查看: 2746|回复: 0
[Fortran] 实现双线性Z变换
发表于 2006-8-6 07:22 | 显示全部楼层 |阅读模式
  1.         subroutine biline(work,d,c,ln,b,a,ierror)
  2. c----------------------------------------------------------------------
  3. c Routine BILINE: To convert analog H(S) to digital H(Z) via bilinear
  4. c                 transformation. H(S)=D(S)/C(S), H(Z)=B(Z)/A(Z)
  5. c LN specifies the length of the coefficient arrays and filter order L
  6. c is computed internally.   WORK is an internal array (2D)
  7. c   IF  IERROR=0:    no errors detected in transformation
  8. c             =1:    all zero transfer function
  9. c             =2:    invalid transfer function; y(k) coef=0
  10. c       From Ref. [5] of Chapter 2 .       in chapter 7
  11. c----------------------------------------------------------------------
  12.         dimension work(0:4,0:4),d(0:4),c(0:4),b(0:4),a(0:4)
  13.         do 10 i=ln,0,-1
  14.            if(c(i).ne.0..or.d(i).ne.0.)go to 20
  15. 10      continue
  16.         ierror=1
  17.         return
  18. 20      l=i
  19.         do 30 J=0,L
  20.            work(0,j)=1.
  21. 30       continue
  22.         tmp=1.
  23.         do 40 i=1,l
  24.            tmp=tmp*float(l-i+1)/float(i)
  25.            work(i,0)=tmp
  26. 40       continue
  27.         do 60 i=1,l
  28.            do 50 j=1,l
  29.               work(i,j)=work(i,j-1)-work(i-1,j)-work(i-1,j-1)
  30. 50         continue
  31. 60      continue
  32.         do 80 i=l,0,-1
  33.            b(i)=0.
  34.            atmp=0.
  35.            do 70 j=0,l
  36.               b(i)=b(i)+work(i,j)*d(j)
  37.               atmp=atmp+work(i,j)*c(j)
  38. 70          continue
  39.            scale=atmp
  40.            if(i.ne.0) a(i)=atmp
  41. 80      continue
  42.         ierror=2
  43.         if(scale.eq.0.) return
  44.         b(0)=b(0)/scale
  45.         do 90 i=1,l
  46.            b(i)=b(i)/scale
  47.            a(i)=a(i)/scale
  48. 90      continue
  49.         do 100 i=l+1,ln
  50.            b(i)=0.0
  51.            a(i)=0.0
  52. 100     continue
  53.         ierror=0
  54.         return
  55.         end
GMT+8, 2025-7-11 13:24 , Processed in 0.075698 second(s), 18 queries , Gzip On.
