查看: 7002|回复: 6
[Fortran] 求FFT的Fortran源程序及详细的使用方法
发表于 2006-8-15 19:00 | 显示全部楼层 |阅读模式
哪位大侠把FFT的Fortran源程序和详细的使用方法发一下,小弟急用,谢谢!
发表于 2006-8-15 20:24 | 显示全部楼层
FFT的Fortran程序在好多书中有,这里列出一个,取自Brigham "The Fast Fourier Transform"一书的10.8。
发表于 2006-9-2 07:08 | 显示全部楼层
fortran的库中自带FFT程序
6.1. Real Trigonometric FFT
Forward transform................................................................ FFTRF 764
Backward or inverse transform............................................ FFTRB 768
Initialization routine for FFTR*................................................FFTRI 770
6.2. Complex Exponential FFT
Forward transform................................................................ FFTCF 772
Backward or inverse transform............................................ FFTCB 774
Initialization routine for FFTC*................................................FFTCI 777
6.3. Real Sine and Cosine FFTs
Forward and inverse sine transform..................................... FSINT 779
Initialization routine for FSINT.................................................FSINI 780
Forward and inverse cosine transform.................................FCOST 782
Initialization routine for FCOST.............................................FCOSI 784
6.4. Real Quarter Sine and Quarter Cosine FFTs
Forward quarter sine transform.............................................QSINF 786
Backward or inverse transform.............................................QSINB 788
Initialization routine for QSIN*................................................ QSINI 790
Forward quarter cosine transform.......................................QCOSF 791
Backward or inverse transform...........................................QCOSB 793
Initialization routine for QCOS* ............................................ QCOSI 795
6.5. Two- and Three-Dimensional Complex FFTs
Forward transform.................................................................FFT2D 797
Backward or inverse transform.............................................FFT2B 800
Forward transform.................................................................FFT3F 802
Backward or inverse transform.............................................FFT3B 806
发表于 2009-9-6 22:00 | 显示全部楼层
没有什么实际的帮助!
发表于 2011-1-26 13:45 | 显示全部楼层
回复 4 # lcc8321 的帖子
是啊,发一个这个玩意给楼主,一点帮助都没有,你为什么要发呢? 还占用版面,我真奇怪
发表于 2011-3-11 17:09 | 显示全部楼层
楼上的两位懒到这个地步,别人也只能无语了
发表于 2011-3-11 17:12 | 显示全部楼层
回复 6 # 风花雪月 的帖子
前辈,好久不见!
好久不见,放假后一直比较忙,今天抽空跑来看看  发表于 2011-3-11 17:19
GMT+8, 2025-6-21 04:37 , Processed in 0.101753 second(s), 23 queries , Gzip On.
