查看: 2478|回复: 0
[Fortran] 利用DFT的卷积性质求两个复序列的线性卷积
发表于 2006-8-11 07:13 | 显示全部楼层 |阅读模式
主程序:
  1. C----------------------------------------------------------------------
  2. C main program HCONVO2:To test subroutine CONVO2
  3. c Please link subroutine CONVO2,SPLFFT
  4. C----------------------------------------------------------------------
  5.         complex h(0:7),x(0:7),y(0:7)
  6.         data n1/4/,n2/2/,n/8/
  7.         do 10 i=0,3
  8.            h(i)=1.
  9.            x(i)=i+1.
  10. 10      continue
  11.         h(0)=1.
  12.         h(1)=1.
  13.         x(0)=1.
  14.         x(1)=2.
  15.         x(2)=3.
  16.         x(3)=4.
  17.         call convo2(x,h,y,n1,n2,n)
  18.         do 20 k=0,n1+n2-2
  19. 20        write(*,*)k,real(y(k))
  20.         stop
  21.         end
子程序:
  1.         subroutine convo2(x,h,y,n1,n2,n)
  2. c----------------------------------------------------------------------
  3. c  Routine CONVO2: To Compute the Convolution of x(i) and h(i) by DFT.
  4. c  x(i),i=0,...,n1-1; h(n),i=0,...,n2-1,But the dimension n of x,h,y
  5. c       must be >=(n1+n2-1) and be the power of 2 ;
  6. c input parameters:
  7. c x( ):n dimensioned real array,signal data is stored in x(0) to x(n1-1).
  8. c h( ):n dimensioned real array,impuls response is stored in h(0) to h(n2-1).
  9. c output parameters:
  10. c y( ):n dimensioned real array, y(i)=x(i)*h(i),i=0,...n-1.
  11. c Notes:
  12. c     n must be a power of 2.
  13. c                                      in chapter 3
  14. c----------------------------------------------------------------------
  15.         complex x(0:n-1),y(0:n-1),h(0:n-1)
  16.         do 10 i=1,16
  17.            nn=2**i
  18.            if(n.eq.nn) go to 20
  19. 10       continue
  20.         write(*,*)'  N is not a power of 2'
  21.         return
  22. 20      do 30 i=n1,n-1
  23. 30          x(i)=0.
  24.         do 40 i=n2,n-1
  25. 40         h(i)=0.
  26.         call splfft(x,n,-1)
  27.         call splfft(h,n,-1)
  28.         do 50 k=0,n-1
  29. 50         y(k)=x(k)*h(k)
  30.         call splfft(y,n,1)
  31.         return
  32.         end
[ 本帖最后由 VibInfo 于 2006-8-11 07:17 编辑 ]
GMT+8, 2024-9-30 03:20 , Processed in 0.060006 second(s), 19 queries , Gzip On.
