATED FLUID FILM BEARING, BRDRC Report No. 3, 1996.
  • Muszynska, A., Littrell, N. B., Bently, D. E., STABILIZING INFLUENCE OF GYROSCOPIC EFFECT ON RIGID ROTORS UNDER FLUID INTERACTION, BRDRC Report No. 5, 1996.
  • Goldman, P., Muszynska, A., Bently, D. E., DYNAMICS OF MULTIMODAL ROTORS WITH TRANSVERSE CRACKS, Proceedings of the 12th Machinery Failure Prevention Technology Conference, Virginia Beach, Virginia, 1997.
  • Muszynska, A., Petchenev, A., Goldman, P., DYNAMICS OF ROTOR/BEARING SYSTEMS WITH FLEXIBLE ROTOR AND FLEXIBLE BEARING SUPPORT, 1997 ASME Design Engng. Techn. Conference, DETC97/VIB-4042, Sacramento, CA, September 1997.
  • Muszynska, A., FREE, FORCED, AND SELF-EXCITED VIBRATIONS, BRDRC Report No 2, 1997; also Orbit, Vol. 18, No. 4, December 1997.
  • Franklin, W., Bently, D. E., Goldman, P., Muszynska, A., EARLY CRACKED SHAFT DETECTION IN PUMPS USING ROTOR LATERAL VIBRATION ANALYSIS, ASME Fluids Division Summer Meeting, FEDSM97-3338, June 1997.
  • Grant, J., Bently, D. E., Muszynska, A., ACTIVE CONTROLLED HYDROSTATIC BEARING FOR A NEW GENERATION OF MACHINES, The Eleventh Symposium on Structural Dynamics and Control, 12-14 May 1997, Virginia Polytechnic Institute and State University, Blacksburg, Virginia; also The International Gas Turbine & Aeroengine Congress & Exhibition, ASME 2000-GT-354, Munich, Germany, 8-11 May 2000.
  • Jensen, R., Muszynska, A., USE OF RELATIVE AND ABSOLUTE MEASUREMENTS FOR INFLUENCE VECTOR BALANCING FOR A SOFTLY SUPPORTED ROTOR, BRDRC Report No 1,1997.
  • Littrell, N. B., Muszynska, A., Goldman, P., RIGID BODY MODES STABILITY OF A ROTOR SUPPORTED IN TWO FLUID BEARINGS, BRDRC Report No 3,1997.
  • Muszynska, A., Petchenev, A., IMPROVING STARTUP PASSING RESONANCE BY SUPPORT STIFFNESS CONTROL, BRDRC Report No 9,1997.
  • Muszynska, A., Hatch, C. T., OIL WHIP OF A ROTOR SUPPORTED IN A POORLY LUBRICATED BEARING, BRDRC Report No 10, 1997; also Orbit, BNC, Vol. 19, No. 3, September 1998, pp. 4-8.
  • Jensen, R., Muszynska, A., USE OF FORWARD RESPONSE DATA FOR THE BALANCING OF ANISOTROPIC ROTORS, BRDRC Report No 5, 1997.
  • Muszynska, A., Littrell, N., DYNAMIC ABSORBER FOR VIBRATION OF A ROTOR/BEARING SYSTEM, BRDRC Report No 4, 1997.
  • Muszynska, A., TRANSITION TO FLUID-INDUCED LIMIT CYCLE SELF-EXCITED VIBRATIONS OF A ROTOR AND INSTABILITY THRESHOLD "HYSTERESIS," Proceedings of the 7th International Symposium on Transport Phenomena and Dynamics of Rotating Machinery, ISROMAC-7, Honolulu, Hawaii, February 1998; also International Journal of Rotating Machinery, Vol. 5, No. 2, 1999, pp. 123-133.
  • Littrell, N. B., Muszynska, A., Goldman, P., REVISITING ROTOR RIGID BODY MODES: PARAMETRIC STUDY OF STABILITY, Proceedings of the 7th International Symposium on Transport Phenomena and Dynamics of Rotating Machinery, ISROMAC-7, Honolulu, Hawaii, February 1998; also International Journal of Rotating Machinery, Vol. 5, No. 3, 1999, pp. 193-201.
  • Goldman, P., Muszynska, A., Bently, D. E., THERMAL BENDING OF THE ROTOR DUE TO ROTOR-TO-STATOR RUB, Proceedings of the 7th International Symposium on Transport Phenomena and Dynamics of Rotating Machinery, ISROMAC-7, Honolulu, Hawaii, February 1998; also International Journal of Rotating Machinery, Vol. 6, No. 2, 2000, pp. 91-100.
  • Bently, D. E., Muszynska, A., Petchenev, A., CASE HISTORY ON VIBRATION RESPONSE (EXHIBITING "8"-SHAPED ORBITS) OF A SIDE-LOADED ROTOR SUPPORTED IN ONE BRONZE BUSHING AND ONE FLUID-LUBRICATED BEARING, BRDRC Report No. 2, 1998.
  • Muszynska, A., Bently, D. E., Yuan, J., SIMULATION RESULT FOR THE OIL WHIP OF A ROTOR SUPPORTED IN A POORLY LUBRICATED BEARING, BRDRC Report No. 4, 1998.
  • Muszynska, A., MARIE SKLODOWSKA CURIE, Orbit, BNC, Vol. 19, No. 3, September 1998, p. 6.
