查看: 2688|回复: 0
[Fortran] 用FFT实现相关函数快速估计
发表于 2006-8-6 07:34 | 显示全部楼层 |阅读模式
主程序:
  1. c----------------------------------------------------------------------
  2. c   Main program HCORRE2 : to test subroutine CORRE2
  3. c   To compute the auto-correlation function of a simple data by FFT
  4. C   Please link subroutine CORRE2,SPLFFT
  5. c----------------------------------------------------------------------
  6.         complex x(0:15)
  7.         data m/8/,n/16/,icorre/0/
  8.         do 10 i=0,m-1
  9.            x(i)=i+1.
  10. 10      continue
  11.         call corre2(x,x,m,n,icorre,ierror)
  12.         write(*,*)'   ierror=',ierror
  13.         if(ierror.ne.0) stop
  14.         write(*,*)(x(i),i=0,n-1)
  15.         stop
  16.         end
子程序:
  1.         subroutine corre2(x,y,m,n,icorre,ierror)
  2. c----------------------------------------------------------------------
  3. c  Routinue CORRE2: To Compute the Correlation  Function of x(i) and
  4. c  y(i) by DFT. x(i),y(i),i=0,...,m-1;But the dimension n of x,y must
  5. c  be >=2*m and be the power of 2 ;
  6. c  If: icorre=0:For auto-correlation
  7. c      icorre=1:For crros-correlation
  8. c                                       in chapter 11
  9. c----------------------------------------------------------------------
  10.         complex x(0:n-1),y(0:n-1)
  11.         ierror=1
  12.         s=n
  13. 1       s=s/2.
  14.         if(s-2.)70,5,1
  15. 5       do 10 i=m,n-1
  16. 10          x(i)=0.
  17.         call splfft(x,n,-1)
  18.         if(icorre.eq.1)goto 30
  19.         do 20 k=0,n-1
  20.            x(k)=conjg(x(k))*x(k)/float(m)
  21. 20      continue
  22.         goto 60
  23. 30      do 40 i=m,n-1
  24. 40         y(i)=0.
  25.         call splfft(y,n,-1)
  26.         do 50 k=0,n-1
  27.            x(k)=conjg(x(k))*y(k)/float(m)
  28. 50      continue
  29. 60      call splfft(x,n,1)
  30.         ierror=0
  31. 70      return
  32.         end
GMT+8, 2024-9-30 03:36 , Processed in 0.140706 second(s), 17 queries , Gzip On.