  • Muszynska, A., ALFORD AND THE DESTABILIZING FORCES THAT LEAD TO FLUID WHIRL/WHIP, Orbit, BNC, Vol. 19, No. 3, September 1998, pp. 29-31.
  • Bently, D. E., Muszynska, A., Dayton, K. P., Yuan, J., DEMONSTRATION OF FLUID WHIRL INSTABILITY FREQUENCY SHIFT RESULTING FROM CHANGING LUBRICATION CONDITIONS AT A FLUID BEARING, BRDRC Report No. 3, 1998.
  • Yu, J., Muszynska, A., Bently, D. E., DYNAMIC BEHAVIOR OF ROTOR WITH FULL ANNULAR RUB, BRDRC Report No. 7, 1998.
  • Muszynska, A., Yuan, J., Goldman, P., Petchenev, A., ROTOR LATERAL/TORSIONAL COUPLING DUE TO UNBALANCE: FORCED AND SELF-EXCITED VIBRATIONS, BRDRC Report No. 8, 1998.
  • Bently, D. E., Muszynska, A., Yuan, J., SIMULATIONS OF SYNCHRONOUS RESPONSES OF AN ISOTROPIC ROTOR SUPPORTED IN ROLLING-ELEMENT BEARINGS AND SQUEEZE-FILM DAMPERS, BRDRC Report No. 9, 1998.
  • Petchenev, A., Bently, D. E., Muszynska, A., Goldman, P., CASE HISTORY OF A FAILURE OF A GAS TURBINE WITH A FLOATING SLEEVE BEARING (THE GARRETT 831-800 GAS TURBINE - THE BENTLY NEVADA CORPORATION TURBINE GENERATOR #1), BRDRC Report No. 1, 1999.
  • Bently, D. E., Muszynska, A., Yuan, J., SIMULATIONS OF SYNCHRONOUS RESPONSES OF AN ISOTROPIC ROTOR SUPPORTED IN ROLLING-ELEMENT BEARINGS AND SQUEEZE-FILM DAMPERS (ABBREVIATED VERSION), BRDRC Report No. 3, 1999.
  • Goldman, P., Muszynska, A., APPLICATION OF FULL SPECTRUM TO ROTATING MACHINERY DIAGNOSTICS," Orbit, BNC, Vol. 20, No. 1, First Quarter, 1999.
  • Muszynska, A., Goldman, P., Yuan, J., INTERPRETATION OF EIGENVECTORS FOR LATERAL/TORSIONAL MODES, BRDRC Report No 4, 1999.
  • Bently, D.E., Yu, J.J., Muszynska,A., Goldman, P., COMPARISON BETWEEN "BEARING COEFFICIENTS" AND "BENTLY/MUSZYNSKA" MODEL FOR FLUID-LUBRICATED BEARINGS, BRDRC Report No. 5, 1999
  • Petchenev, A., Bently, D. E., Muszynska, A., Goldman, P., Grissom, R. L., CASE HISTORY OF A FAILURE OF A GAS TURBINE WITH A FLOATING SLEEVE BEARING, Proceedings of the 1999 ASME Design Engineering Technical Conference, Las Vegas, Nevada, 12-15 September 1999.
  • Goldman, P., Muszynska, A., Bently, D. E., Dayton, K. P., APPLICATION OF PERTURBATION METHODOLOGY AND DIRECTIONAL FILTERING FOR EARLY ROTOR CRACK DETECTION, presented at the ASME International Gas Turbine & Aeroengine Congress & Exhibition, Indianapolis, Indiana, 7-10 June 1999.
  • Muszynska, A., Yuan, J., TWO-MODE ANISOTROPIC ROTOR NONSYNCHRONOUS RESPONSES, BRDRC Report No. 6, 1999.
  • Yu, J.J., Goldman, P., Bently, D.E., Muszynska, A., ROTOR/SEAL EXPERIMENTSL AND ANALYTICAL STUDY ON FULL ANNULAR RUB, submitted to the Transactions of the ASME, 2000.
  • Muszynska, A., Yu, J.J., ROTOR/SEAL FULL ANNULAR RUB. PART1: EXPERIMENT, PART 2: ANALYSIS, submitted to the Journal of Sound and Vibration, 2001.
发表于 2005-8-28 18:39 | 显示全部楼层
这本书不错啊,哪儿能买到哈?
发表于 2005-8-31 17:57 | 显示全部楼层
发表于 2005-12-29 11:13 | 显示全部楼层
请问楼主是在哈工大吗?可否告知下电子邮箱,我想借下你那本书复印下行吗?
发表于 2005-12-30 21:29 | 显示全部楼层
买的话是有点贵了
发表于 2008-4-30 13:16 | 显示全部楼层
我有这本书的电子版本.要的话给你们,我的邮箱lei571@163.com
发表于 2008-5-5 08:47 | 显示全部楼层
请问楼主有作者的email吗,我也想请教问题,谢谢
发表于 2009-1-5 10:14 | 显示全部楼层
lei571,你好,我需要电子版,可以发到我邮箱吗?谢谢了
zhoukjcq@sina.com
发表于 2009-1-18 16:28 | 显示全部楼层
lei571,可以也给我发一份吗?persist_lxb@163.com       不胜感激。
发表于 2009-1-18 23:31 | 显示全部楼层
朋友 也能发一份给我吗 谢谢了
  lianghong2002@sina.com
真的多谢
GMT+8, 2025-1-18 20:20 , Processed in 0.081200 second(s), 20 queries , Gzip On.
